Air Compressor Filter - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Compressor Filter (/showthread.php?tid=3096) |
Air Compressor Filter - Scott Forman - 08-05-2006 02:54 Hello all, Went to replace the air compressor air filter this morning. Opened up the little filter box and there is nothing in there, just an empty little chamber. What am I missing? Did someone take out a dirty filter and never replace it? Does NAPA have them? Anyone know a part number since I have nothing to match against? Scott Forman 82 FC35RB Memphis Air Compressor Filter - davidkerryedwards - 08-05-2006 04:12 Scott: I recall reading that older model GM's (late 60's and 70's) had a little filter at the end of the PCV valve line in the engine air filter. This GM filter will fit in the air compressor on the 3208 according to what I read. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Hello all, > > Went to replace the air compressor air filter this morning. Opened up > the little filter box and there is nothing in there, just an empty > little chamber. > > What am I missing? Did someone take out a dirty filter and never > replace it? Does NAPA have them? Anyone know a part number since I > have nothing to match against? > > Scott Forman > 82 FC35RB > Memphis > Air Compressor Filter - pattypape - 08-05-2006 05:15 Scott, Our foam filter was also missing, I think the compressor ate it. hopefully little pieces are in the air dryer, Change the air dryer filter also. Take off the whole filter housing , two bolts, take it to Napa and replace it with a new housing and a paper throw away filter, It is about two inches round and it looks like a mini carburator filter. Then it will be really easy to check and replace, from the doghouse. About $20.00. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Hello all, > > Went to replace the air compressor air filter this morning. Opened up > the little filter box and there is nothing in there, just an empty > little chamber. > > What am I missing? Did someone take out a dirty filter and never > replace it? Does NAPA have them? Anyone know a part number since I > have nothing to match against? > > Scott Forman > 82 FC35RB > Memphis > Air Compressor Filter - Scott Forman - 08-05-2006 06:11 Got one of those small round assemblies, much easier to deal with. Scott --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Scott, > > Our foam filter was also missing, I think the compressor ate it. > hopefully little pieces are in the air dryer, Change the air dryer > filter also. > Take off the whole filter housing , two bolts, > take it to Napa and replace it with a new housing and a paper throw > away filter, It is about two inches round and it looks like a mini > carburator filter. Then it will be really easy to check and > replace, from the doghouse. > About $20.00. > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> > wrote: > > > > Hello all, > > > > Went to replace the air compressor air filter this morning. > Opened > up > > the little filter box and there is nothing in there, just an empty > > little chamber. > > > > What am I missing? Did someone take out a dirty filter and never > > replace it? Does NAPA have them? Anyone know a part number since > I > > have nothing to match against? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > Air Compressor Filter - Dan Darst - 08-05-2006 09:24 That would be a Wix 42714. dandarst86fc35rbhuntleyil. >From: "Scott Forman" <sforman@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Air Compressor Filter >Date: Sat, 05 Aug 2006 14:54:49 -0000 > >Hello all, > >Went to replace the air compressor air filter this morning. Opened up >the little filter box and there is nothing in there, just an empty >little chamber. > >What am I missing? Did someone take out a dirty filter and never >replace it? Does NAPA have them? Anyone know a part number since I >have nothing to match against? > >Scott Forman >82 FC35RB >Memphis > > > Air Compressor Filter - Tom Warner - 08-05-2006 09:32 Bill on some of the FC models (for instance my former 1982 FC35) there is not enough room to install the throw away filter housing and filter. I bought the proper foam filters from NAPA. Tom Warner Vernon Center,NY 1985 PT 40 At 01:15 PM 8/5/2006, you wrote: >Scott, > >Our foam filter was also missing, I think the compressor ate it. >hopefully little pieces are in the air dryer, Change the air dryer >filter also. >Take off the whole filter housing , two bolts, >take it to Napa and replace it with a new housing and a paper throw >away filter, It is about two inches round and it looks like a mini >carburator filter. Then it will be really easy to check and >replace, from the doghouse. >About $20.00. > >Bill 88 FC Michigan > >--- In > >"Scott Forman" ><sforman@...> >wrote: > > > > Hello all, > > > > Went to replace the air compressor air filter this morning. >Opened >up > > the little filter box and there is nothing in there, just an empty > > little chamber. > > > > What am I missing? Did someone take out a dirty filter and never > > replace it? Does NAPA have them? Anyone know a part number since >I > > have nothing to match against? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > |
