Where are my circuit breakers? 87FC35 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Where are my circuit breakers? 87FC35 (/showthread.php?tid=3229) |
Where are my circuit breakers? 87FC35 - krminyl@... - 08-21-2006 00:14 I think you've been chasing the gremlin. Turn on your emergency flashers, and see if those side lights light up. Typically those are turn indicator lights, not clearance lights. Good luck....hope you didn't spend too much time and effort trying to get those things to light up as clearance lights! Been there...done that! Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] Where are my circuit breakers? 87FC35 - Alan - 08-21-2006 01:18 Well, I'm still learning where everything is on my new Bird. This is my latest problem (that I need to get fixed so I can get Texas tags). My side running lights are inop. (Not the ones at the top of the coach, the lower ones) There are two on each side. I think I found the problem. It was a short on one of the lights. I corrected the problem, but they still won't come on. So, here are my questions. 1. Figure 10-2 in my manual (Lower Front Load Center) says that circuit breaker #10, wire #1 is for my "Parking and tail lights". My front and rear tail lights ARE working, but if those side lights aren't that, then I don't know what they are called. Any thoughts? 2. And even if that was the circuit breaker, I can't find it. I've taken my grill off and taken off both access panels behind the grill. On the drivers side I see only maybe two of the small (maybe 1" square) black boxes that I understand are the circuit breakers. My manual shows there to be 25 of them in the lower front load center. ...So I must not be looking in the right place..?? Thanks!! Alan Johnson New 87FC35 owner Where are my circuit breakers? 87FC35 - Stephen Birtles - 08-21-2006 01:28 Have you tried hooking a power source to the individual light direct to see if the light is still faulty if not the case you may have to chase the wire to look for a break or run new wire to the offending lights also check the grounds Stephen 77fc35 trying to find another coolant leak --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Well, I'm still learning where everything is on my new Bird. This > is my latest problem (that I need to get fixed so I can get Texas > tags). > > My side running lights are inop. (Not the ones at the top of the > coach, the lower ones) There are two on each side. I think I found > the problem. It was a short on one of the lights. I corrected the > problem, but they still won't come on. So, here are my questions. > > 1. Figure 10-2 in my manual (Lower Front Load Center) says that > circuit breaker #10, wire #1 is for my "Parking and tail lights". > My front and rear tail lights ARE working, but if those side lights > aren't that, then I don't know what they are called. Any thoughts? > > 2. And even if that was the circuit breaker, I can't find it. I've > taken my grill off and taken off both access panels behind the > grill. On the drivers side I see only maybe two of the small (maybe > 1" square) black boxes that I understand are the circuit breakers. > My manual shows there to be 25 of them in the lower front load > center. ...So I must not be looking in the right place..?? > > Thanks!! > Alan Johnson > New 87FC35 owner > Where are my circuit breakers? 87FC35 - pattypape - 08-21-2006 01:51 Hi Alan, Good to see you digging into the repairs. The two black 1" square items, I think are the Bosh relays. There are many in the Bird. The two behind the front headlight panel forward of the brake pedal are for the round Driving lights in the Bumper, turned on with the headlight highbeam switch and the driving light toggle switch on the transmission button consol. I also think the load center you may be refering to is the left front load center, located in the overhead above and right of the dinette table. I am a little confused with your discription. The white cornering lights located on the front , left and right bay doors light with the turn signals , I believe the headlights need to also be turned ON. hope the helps. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Alan" > > Well, I'm still learning where everything is on my new Bird. This > is my latest problem (that I need to get fixed so I can get Texas > tags). > > My side running lights are inop. (Not the ones at the top of the > coach, the lower ones) There are two on each side. I think I found > the problem. It was a short on one of the lights. I corrected the > problem, but they still won't come on. So, here are my questions. > > 1. Figure 10-2 in my manual (Lower Front Load Center) says that > circuit breaker #10, wire #1 is for my "Parking and tail lights". > My front and rear tail lights ARE working, but if those side lights > aren't that, then I don't know what they are called. Any thoughts? > > 2. And even if that was the circuit breaker, I can't find it. I've > taken my grill off and taken off both access panels behind the > grill. On the drivers side I see only maybe two of the small (maybe > 1" square) black boxes that I understand are the circuit breakers. > My manual shows there to be 25 of them in the lower front load > center. ...So I must not be looking in the right place..?? > > Thanks!! > Alan Johnson > New 87FC35 owner > Where are my circuit breakers? 87FC35 - Leroy Eckert - 08-21-2006 02:25 Alan: Those two amber lights on my WB40 are turn signal indicators. See if they work with the hazard and turn signals. Leroy Eckert 1990WB40 Niceville, FL ----- Original Message ----- From: Alan To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 8:18 AM Subject: [WanderlodgeForum] Where are my circuit breakers? 