Sporlan,water fill/location - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sporlan,water fill/location (/showthread.php?tid=332) |
Sporlan,water fill/location - dspithaler@... - 04-19-2005 10:44 Tom My sporlan valve is curbside bedroom behind that carpeted base by the rear chassis heater. I had a leak in my water pipes where it came up through the floor & that is when I saw mine. It would be a bear to replace. Don 89 SP 36' Butler, PA Just got home from a 6000 mile trip [Non-text portions of this message have been removed] Sporlan,water fill/location - Tom Seitz - 04-19-2005 14:30 I have heard and read alot about the sporlan valves and water fill valve.Are they one in the same? It takes a little bit for my water fill to stop filling when I flip the switch so i think it needs cleaning.Before I could here it stop filling, and could tell it had a good seal but now it slooooows and then finally stops. Can anyone tell me where this or these valves are located on a 90 SP36? Thanks Tom 90 SP36 Alpharetta GA Sporlan,water fill/location - Jeff Miller - 04-19-2005 14:37 This is one valve as you suspect. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" wrote: > > I have heard and read alot about the sporlan valves and water fill > valve.Are they one in the same? It takes a little bit for my water > fill to stop filling when I flip the switch so i think it needs > cleaning.Before I could here it stop filling, and could tell it had a > good seal but now it slooooows and then finally stops. > Can anyone tell me where this or these valves are located on a 90 > SP36? Thanks Tom 90 SP36 Alpharetta GA |
