Spring vs: air suspension - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Spring vs: air suspension (/showthread.php?tid=2973) |
Spring vs: air suspension - gcyeaw - 07-16-2006 15:01 Can anyone out there give me an evauation of the diference between the spring and air suspension ride? I am looking at some early 1980 FC units and they have the spring suspension. Tey also have the 210 HP NA engine, which may not be enough to tow a toad. Any comments would be appreciated.. Spring vs: air suspension - John Stiles - 07-17-2006 22:21 Please sign your post so that we know who we are responding to. I have a 1980 with air suspension and in my biased opinion it rides as well as and better than most other manufacturers new models. The 1980 (as well as later FC's) utilize 2 bags per wheel whereas many other manufacturers use 1. As far as pulling a toad, I have thousands of miles pulling a 2001 Jeep Wrangler Sahara and have also pulled a Jeep Cherokee with no problem. Granted the 210 hp can be a bit slow in the hills but the idea is relaxation and enjoying the ride/scenery and at 8-9 mpg I don't mind being a bit slow in the hills. Keep in mind also that the the old FC's are rated to carry more than most other (ie plastic) manufacturers are rated to tow. Hope this helps, John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > Can anyone out there give me an evauation of the diference between > the spring and air suspension ride? I am looking at some early 1980 FC > units and they have the spring suspension. Tey also have the 210 HP NA > engine, which may not be enough to tow a toad. > > Any comments would be appreciated.. > Spring vs: air suspension - warren madson - 07-18-2006 07:02 I have an 80 with springs. having never riden in one with air bags can't compare but I think the ride is good for the 15+ tons. my wife has a bad back so got her a air ride truck seat and its fine with her now. I know that I have never had to replace an air bag or the leaveling things they talk about. as for power, or lack of, go slow enjoy life. it's the only one you got, and you can't see it all anyway. Have had no problem with a toad don't even know it's back there, have to turn on the camera to check' 8.6 mpg with gen run aint bad, for a house! 8035fcsb with springs warren madson calmar iowa --- John Stiles > Please sign your post so that we know who we are > responding to. I > have a 1980 with air suspension and in my biased > opinion it rides as > well as and better than most other manufacturers new > models. The 1980 > (as well as later FC's) utilize 2 bags per wheel > whereas many other > manufacturers use 1. As far as pulling a toad, I > have thousands of > miles pulling a 2001 Jeep Wrangler Sahara and have > also pulled a Jeep > Cherokee with no problem. Granted the 210 hp can be > a bit slow in the > hills but the idea is relaxation and enjoying the > ride/scenery and at > 8-9 mpg I don't mind being a bit slow in the hills. > Keep in mind also > that the the old FC's are rated to carry more than > most other (ie > plastic) manufacturers are rated to tow. > > Hope this helps, > > John Stiles > 1980 33FC > "My Navion" > > > > --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > > > > Can anyone out there give me an evauation of the > diference between > > the spring and air suspension ride? I am looking > at some early 1980 > FC > > units and they have the spring suspension. Tey > also have the 210 HP > NA > > engine, which may not be enough to tow a toad. > > > > Any comments would be appreciated.. > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com Spring vs: air suspension - dthollis1961 - 07-18-2006 08:52 I owned a 78 FC33 with leaf springs and now own an 84 FC35 with air ride. The ride is better in the 84, but the handling in the 78 was more precise and the ride wasn't objectional at all. The difference to me with the 84 compared to the 78 is the combination of ALL the upgrades: air ride, turbo, retarder, larger diesel generator and higher gearing which lowers engine speed and noise. David Hollis 84 FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > Can anyone out there give me an evauation of the diference between > the spring and air suspension ride? I am looking at some early 1980 FC > units and they have the spring suspension. Tey also have the 210 HP NA > engine, which may not be enough to tow a toad. > > Any comments would be appreciated.. > Spring vs: air suspension - Gardner Yeaw - 07-18-2006 13:04 Sorry, I forgot to put my name in the post. Is there a way to have it automaticaly placed at the end on every post. I was looking at my profile but couldn't figure it out. Thanks for the replies. I do like the idea of the retarder and other upgrades, particularly the turbo in '85, but a real well kept older unit is also very attractive. Thanks Gardner Wanabe --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > Can anyone out there give me an evauation of the diference between > the spring and air suspension ride? I am looking