Radome type antenna replacement. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Radome type antenna replacement. (/showthread.php?tid=3133) |
Radome type antenna replacement. - williamcharrison - 08-11-2006 01:48 Has anyone on the forum replaced their radome type tv antenna and if so, where do you get a replacement? I took the cover off mine to check why rotating the antenna did not affect reception and found that the foam center in the disc was broken and the coax cable had disintegrated. The cover is also cracked and about to fall apart. Chuck harrison Akron, Ohio 90SP36 Radome type antenna replacement. - Richard Hayden - 08-11-2006 04:05 Chuck, There is someone on this forum that has access to those and I'm sure they will chime in or someone else will give you the details. So, be patient. I wish I could remember who it was. If you want to browse the posts maybe you will find it mentioned. Good Luck Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 11, 2006 6:48 AM Subject: [WanderlodgeForum] Radome type antenna replacement. Has anyone on the forum replaced their radome type tv antenna and if so, where do you get a replacement? I took the cover off mine to check why rotating the antenna did not affect reception and found that the foam center in the disc was broken and the coax cable had disintegrated. The cover is also cracked and about to fall apart. Chuck harrison Akron, Ohio 90SP36 [Non-text portions of this message have been removed] Radome type antenna replacement. - pattypape - 08-11-2006 05:02 I think Stephen Birtles has this part. http://www.capeinnovation.com/ Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Has anyone on the forum replaced their radome type tv antenna and > if so, where do you get a replacement? > I took the cover off mine to check why rotating the antenna did not > affect reception and found that the foam center in the disc was > broken and the coax cable had disintegrated. The cover is also > cracked and about to fall apart. > > Chuck harrison > Akron, Ohio > 90SP36 > Radome type antenna replacement. - Eric Johnson - 08-11-2006 06:15 Hi Chuck, I recently replaced my old one with a new antenna from "Antenna Craft" that I got from Stephen Bertles. You can contact him at info@.... The new one works much better than the old. Only gripe I have on the unit was that one of the terminal screws was galled beyond use and the factory was no help. Otherwise fine. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" wrote: > > Has anyone on the forum replaced their radome type tv antenna and > if so, where do you get a replacement? > I took the cover off mine to check why rotating the antenna did not > affect reception and found that the foam center in the disc was > broken and the coax cable had disintegrated. The cover is also > cracked and about to fall apart. > > Chuck harrison > Akron, Ohio > 90SP36 > |