87FC35 Well, I'm still learning where everything is on my new Bird. This is my latest problem (that I need to get fixed so I can get Texas tags). My side running lights are inop. (Not the ones at the top of the coach, the lower ones) There are two on each side. I think I found the problem. It was a short on one of the lights. I corrected the problem, but they still won't come on. So, here are my questions. 1. Figure 10-2 in my manual (Lower Front Load Center) says that circuit breaker #10, wire #1 is for my "Parking and tail lights". My front and rear tail lights ARE working, but if those side lights aren't that, then I don't know what they are called. Any thoughts? 2. And even if that was the circuit breaker, I can't find it. I've taken my grill off and taken off both access panels behind the grill. On the drivers side I see only maybe two of the small (maybe 1" square) black boxes that I understand are the circuit breakers. My manual shows there to be 25 of them in the lower front load center. ...So I must not be looking in the right place..?? Thanks!! Alan Johnson New 87FC35 owner [Non-text portions of this message have been removed] Where are my circuit breakers? 87FC35 - Scott - 08-21-2006 04:18 Hey there Alan, congrats on the new to you coach. I have an 86FC35RB. When talking about lighting it can be somewhat confusing as most things with older BB. I think Leroy is correct. The amber lights on the side of the coach are turn signals. The only running or marker lights are amber on front cap, red on the back cap and red/amber along the goat rail. You should be able to turn those on with a switch on the dash "MARKER LIGHTS" mine do not come on automatically. There are some "stick on" amber markers but they do not have lights. Now for some confusing stuff..There is a solenoid in the upper front compartment above the driver, this solenoid works the turn signals in the rear, along with the heavy duty switch under the dash. Plus when working on the lights, the tail/turn lights in the rear go through a load center, mine are located in the upper rear load center passenger side, above a bed in our case. A good upgrade is to add a relay to push more power to dim lights both headlights and rear lights. Also some have removed the lenses and put chrome finish on the inside of the lamp assembly itself. Either paint or the easiest in my opinion is to us some hvac tape. The thin aluminum tape that hvac folks use, it is adhesive on the back, some have even cut pie pans to put in there. Best of luck ScottB 86FC35 "RUBY" 4SALE Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, "Alan" > > Well, I'm still learning where everything is on my new Bird. This > is my latest problem (that I need to get fixed so I can get Texas > tags). > > My side running lights are inop. (Not the ones at the top of the > coach, the lower ones) There are two on each side. I think I found > the problem. It was a short on one of the lights. I corrected the > problem, but they still won't come on. So, here are my questions. > > 1. Figure 10-2 in my manual (Lower Front Load Center) says that > circuit breaker #10, wire #1 is for my "Parking and tail lights". > My front and rear tail lights ARE working, but if those side lights > aren't that, then I don't know what they are called. Any thoughts? > > 2. And even if that was the circuit breaker, I can't find it. I've > taken my grill off and taken off both access panels behind the > grill. On the drivers side I see only maybe two of the small (maybe > 1" square) black boxes that I understand are the circuit breakers. > My manual shows there to be 25 of them in the lower front load > center. ...So I must not be looking in the right place..?? > > Thanks!! > Alan Johnson > New 87FC35 owner > Where are my circuit breakers? 87FC35 - Howard O. Truitt - 08-21-2006 05:56 Alan, Try this it worked for me. Unscrew the mounting screws from the coach coat with dialectric grease and reattach. The ground is often corroded this fixed the problem with my running lights and patio lights also. Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] Where are my circuit breakers? 87FC35 - Jeff Miller - 08-21-2006 12:51 As others have mentioned, they are turn-signals. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Alan" > > Well, I'm still learning where everything is on my new Bird. This > is my latest problem (that I need to get fixed so I can get Texas > tags). > > My side running lights are inop. (Not the ones at the top of the > coach, the lower ones) There are two on each side. I think I found > the problem. It was a short on one of the lights. I corrected the > problem, but they still won't come on. So, here are my questions. > > 1. Figure 10-2 in my manual (Lower Front Load Center) says that > circuit breaker #10, wire #1 is for my "Parking and tail lights". > My front and rear tail lights ARE working, but if those side lights > aren't that, then I don't know what they are called. Any thoughts? > > 2. And even if that was the circuit breaker, I can't find it. I've > taken my grill off and taken off both access panels behind the > grill. On the drivers side I see only maybe two of the small (maybe > 1" square) black boxes that I understand are the circuit breakers. > My manual shows there to be 25 of them in the lower front load > center. ...So I must not be looking in the right place..?? > > Thanks!! > Alan Johnson > New 87FC35 owner > |
