Snake bit - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Snake bit (/showthread.php?tid=3091) |
Snake bit - Bill Rowe - 08-04-2006 12:02 Hello All, I have come to the conclusion that I'm snake bit. Every thing I try to do turn's out harder than expected. I can not find a way to get a cable from the closet across from the bath to the back up camera. The old cable must have been run underneath the coach. There appears to be no access from the end of the long lighting fixture to the end cavity. The floor plan is the same as the late FCs. How hard is it to take that light down so I can drill a hole either in the cabinet over the bed or into the end cavity? I know some of you guys have run new cables to the back up camera, am I the only one that can't figure it out? Bill Conway AR 90sp36 Snake bit - Eric Johnson - 08-05-2006 00:29 Hello Bill, I have an 84FC so I'm not sure I can help you. For what's it worth, I installed a rear camera and monitor in my coach by running the cable from front to back on the driver side. Toughest part of the job was fishing the cable behind the side bath area but running cable behind the overhead bins was a snap. I avoided the passenger side of the coach because I was concerned about how to get past the light fixture area above the side door. Regards, Eric 84FC35SB --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" > > > Hello All, > I have come to the conclusion that I'm snake bit. Every thing I try to > do turn's out harder than expected. I can not find a way to get a cable > from the closet across from the bath to the back up camera. The old > cable must have been run underneath the coach. There appears to be no > access from the end of the long lighting fixture to the end cavity. > The floor plan is the same as the late FCs. > > How hard is it to take that light down so I can drill a hole either in > the cabinet over the bed or into the end cavity? I know some of you > guys have run new cables to the back up camera, am I the only one that > can't > figure it out? > > Bill Conway AR 90sp36 > Snake bit - Howard O. Truitt - 08-05-2006 01:43 Bill, Maybe you could run a pc. of thin wall conduit thru this section and then run the wire thru it. Howard ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Saturday, August 05, 2006 8:29 AM Subject: [WanderlodgeForum] Re: Snake bit Hello Bill, I have an 84FC so I'm not sure I can help you. For what's it worth, I installed a rear camera and monitor in my coach by running the cable from front to back on the driver side. Toughest part of the job was fishing the cable behind the side bath area but running cable behind the overhead bins was a snap. I avoided the passenger side of the coach because I was concerned about how to get past the light fixture area above the side door. Regards, Eric 84FC35SB --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" > > > Hello All, > I have come to the conclusion that I'm snake bit. Every thing I try to > do turn's out harder than expected. I can not find a way to get a cable > from the closet across from the bath to the back up camera. The old > cable must have been run underneath the coach. There appears to be no > access from the end of the long lighting fixture to the end cavity. > The floor plan is the same as the late FCs. > > How hard is it to take that light down so I can drill a hole either in > the cabinet over the bed or into the end cavity? I know some of you > guys have run new cables to the back up camera, am I the only one that > can't > figure it out? > > Bill Conway AR 90sp36 > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.7/409 - Release Date: 8/4/2006 [Non-text portions of this message have been removed] Snake bit - Bill Rowe - 08-05-2006 03:55 Hello Eric, On my sp36 on the drivers side there is no access to the cable run from the refrig. all the way to the back about 18 or so feet. So I decided to run it on pass. side. I ran a new tv cable a couple of years ago but I went down to the floor at the closet because I needed to cross under the bed to get to the driver side of coach to go out. Bill 90sp36 --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > > Hello Bill, > I have an 84FC so I'm not sure I can help you. For what's it worth, I installed a rear camera > and monitor in my coach by running the cable from front to back on the driver side. > Toughest part of the job was fishing the cable behind the side bath area but running cable > behind the overhead bins was a snap. I avoided the passenger side of the coach because I > was concerned about how to get past the light fixture area above the side door. > Regards, Eric > 84FC35SB Snake bit - Bill Rowe - 08-05-2006 03:59 Howard, I may have to do that. First though I will see if I can use the Zip Dee hook and catch the fish tape from the cam. access hole in the back. Bill 90sp36 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Bill, > Maybe you could run a pc. of thin wall conduit thru this section and then run the wire thru it. > Howard Snake bit - Bill Rowe - 08-12-2006 13:48 Well I'm still snake bit. I was finishing up the new glass in the hole for rear view camera and needed water to clean it. No pump it will not come on. I must have messed up a wire while trying to fish the wire thru the wall. My question is does anyone have a wiring diagram for the rear 12 volt power center for 89 90 sp 36? The wire would be impossible to get to so I may need to run a new wire. Bill Conway AR 90sp36 |
