1988 pt40 Power Problems - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1988 pt40 Power Problems (/showthread.php?tid=3169) |
1988 pt40 Power Problems - Robert & Teri Rahn - 02-09-2007 15:04 We just tried to see if anything different would happen if we started up the generator, but same thing. Still no power to most of the coach and no lights or readings on upper dash pannel. Thanks for your help! Robert Rahn 1988 pt40 Kalispell, MT 1988 pt40 Power Problems - Leroy Eckert - 02-09-2007 15:20 Was shore power off when you ran the generator? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:04 PM Subject: [WanderlodgeForum] 1988 pt40 Power Problems We just tried to see if anything different would happen if we started up the generator, but same thing. Still no power to most of the coach and no lights or readings on upper dash pannel. Thanks for your help! Robert Rahn 1988 pt40 Kalispell, MT [Non-text portions of this message have been removed] 1988 pt40 Power Problems - Robert & Teri Rahn - 02-09-2007 15:27 No, but I switched the dial to generator power. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Was shore power off when you ran the generator? > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Robert & Teri Rahn > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 9:04 PM > Subject: [WanderlodgeForum] 1988 pt40 Power Problems > > > We just tried to see if anything different would happen if we started > up the generator, but same thing. Still no power to most of the coach > and no lights or readings on upper dash pannel. Thanks for your help! > > Robert Rahn > 1988 pt40 > Kalispell, MT > > > > > > [Non-text portions of this message have been removed] > 1988 pt40 Power Problems - Leroy Eckert - 02-09-2007 15:42 I do not know which on takes precedence and I don't have my prints at home. Turn off the park power, start the generator and if you get two legs through the transfer switch then I would be suspicious of the park power side of the transfer switch. If you do not get 2 legs then I would do what Curt suggested and check the main breaker integrity for leg 1. I'm just trying to come up the line from the park power to the breaker box from memory. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:27 PM Subject: [WanderlodgeForum] Re: 1988 pt40 Power Problems No, but I switched the dial to generator power. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Was shore power off when you ran the generator? > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Robert & Teri Rahn > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 9:04 PM > Subject: [WanderlodgeForum] 1988 pt40 Power Problems > > > We just tried to see if anything different would happen if we started > up the generator, but same thing. Still no power to most of the coach > and no lights or readings on upper dash pannel. Thanks for your help! > > Robert Rahn > 1988 pt40 > Kalispell, MT > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] 1988 pt40 Power Problems - Leroy Eckert - 02-09-2007 15:46 Gez, I do not have a dial. Missed that. Does the dial manually change the power source in your coach from shore power to generator power? If so, I would head to the breaker panel. Leroy Eckert 1990 WB-40"smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:27 PM Subject: [WanderlodgeForum] Re: 1988 pt40 Power Problems No, but I switched the dial to generator power. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Was shore power off when you ran the generator? > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Robert & Teri Rahn > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 9:04 PM > Subject: [WanderlodgeForum] 1988 pt40 Power Problems > > > We just tried to see if anything different would happen if we started > up the generator, but same thing. Still no power to most of the coach > and no lights or readings on upper dash pannel. Thanks for your help! > > Robert Rahn > 1988 pt40 > Kalispell, MT > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] 1988 pt40 Power Problems - Tom Warner - 02-09-2007 16:00 Hmmm.. First check to see if you have both legs at the gally panel where each leg has a green light and a voltmeter. Then check on the front overhead voltmeters for each leg and see if you have it there. If not check both sides of the 50amp breakers to see if you have power there. tom warner vernon center,ny 1985 PT 40 At 10:42 PM 2/9/2007, you wrote: >I do not know which on takes precedence and I don't have my prints >at home. Turn off the park power, start the generator and if you >get two legs through the transfer switch then I would be suspicious >of the park power side of the transfer switch. If you do not get 2 >legs then I would do what Curt suggested and check the main breaker >integrity for leg 1. I'm just trying to come up the line from the >park power to the breaker box from memory. > >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Niceville, FL > > > > ----- Original Message ----- > From: Robert & Teri Rahn > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 9:27 PM > Subject: [WanderlodgeForum] Re: 1988 pt40 Power Problems > > > No, but I switched the dial to generator power. > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > Was shore power off when you ran the generator? > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > > > ----- Original Message ----- > > From: Robert & Teri Rahn > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 09, 2007 9:04 PM > > Subject: [WanderlodgeForum] 1988 pt40 Power Problems > > > > > > We just tried to see if anything different would happen if we > started > > up the generator, but same thing. Still no power to most of the > coach > > and no lights or readings on upper dash pannel. Thanks for your > help! > > > > Robert Rahn > > 1988 pt40 > > Kalispell, MT > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > |
