FC Cooling Fan - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FC Cooling Fan (/showthread.php?tid=2966) |
FC Cooling Fan - keith - 07-15-2006 11:49 Hello Wise Ones, My 1981 FC'S cooling fan began behaving irractically..do's antoe have a a wiring diagram for this? Is there a relay or just a theromswitch??? Any help is appreciated. Thanks Keith 1981 33 FC FC Cooling Fan - Jeff Miller - 07-15-2006 14:32 A thermoswitch located to the streetside of the fan pulley on the front of the engine. Check the wire terminals on the fan bracket also. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "keith" > > Hello Wise Ones, > > My 1981 FC'S cooling fan began behaving irractically..do's antoe have a > a wiring diagram for this? Is there a relay or just a theromswitch??? > > Any help is appreciated. > > Thanks Keith > > 1981 33 FC > FC Cooling Fan - jim matus - 07-16-2006 15:58 My fan started acting up on our way home from Minn. after buying our bird. On mine the problem was a bad ground. The ground wire from the fan goes under a bolt on the top of the fan carrier/adjuster. My ground wire was loose and had old loose paint and rust under it.Cleaned it up works great. Jim Matus 1984 FC35 Rescue CA \ > > A thermoswitch located to the streetside of the fan pulley on the front > of the engine. Check the wire terminals on the fan bracket also. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "keith" > > > > Hello Wise Ones, > > > > My 1981 FC'S cooling fan began behaving irractically..do's antoe have > a > > a wiring diagram for this? Is there a relay or just a theromswitch??? > > > > Any help is appreciated. > > > > Thanks Keith > > > > 1981 33 FC > > > |
