Fuel Pump Leaks/Return lines/ FYI... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fuel Pump Leaks/Return lines/ FYI... (/showthread.php?tid=3130) |
Fuel Pump Leaks/Return lines/ FYI... - Tom Seitz - 08-10-2006 15:07 Hi All. I have been chasing a fuel leak on my 90 SP36. The lip seal on the Shut down shaft. Yesterday I finally figured out why. After shut down the fuel pressure at the pump would spike and blow the seal because my fuel return line was completely stopped up. Not flowing at all. There is a return line that comes off the to of the pump down the side of the cat to a 90 degree fitting mounted beside the fuel filter. (this line was good) then out the other side of the 90 fitting there is about a 2' rubber hose that runs over to the frame rail and ties into the copper line that runs all the way to the tank. This rubber hose and the 90 were stopped. When I went to get a hose made the shop said that the hose was not FUEL RATED. That it was regular hyd. hose and over time the fuel will break down the inside of the hose. I dont know if this hose is original or not. But by looking at the out side it looks 16 years old and the inside was completely broken down. could not even blow air through with shop compressor. Anybody with this same set up may want to take the time to check or replace it with a fuel rated line. Cheap insurance and save alot of headaches. Tom 90 SP36 Alpharetta GA Fuel Pump Leaks/Return lines/ FYI... - davidkerryedwards - 08-10-2006 15:21 Thanks for that tip. I've had a leak in the incoming fuel line that increases when the engine shuts off. I had the line replaced and it held for a few thousand miles then started leaking again. I'll check the fuel return line. I think mine is much shorter than 2'. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > > Hi All. I have been chasing a fuel leak on my 90 SP36. The lip seal > on > the Shut down shaft. Yesterday I finally figured out why. After shut > down the fuel pressure at the pump would spike and blow the seal > because my fuel return line was completely stopped up. Not flowing at > all. There is a return line that comes off the to of the pump down > the > side of the cat to a 90 degree fitting mounted beside the fuel > filter. > (this line was good) then out the other side of the 90 fitting there > is about a 2' rubber hose that runs over to the frame rail and ties > into the copper line that runs all the way to the tank. This rubber > hose and the 90 were stopped. When I went to get a hose made the shop > said that the hose was not FUEL RATED. That it was regular hyd. hose > and over time the fuel will break down the inside of the hose. I dont > know if this hose is original or not. But by looking at the out side > it looks 16 years old and the inside was completely broken down. > could > not even blow air through with shop compressor. Anybody with this > same > set up may want to take the time to check or replace it with a fuel > rated line. Cheap insurance and save alot of headaches. Tom 90 SP36 > Alpharetta GA > |
