Transmission Dipstick Problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Transmission Dipstick Problem (/showthread.php?tid=3124) |
Transmission Dipstick Problem - Eric Johnson - 08-09-2006 06:34 I've had a series of problems with the Allison MT643 tranmission dipstick as follows: Noticed about 5 yrs ago that cap and stopper were loose on the dipstick. Had a mechanic spot weld the cap in place. Noticed about 3 yrs ago that the handle had fallen off above the spot weld so I ordered a new dipstick assembly from Blue Bird and installed it. Today I pulled on the dipstick to check transmission level and found the dipstick had broken off just below the cap and stopper assembly. I was able to fish the rest of the dipstick out. I could see some metal dust around the top of the dipstick tube. I think the problem is vibration related. I talked with Bennie Collier about the problem and it was new to him. Has anybody had a similar problem? Know of any fixes? Eric in San Antonio 84FC35SBWL2 Transmission Dipstick Problem - erniecarpet@... - 08-09-2006 08:23 Eric- just me wondering here- if you have metal shavings and have gone through 2 dipsticks, would a change in transmission fluid and filter be in order? Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Transmission Dipstick Problem - davidkerryedwards - 08-09-2006 10:16 I thought the cap/stopper were supposed to be loose. It seems that all GM cars I've ever owned had a loose cap/stopper. I'd speculate that the weld caused the failure. Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > I've had a series of problems with the Allison MT643 tranmission dipstick as follows: > > Noticed about 5 yrs ago that cap and stopper were loose on the dipstick. Had a mechanic > spot weld the cap in place. > > Noticed about 3 yrs ago that the handle had fallen off above the spot weld so I ordered a new > dipstick assembly from Blue Bird and installed it. > > Today I pulled on the dipstick to check transmission level and found the dipstick had broken > off just below the cap and stopper assembly. I was able to fish the rest of the dipstick out. I > could see some metal dust around the top of the dipstick tube. > > I think the problem is vibration related. I talked with Bennie Collier about the problem and it > was new to him. Has anybody had a similar problem? Know of any fixes? > > Eric in San Antonio > 84FC35SBWL2 > Transmission Dipstick Problem - Eric Johnson - 08-09-2006 11:41 Hi Kerry, I agree with you on the weld as responsible for the first dipstick break. I am really puzzled by the latest break of the 3 year old dipstick supplied by Blue Bird. It didn't have any welding done on it. I have another dipstick on order but doesn't feel like I'm fixing the root cause. Thanks, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" wrote: > > I thought the cap/stopper were supposed to be loose. It seems that > all GM cars I've ever owned had a loose cap/stopper. I'd speculate > that the weld caused the failure. > > Kerry > 82 FC 35 > Denver- > > -- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > > > I've had a series of problems with the Allison MT643 tranmission > dipstick as follows: > > > > Noticed about 5 yrs ago that cap and stopper were loose on the > dipstick. Had a mechanic > > spot weld the cap in place. > > > > Noticed about 3 yrs ago that the handle had fallen off above the > spot weld so I ordered a new > > dipstick assembly from Blue Bird and installed it. > > > > Today I pulled on the dipstick to check transmission level and found > the dipstick had broken > > off just below the cap and stopper assembly. I was able to fish the > rest of the dipstick out. I > > could see some metal dust around the top of the dipstick tube. > > > > I think the problem is vibration related. I talked with Bennie > Collier about the problem and it > > was new to him. Has anybody had a similar problem? Know of any fixes? > > > > Eric in San Antonio > > 84FC35SBWL2 > > > Transmission Dipstick Problem - Eric Johnson - 08-09-2006 15:07 Hi Ernie, For sure. I'm in the process of changing out belts, hoses, etc. When I get coach back together will head to Allison shop for transmission service. Thanks, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Eric- just me wondering here- if you have metal shavings and have gone > through 2 dipsticks, would a change in transmission fluid and filter be in order? > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > Transmission Dipstick Problem - Gregory OConnor - 08-09-2006 16:51 Eric, one other part that fatiques often in the 3208 is the oil pickup in the sump. I was surprised when Cat had the part instock. The clerk said it was a high failure item. The truck had 300,000+ miles whin it failed on me but record from the previous owner showed it was repalced twice prior when the pan was dropped. Gregory 94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > Hi Kerry, > > I agree with you on the weld as responsible for the first dipstick break. I am really puzzled > by the latest break of the 3 year old dipstick supplied by Blue Bird. It didn't have any > welding done on it. I have another dipstick on order but doesn't feel like I'm fixing the > root cause. > > Thanks, Eric > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > wrote: > > > > I thought the cap/stopper were supposed to be loose. It seems that > > all GM cars I've ever owned had a loose cap/stopper. I'd speculate > > that the weld caused the failure. > > > > Kerry > > 82 FC 35 > > Denver- > > > > -- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > > > > > I've had a series of problems with the Allison MT643 tranmission > > dipstick as follows: > > > > > > Noticed about 5 yrs ago that cap and stopper were loose on the > > dipstick. Had a mechanic > > > spot weld the cap in place. > > > > > > Noticed about 3 yrs ago that the handle had fallen off above the > > spot weld so I ordered a new > > > dipstick assembly from Blue Bird and installed it. > > > > > > Today I pulled on the dipstick to check transmission level and found > > the dipstick had broken > > > off just below the cap and stopper assembly. I was able to fish the > > rest of the dipstick out. I > > > could see some metal dust around the top of the dipstick tube. > > > > > > I think the problem is vibration related. I talked with Bennie > > Collier about the problem and it > > > was new to him. Has anybody had a similar problem? Know of any fixes? > > > > > > Eric in San Antonio > > > 84FC35SBWL2 > > > > > > Transmission Dipstick Problem - Howard O. Truitt - 08-09-2006 22:48 Eric, It's my understanding that there is a magnet in the bottom pan of the Allison Transmission to catch any metal in the fluid. If this is correct just draining the fluid would not flush out the metal shavings attached to the magnet. Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] Transmission Dipstick Problem - Eric Johnson - 08-10-2006 00:56 Thanks Howard, My plan is to head to the nearest Allison authorized shop to let a professional take care of the transmission service. I'll tell him about the metal from the dipstick and see what he wants to do. Regards, Eric 84FCS35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Eric, > It's my understanding that there is a magnet in the bottom pan of the Allison Transmission to catch any metal in the fluid. If this is correct just draining the fluid would not flush out the metal shavings attached to the magnet. > Howard Truitt > Camilla, Ga. > 86 PT40 > > [Non-text portions of this message have been removed] > |
