Rediline...Why Should I Want To Make Mine Work? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rediline...Why Should I Want To Make Mine Work? (/showthread.php?tid=2972) |
Rediline...Why Should I Want To Make Mine Work? - erniecarpet@... - 07-16-2006 11:02 David, I gave my Rediline to Joe Losh. Freed up the space to put my charger. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Rediline...Why Should I Want To Make Mine Work? - dthollis1961 - 07-16-2006 11:30 The Rediline on the 84 FC has 2 bad solenoids, other than that it works fine. I can't think of a reason to make it functional. The icemaker is out of service and I don't have plans to repair it. Does anyone here use their Rediline and for what? I understand they can fetch some money on Ebay. Should I just save up for an inverter? Thanks, David Hollis 84 FC35 Springfield,IL Rediline...Why Should I Want To Make Mine Work? - Jeff Miller - 07-16-2006 14:27 I am not fond of the rediline, but for powering the icemaker/freezer underway, if it works, it is a decent unit. Its startup current is hard on alternators unless you have good batteries, that is the only down-side. An inverter is far superior as it can power small loads fairly efficiently. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" wrote: > > The Rediline on the 84 FC has 2 bad solenoids, other than that it > works fine. I can't think of a reason to make it functional. The > icemaker is out of service and I don't have plans to repair it. > > Does anyone here use their Rediline and for what? I understand they > can fetch some money on Ebay. Should I just save up for an inverter? > > Thanks, > David Hollis 84 FC35 Springfield,IL > |
