SMI Silent Partner Brake Control Questions - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: SMI Silent Partner Brake Control Questions (/showthread.php?tid=3284) |
SMI Silent Partner Brake Control Questions - Curt Sprenger - 08-26-2006 07:34 Before I screw something up I have some questions. I'm installing the SMI Silent Partner brake control in the Bronco/Bird. All the Bronco stuff is installed. To check out the towed install, the instructions say the gauge should read about 12" vacuum, no more than 15". Is there a gauge in the control box? Do I need to install a gauge in the vacuum line? The instruction also say to adjust the vacuum in 1/4 turn increments...location of adjustment screw? Those who have installed one of these units themselves, is there a gauge inside of the box along with the adjustment screw? Remove the bottom plate or remove the cover? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. SMI Silent Partner Brake Control Questions - Scott Williams - 08-26-2006 10:00 Hi Curt, On mine, the gauge is on the box (with the pump in it) that goes in the car adjustment is on box also. Guage shows on top of box, adjustment on end. I put mine under the front seat Mine is the Silent partner model and 3-4 years old. Help? Scott Williams 04 Essex http://www.rvsafetycandle.com ================ --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Before I screw something up I have some questions. I'm installing the > SMI Silent Partner brake control in the Bronco/Bird. All the Bronco > stuff is installed. > > To check out the towed install, the instructions say the gauge should > read about 12" vacuum, no more than 15". Is there a gauge in the control > box? Do I need to install a gauge in the vacuum line? > > The instruction also say to adjust the vacuum in 1/4 turn > increments...location of adjustment screw? > > Those who have installed one of these units themselves, is there a gauge > inside of the box along with the adjustment screw? Remove the bottom > plate or remove the cover? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
