One more tip on fuel blow back--was--Re: Re: Fuel blow back - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: One more tip on fuel blow back--was--Re: Re: Fuel blow back (/showthread.php?tid=3150) |
One more tip on fuel blow back--was--Re: Re: Fuel blow back - Jo-Ski - 10-22-2006 02:16 Hi, all-- Meant to respond to this thread earlier. . .The FuelKleen Splash Absorbing Collar sounds great, and I'm sure we'll be purchasing one, but here's one more tip. Most of you probably know this already (and, apologies if someone covered it already), but we sure didn't until we recently refueled for the first time at a popular truck-stop along I-5 (noticed the cheapest diesel prices in the whole area): if you're using what's known as a high-velocity pump (not necessarily common at regular gas stations, but used at many of the truck-stops 'cuz otherwise, it would take forever to fill huge truck tanks), you can avoid fuel blow back by using the lowest setting/notch on the pump handle. In this case, Stew only avoided being covered in diesel by virtue of the fact that he had inserted the pump handle (with it set to the highest notch setting--unknowingly to us, the highest truck-velocity setting) into the coach, and then had stepped back to the pump to start everything up--resulting in diesel blowing back all over the place. At least Stew was out of range! A guy at the next pump explained what was going on and said to set the pump handle at the lowest notch. Again, if you're relatively new to RVing as we are, how do ya necessarily know these things? Oh, well, live and learn! Jo-Ski (and Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA -------------------------------------------------------------------------------- ----- Original Message ----- From: TJ Hannink To: WanderlodgeForum@yahoogroups.com Sent: Saturday, October 14, 2006 7:43 PM Subject: Re: [WanderlodgeForum] Re: Fuel blow back FuelKleen Splash Absorbing Collar Manufacturer - CENTEK INDUSTRIES MFG Park # 8-FK-1-R West Marine Number 3683166 Price: $6.99 each "Splash" was the search term that worked, all the obvious ones - fuel, fill, spill, etc.... couldn't locate it. Good luck, TJ Hannink Goldibox - 1987 Vanagon Camper, Wolfsburg Edition 1981 Bluebird Wanderlodge, FC-33SB Full-timing in Paradis, Louisiana http://groups.yahoo.com/group/wolfsburg_campers http://groups.yahoo.com/group/FC_wanderlodge ----- Original Message ---- From: Dan Weaver To: WanderlodgeForum@yahoogroups.com Sent: Saturday, October 14, 2006 8:41:05 PM Subject: [WanderlodgeForum] Re: Fuel blow back Do you have a link to this product? Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. I did several searches at west marine and did not find it. Dan --- In WanderlodgeForum@ yahoogroups. com, Wallace Craig > > As with most of you, I have been drenched in diesel for years while fueling BB. I finally found a solution!!! Eureka!!! > > West Marine, and probably other boating stores sells a collar which fits around the spout of the nozzle that ABSOLUTELY blocks blow back. I did it today for the first time; NOT A DROP SPILLED. > > This is used primarily aroung marinas because of fed. regs against spilling any fuel in water. It was less than $10 and you just put it in a baggie and keep it in the fuel door or wherever winds your clock. > > This is better than rags or towels because it has crystals that capture any overflow. > > Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
