oil pressure guage not working. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: oil pressure guage not working. (/showthread.php?tid=2962) |
oil pressure guage not working. - nslinkman - 07-15-2006 02:44 Don't even know where to start. I have a 1994 40' with an 8v92 coach. Any help would be appreciated. Thanks in advance. Nelson Westminster, Md oil pressure guage not working. - Leroy Eckert - 07-15-2006 05:20 Nelson: I would start at the sender. The sender on my 8v92 is located under the right-hand rear of the engine. It is silver or gold about 2" high and 1" in diameter. Check to see if the wire us attached to the sender first. It takes about 5 minutes to change/less than $20.00. My gauge quit on the road, put a new sender in, it quit also, put another new sender in and has been fine since. Leroy Eckert 1990WB-40 Niceville,FL ----- Original Message ----- From: nslinkman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 15, 2006 9:44 AM Subject: [WanderlodgeForum] oil pressure guage not working. Don't even know where to start. I have a 1994 40' with an 8v92 coach. Any help would be appreciated. Thanks in advance. Nelson Westminster, Md [Non-text portions of this message have been removed] oil pressure guage not working. - krminyl@... - 07-15-2006 06:48 Tough part is finding a parts house that stocks the sender. It has to match the gauge, of the same ohmage (sp?). I found my replacement sender at a shop that builds new dashboards for busses...if you have difficulty finding a new sender, let me know, and I'll try to find the name and number of the shop where I got mine (somewhere in Gardena, CA). Do you have Teleflex gauges? Cost about $40 I think... Kevin McKeown Yorba Linda, CA 1986 38' PT 8V92 [Non-text portions of this message have been removed] oil pressure guage not working. - Leroy Eckert - 07-15-2006 11:48 I purchased the part from Coachworks by MacDonald in Columbus, GA. They are a BB warranty and mod house. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 15, 2006 5:48 PM Subject: Re: [WanderlodgeForum] oil pressure guage not working. Tough part is finding a parts house that stocks the sender. It has to match the gauge, of the same ohmage (sp?). I found my replacement sender at a shop that builds new dashboards for busses...if you have difficulty finding a new sender, let me know, and I'll try to find the name and number of the shop where I got mine (somewhere in Gardena, CA). Do you have Teleflex gauges? Cost about $40 I think... Kevin McKeown Yorba Linda, CA 1986 38' PT 8V92 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] oil pressure guage not working. - nslinkman - 07-15-2006 17:46 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > Leroy thanks alot for the info. I will check it tomorrow. > Nelson: I would start at the sender. The sender on my 8v92 is located under the right-hand rear of the engine. It is silver or gold about 2" high and 1" in diameter. Check to see if the wire us attached to the sender first. It takes about 5 minutes to change/less than $20.00. My gauge quit on the road, put a new sender in, it quit also, put another new sender in and has been fine since. > > Leroy Eckert > 1990WB-40 > Niceville,FL > > > > > > ----- Original Message ----- > From: nslinkman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 15, 2006 9:44 AM > Subject: [WanderlodgeForum] oil pressure guage not working. > > > Don't even know where to start. I have a 1994 40' with an 8v92 coach. > Any help would be appreciated. > Thanks in advance. > > Nelson Westminster, Md > > > > > > [Non-text portions of this message have been removed] > oil pressure guage not working. - nslinkman - 07-15-2006 17:49 I will take the dash out tomorrow. I will let you know the brand. Thanks Alot --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Tough part is finding a parts house that stocks the sender. It has to match > the gauge, of the same ohmage (sp?). I found my replacement sender at a > shop that builds new dashboards for busses...if you have difficulty finding a > new sender, let me know, and I'll try to find the name and number of the shop > where I got mine (somewhere in Gardena, CA). Do you have Teleflex gauges? > > Cost about $40 I think... > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > 8V92 > > > [Non-text portions of this message have been removed] > |