at some early 1980 FC > units and they have the spring suspension. Tey also have the 210 HP NA > engine, which may not be enough to tow a toad. > > Any comments would be appreciated.. > Spring vs: air suspension - Gardner Yeaw - 07-18-2006 13:29 Sorry for not signing, I wasn't thinking. How can I set up an automatic tag at the end of a post? I tried looking in my profile but only found how to add a picture, not a tag line? Gardner Wanabe --- In WanderlodgeForum@yahoogroups.com, warren madson > > I have an 80 with springs. having never riden in one > with air bags can't compare but I think the ride is > good for the 15+ tons. my wife has a bad back so got > her a air ride truck seat and its fine with her now. I > know that I have never had to replace an air bag or > the leaveling things they talk about. as for power, or > lack of, go slow enjoy life. it's the only one you > got, and you can't see it all anyway. Have had no > problem with a toad don't even know it's back there, > have to turn on the camera to check' 8.6 mpg with gen > run aint bad, for a house! > 8035fcsb with springs > warren madson > calmar iowa > > --- John Stiles > > > Please sign your post so that we know who we are > > responding to. I > > have a 1980 with air suspension and in my biased > > opinion it rides as > > well as and better than most other manufacturers new > > models. The 1980 > > (as well as later FC's) utilize 2 bags per wheel > > whereas many other > > manufacturers use 1. As far as pulling a toad, I > > have thousands of > > miles pulling a 2001 Jeep Wrangler Sahara and have > > also pulled a Jeep > > Cherokee with no problem. Granted the 210 hp can be > > a bit slow in the > > hills but the idea is relaxation and enjoying the > > ride/scenery and at > > 8-9 mpg I don't mind being a bit slow in the hills. > > Keep in mind also > > that the the old FC's are rated to carry more than > > most other (ie > > plastic) manufacturers are rated to tow. > > > > Hope this helps, > > > > John Stiles > > 1980 33FC > > "My Navion" > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > > > > > > > Can anyone out there give me an evauation of the > > diference between > > > the spring and air suspension ride? I am looking > > at some early 1980 > > FC > > > units and they have the spring suspension. Tey > > also have the 210 HP > > NA > > > engine, which may not be enough to tow a toad. > > > > > > Any comments would be appreciated.. > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > Spring vs: air suspension - Curt Sprenger - 07-19-2006 02:15 Gardner, Automatic Signature...Depends on the email product you are using. It works something like this...Create your Signature in a word document. Save this in My Documents\Signature (or somewhere). In your Mail Box click on Edit. Then click on Mail & Newsgroups Account Settings (or something close to this wording). Click on Attach This Signature. Click Choose (Browse). Click on My Documents\Signature. Click OK. Test this by creating an email, the automatic signature should show up. Some products, at the Account Settings, allow you to create an automatic signature. Hope this helps. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gardner Yeaw wrote: > Sorry, I forgot to put my name in the post. Is there a way to have it > automaticaly placed at the end on every post. I was looking at my > profile but couldn't figure it out. > > Thanks for the replies. I do like the idea of the retarder and > other upgrades, particularly the turbo in '85, but a real well kept > older unit is also very attractive. > > Thanks > Gardner > Wanabe > > roups Terms of Use <http://docs.yahoo.com/info/terms/> | Unsubscribe > > New Message Search > > Find the message you want faster. Visit your group to try out the > improved message search. > > Share feedback on the new changes to Groups > <http://us.lrd.yahoo.com/_ylc=X3oDMTJuY2Izbm00BF9TAzk3MzU5NzE0BF9wAzIEZ3JwSWQDMT\ Q4MTU1MTgEZ3Jwc3BJZAMxNjAwMTI2MTg1BHNlYwNuY21vZARzbGsDZmRiY2sEc3RpbWUDMTE1MzI4Nj\ cyNQ--;_ylg=1/SIG=11im36rmb/**http%3a//surveylink.yahoo.com/wix/p1412899.aspx> > > Recent Activity > > * > 8 > New Members > <http://groups.yahoo.com/group/WanderlodgeForum/members;_ylc=X3oDMTJnaTZ2NjRxBF9\ TAzk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTYwMDEyNjE4NQRzZWMDdnRsBHNsawN2bWJ\ ycwRzdGltZQMxMTUzMjg2NzI1> > * > 2 > New Photos > <http://groups.yahoo.com/group/WanderlodgeForum/spnew;_ylc=X3oDMTJnODJmaGM4BF9TA\ zk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTYwMDEyNjE4NQRzZWMDdnRsBHNsawN2cGhvd\ ARzdGltZQMxMTUzMjg2NzI1> > * > 1 > New Links > <http://groups.yahoo.com/group/WanderlodgeForum/links;_ylc=X3oDMTJoc3I1bGtwBF9TA\ zk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTYwMDEyNjE4NQRzZWMDdnRsBHNsawN2bGlua\ 3MEc3RpbWUDMTE1MzI4NjcyNQ--> > > Visit Your Group > <http://groups.yahoo.com/group/WanderlodgeForum;_ylc=X3oDMTJmcWR2Z2E3BF9TAzk3MzU\ 5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTYwMDEyNjE4NQRzZWMDdnRsBHNsawN2Z2hwBHN0aW1\ lAzExNTMyODY3MjU-> > > . > > |
