exhaust problem revisited - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: exhaust problem revisited (/showthread.php?tid=2968) |
exhaust problem revisited - Bob Benner - 07-16-2006 01:18 Here's the page to see what I eventually did to fix the problem. http://bennersfarm.com/BF%20Home/Bluebird/bus%20dilemma.html None of the parts were available so I had to follow the guru Rube Goldberg and concoct a fix as I'm leaving Wednesday for the north. On the page at the top is a picture of what I believe is the tach sender. It is loose, not being held by anything and is easily slipped out of its hole. Attached at the bottom of the unit is a gear that is also loose and easily lifted from the hole. Do any of you know if this is a Detroit part or aftermarket or where I can find it. Also are there any 'do not's', I should know about when I go to change it? Bob 86PT40 on sticky LI exhaust problem revisited - Jay Darst - 07-16-2006 02:09 Looks like that should work... Apparently the ring slides on the pipe? None of the flanges are removable on my exhaust pipes. I don't see how that would have ever held? my connections consisted of the following: 1.)cast iron exhaust manifold to steel exhaust pipe connected via a "V" clamp with no removable flange or ring. 2.)steel exhaust pipe connected to cast iron turbo inlet "T" via a "V" clamp with no removable flange or ring. Both ends of the steel pipe are flanged to accomodate the "V" clamp. Both cast iron pieces have a nice flange cast into them. So, I don't understand the removable flange or ring. It would appear to me that there has been a repair that was done using none standard parts. Looks like what you've done is a very good temporary repair, may even last a long time ;~} Jay Darst 85PT40 6V92 with all new exhaust and drivers side exhaust manifold in 2005. Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Bob Benner" wrote: > > Here's the page to see what I eventually did to fix the problem. > > http://bennersfarm.com/BF%20Home/Bluebird/bus%20dilemma.html > > None of the parts were available so I had to follow the guru Rube Goldberg and concoct a > fix as I'm leaving Wednesday for the north. > > On the page at the top is a picture of what I believe is the tach sender. It is loose, not > being held by anything and is easily slipped out of its hole. Attached at the bottom of the > unit is a gear that is also loose and easily lifted from the hole. > > Do any of you know if this is a Detroit part or aftermarket or where I can find it. Also are > there any 'do not's', I should know about when I go to change it? > > Bob > 86PT40 > on sticky LI > exhaust problem revisited - Jay Darst - 07-16-2006 02:28 IS THIS CONNECTION AFTER THE TURBO? When you said that you noticed more and more black smoke, that would indicate that the turbo was not forcing a good volume of air into the engine, therefore the extremely rich mixture(black smoke). Black smoke is indicative of the exhaust pipe leaking before the turbo, causing reduced turbo boost, which causes reduced engine air, which results in too rich a fuel/air mixture, which shows itself as black smoke. Jay Darst --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Looks like that should work... > > Apparently the ring slides on the pipe? > > None of the flanges are removable on my exhaust pipes. I don't see > how that would have ever held? > > my connections consisted of the following: > > 1.)cast iron exhaust manifold to steel exhaust pipe connected via > a "V" clamp with no removable flange or ring. > > 2.)steel exhaust pipe connected to cast iron turbo inlet "T" via > a "V" clamp with no removable flange or ring. > > Both ends of the steel pipe are flanged to accomodate the "V" clamp. > Both cast iron pieces have a nice flange cast into them. > > So, I don't understand the removable flange or ring. It would appear > to me that there has been a repair that was done using none standard > parts. > > Looks like what you've done is a very good temporary repair, may > even last a long time ;~} > > Jay Darst > 85PT40 6V92 with all new exhaust and drivers side exhaust manifold > in 2005. > Springfield, IL > --- In WanderlodgeForum@yahoogroups.com, "Bob Benner" > wrote: > > > > Here's the page to see what I eventually did to fix the problem. > > > > http://bennersfarm.com/BF%20Home/Bluebird/bus%20dilemma.html > > > > None of the parts were available so I had to follow the guru Rube > Goldberg and concoct a > > fix as I'm leaving Wednesday for the north. > > > > On the page at the top is a picture of what I believe is the tach > sender. It is loose, not > > being held by anything and is easily slipped out of its hole. > Attached at the bottom of the > > unit is a gear that is also loose and easily lifted from the > hole. > > > > Do any of you know if this is a Detroit part or aftermarket or > where I can find it. Also are > > there any 'do not's', I should know about when I go to change it? > > > > Bob > > 86PT40 > > on sticky LI > > > exhaust problem revisited - Stephen Birtles - 07-16-2006 03:21 for inside exhaust parts and flex and oassorted stuf for 8v92 you might want to take a look at MCI parts Also there is a flex listed on ebay Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > IS THIS CONNECTION AFTER THE TURBO? > > When you said that you noticed more and more black smoke, that would > indicate that the turbo was not forcing a good volume of air into > the engine, therefore the extremely rich mixture(black smoke). Black > smoke is indicative of the exhaust pipe leaking before the turbo, > causing reduced turbo boost, which causes reduced engine air, which > results in too rich a fuel/air mixture, which shows itself as black > smoke. > > Jay Darst > > > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Looks like that should work... > > > > Apparently the ring slides on the pipe? > > > > None of the flanges are removable on my exhaust pipes. I don't see > > how that would have ever held? > > > > my connections consisted of the following: > > > > 1.)cast iron exhaust manifold to steel exhaust pipe connected via > > a "V" clamp with no removable flange or ring. > > > > 2.)steel exhaust pipe connected to cast iron turbo inlet "T" via > > a "V" clamp with no removable flange or ring. > > > > Both ends of the steel pipe are flanged to accomodate the "V" > clamp. > > Both cast iron pieces have a nice flange cast into them. > > > > So, I don't understand the removable flange or ring. It would > appear > > to me that there has been a repair that was done using none > standard > > parts. > > > > Looks like what you've done is a very good temporary repair, may > > even last a long time ;~} > > > > Jay Darst > > 85PT40 6V92 with all new exhaust and drivers side exhaust manifold > > in 2005. > > Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com, "Bob Benner" > > wrote: > > > > > > Here's the page to see what I eventually did to fix the problem. > > > > > > http://bennersfarm.com/BF%20Home/Bluebird/bus%20dilemma.html > > > > > > None of the parts were available so I had to follow the guru > Rube > > Goldberg and concoct a > > > fix as I'm leaving Wednesday for the north. > > > > > > On the page at the top is a picture of what I believe is the > tach > > sender. It is loose, not > > > being held by anything and is easily slipped out of its hole. > > Attached at the bottom of the > > > unit is a gear that is also loose and easily lifted from the > > hole. > > > > > > Do any of you know if this is a Detroit part or aftermarket or > > where I can find it. Also are > > > there any 'do not's', I should know about when I go to change it? > > > > > > Bob > > > 86PT40 > > > on sticky LI > > > > > > |
