propane pressure - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: propane pressure (/showthread.php?tid=3008) |
propane pressure - Bob & Carol Howald` - 07-22-2006 00:59 Wow, it's been hot here in the midwest, Electricity at our house was off for 26 hours. We put a lot of our food in the coach refer and also ran the gen set to power other's. It seems that the refer's been running a lot cooler on electric than gas. I took the burner out and cleaned it, also soaked the jet and blew it out but it seem's to be the same. I made a manometer and checked the water column pressure and could only get 10 inch's on it. The book calls for 11 inch's. My question is , will the 1 inch difference be enough to change the flame ( effect the btu rating) enough not to get max cooling? Thanks.....Bob 93pt Illinois....Getting back to normal after all the storms!!! |
