Battery tie solenoid - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Battery tie solenoid (/showthread.php?tid=3213) |
Battery tie solenoid - Gardner Yeaw - 08-18-2006 03:29 I have read the previous entries on this subject, but have one question. Should the solenoid(s) be energised when the gen. starter switch is pressed, or is there another method of energizing them? In my 78F#33 I disconnected all the batteries, then reconnect the generator battery. I hear the solenoid energize when the cable is connected. This doesn't seem right as it will put a constant drain on the battery. I still need to do some investigation, testing, to determine if the power is fed back to the coach batteries, but I thought I would start here, wiht a question. Thanks Gardner 78FC33 Battery tie solenoid - Scott Forman - 08-18-2006 04:01 The solenoid is energized when the auxillary battery switch on the dash is pushed. Unless that switch is activated, it should be open. This prevents the coach batts from drawing down the gen batt, especially handy when dry-camping. By isolating the gen batt, even if you run your coach batts down too far, you will always have juice to start the generator and get the batt chargers going. Disonnect your coach batts and see if you have voltage on the coach side of the solenoid. If so, replace it. There is also a modification you might want to install if you don't have it. BB came out with a "jumper wire" across that solenoid with a circuit breaker and a diode. This allowed current to flow from the coach charging system (alternator or batt chargers) to the gen batt to keep it charged, but the doide prevented current from flowing from the gen batt back to the coach. Provides a little extra insurance that your gen batt will stay charged. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I have read the previous entries on this subject, but have one > question. Should the solenoid(s) be energised when the gen. starter > switch is pressed, or is there another method of energizing them? > > In my 78F#33 I disconnected all the batteries, then reconnect the > generator battery. I hear the solenoid energize when the cable is > connected. This doesn't seem right as it will put a constant drain on > the battery. I still need to do some investigation, testing, to > determine if the power is fed back to the coach batteries, but I > thought I would start here, wiht a question. > > Thanks > Gardner > 78FC33 > Battery tie solenoid - Gardner Yeaw - 08-19-2006 13:55 Scott, Thank you. I will check out the wiring tomorrow. It will take me some time to learn the systems on this coach, they are very sophisticated so it's more than just a basic cause/effect approach. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > The solenoid is energized when the auxillary battery switch on the dash > is pushed. Unless that switch is activated, it should be open. This > prevents the coach batts from drawing down the gen batt, especially > handy when dry-camping. By isolating the gen batt, even if you run > your coach batts down too far, you will always have juice to start the > generator and get the batt chargers going. Disonnect your coach batts > and see if you have voltage on the coach side of the solenoid. If so, > replace it. > > There is also a modification you might want to install if you don't > have it. BB came out with a "jumper wire" across that solenoid with a > circuit breaker and a diode. This allowed current to flow from the > coach charging system (alternator or batt chargers) to the gen batt to > keep it charged, but the doide prevented current from flowing from the > gen batt back to the coach. Provides a little extra insurance that > your gen batt will stay charged. > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > I have read the previous entries on this subject, but have one > > question. Should the solenoid(s) be energised when the gen. starter > > switch is pressed, or is there another method of energizing them? > > > > In my 78F#33 I disconnected all the batteries, then reconnect the > > generator battery. I hear the solenoid energize when the cable is > > connected. This doesn't seem right as it will put a constant drain on > > the battery. I still need to do some investigation, testing, to > > determine if the power is fed back to the coach batteries, but I > > thought I would start here, wiht a question. > > > > Thanks > > Gardner > > 78FC33 > > > Battery tie solenoid - Scott Forman - 08-20-2006 02:18 Don't feel bad, I have had my coach a year and a half and I learn something new about it every week. Scott --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Scott, > Thank you. I will check out the wiring tomorrow. It will take me > some time to learn the systems on this coach, they are very > sophisticated so it's more than just a basic cause/effect approach. > > Gardner > 78FC33 > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> wrote: > > > > The solenoid is energized when the auxillary battery switch on the > dash > > is pushed. Unless that switch is activated, it should be open. > This > > prevents the coach batts from drawing down the gen batt, > especially > > handy when dry-camping. By isolating the gen batt, even if you > run > > your coach batts down too far, you will always have juice to start > the > > generator and get the batt chargers going. Disonnect your coach > batts > > and see if you have voltage on the coach side of the solenoid. If > so, > > replace it. > > > > There is also a modification you might want to install if you > don't > > have it. BB came out with a "jumper wire" across that solenoid > with a > > circuit breaker and a diode. This allowed current to flow from > the > > coach charging system (alternator or batt chargers) to the gen > batt to > > keep it charged, but the doide prevented current from flowing from > the > > gen batt back to the coach. Provides a little extra insurance > that > > your gen batt will stay charged. > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > wrote: > > > > > > I have read the previous entries on this subject, but have one > > > question. Should the solenoid(s) be energised when the gen. > starter > > > switch is pressed, or is there another method of energizing them? > > > > > > In my 78F#33 I disconnected all the batteries, then reconnect > the > > > generator battery. I hear the solenoid energize when the cable > is > > > connected. This doesn't seem right as it will put a constant > drain on > > > the battery. I still need to do some investigation, testing, to > > > determine if the power is fed back to the coach batteries, but I > > > thought I would start here, wiht a question. > > > > > > Thanks > > > Gardner > > > 78FC33 > > > > > > |
