Plumbing winterizing question - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Plumbing winterizing question (/showthread.php?tid=3058) |
Plumbing winterizing question - davidkerryedwards - 07-30-2006 01:44 Some of you may recall I posted a question about a problem I was having with no water thru the hot water lines. I figured out that problem after talking to Tom Warner. The valve labeled 'Hot Water Drain' in my coach is actually a hot water tank/line fill valve. If that valve is not depressed with the cable control, water does not enter the hot water lines. Once depressed, everything worked fine. But I have a conceptual question about winterizing. When the air is blown into the system via the electric valve, how are the hot water lines blown out since the air has (?) to pass thru the hot water heater before pressurizing the hot water lines? It seems the hot water heater would absorb a lot of pressurized air before there was enough oomph to blow out all the hot water lines. Kerry 82 FC35 Denver Plumbing winterizing question - Tom Warner - 07-30-2006 02:24 Kerry your fill valve is on the outside where the water connection is. It appears that you are not following the instructions on the drop down door where your air fill and winterizing valves are. You have to have both valves in the normal position if you are going to fill your tank . Tom Warner Vernon Center,NY 1985 Bluebird At 09:44 AM 7/30/2006, you wrote: >Some of you may recall I posted a question about a problem I was >having with no water thru the hot water lines. I figured out that >problem after talking to Tom Warner. The valve labeled 'Hot Water >Drain' in my coach is actually a hot water tank/line fill valve. If >that valve is not depressed with the cable control, water does not >enter the hot water lines. Once depressed, everything worked fine. >But I have a conceptual question about winterizing. When the air is >blown into the system via the electric valve, how are the hot water >lines blown out since the air has (?) to pass thru the hot water >heater before pressurizing the hot water lines? It seems the hot >water heater would absorb a lot of pressurized air before there was >enough oomph to blow out all the hot water lines. > >Kerry >82 FC35 >Denver > > [Non-text portions of this message have been removed] Plumbing winterizing question - davidkerryedwards - 07-30-2006 12:24 Yes, the water tank fill valve is outside, but inside is a spring loaded valve built into the water lines which allows the hot water heater tank to fill. It is labeled as a drain valve behind the drop down door inside but the hot water heater tank will only fill if the long arm compresses that valve. If that valve is not compressed there is no water in the hot water lines either from the water tank or from city pressure. Kerry --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Kerry your fill valve is on the outside where the water connection > is. It appears that you are not following the instructions on the > drop down door where your air fill and winterizing valves are. You > have to have both valves in the normal position if you are going to > fill your tank . > > Tom Warner > Vernon Center,NY > 1985 Bluebird > > At 09:44 AM 7/30/2006, you wrote: > > >Some of you may recall I posted a question about a problem I was > >having with no water thru the hot water lines. I figured out that > >problem after talking to Tom Warner. The valve labeled 'Hot Water > >Drain' in my coach is actually a hot water tank/line fill valve. If > >that valve is not depressed with the cable control, water does not > >enter the hot water lines. Once depressed, everything worked fine. > >But I have a conceptual question about winterizing. When the air is > >blown into the system via the electric valve, how are the hot water > >lines blown out since the air has (?) to pass thru the hot water > >heater before pressurizing the hot water lines? It seems the hot > >water heater would absorb a lot of pressurized air before there was > >enough oomph to blow out all the hot water lines. > > > >Kerry > >82 FC35 > >Denver > > > > > > > [Non-text portions of this message have been removed] > |
