1982PT40 propane leak protocal - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1982PT40 propane leak protocal (/showthread.php?tid=3360) |
1982PT40 propane leak protocal - Jerry Legris - 09-05-2006 20:07 Tonight my wife smelled an odor and turned on the sensor below the refrig. It started beeping and after a few more test and her smelling around, we feel it is the propane. Or could it be the hydrogen from the tubes behind the refrig we just discovered recently has some leak. All the electrical is shut down and main switch is Off. Windows open for circulation. She couldn't find any instructions to follow to resolve this. Are there propane companies that can be called to come out and search for the leak. Is it dangerous...not really identified as such in the manuel. I left a message at Bluebird. I am about 250 miles from the bus at this point in time, but was there this morning. Jerry Legris 1982PT40 Anaheim/Fresno Jerry Legris, Broker LEGRIS TEAM REAL ESTATE Serving Orange County http://www.LegrisTeam.com email: Jerry@... 888-441-8751 toll free 714-635-9319 Fax --------------------------------- Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business. [Non-text portions of this message have been removed] 1982PT40 propane leak protocal - Curt Sprenger - 09-06-2006 03:47 Jerry Call Suburban Propane in Fresno 559 486-2770, 2874 S CHERRY AVE. I took our previous Bird to the Suburban Propane store in Placentia, CA. They checked the propane system for leaks. When will the coach come to Anaheim? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jerry Legris wrote: > Tonight my wife smelled an odor and turned on the sensor below the > refrig. It started beeping and after a few more test and her smelling > around, we feel it is the propane. Or could it be the hydrogen from > the tubes behind the refrig we just discovered recently has some leak. > All the electrical is shut down and main switch is Off. Windows open > for circulation. > She couldn't find any instructions to follow to resolve this. Are > there propane companies that can be called to come out and search for > the leak. Is it dangerous...not really identified as such in the > manuel. I left a message at Bluebird. I am about 250 miles from the > bus at this point in time, but was there this morning. > Jerry Legris > 1982PT40 Anaheim/Fresno > > Jerry Legris, Broker > LEGRIS TEAM REAL ESTATE > Serving Orange County > http://www.LegrisTeam.com email: Jerry@... > > 888-441-8751 toll free 714-635-9319 Fax > > > --------------------------------- > Get your own web address for just $1.99/1st yr. We'll help. Yahoo! > Small Business. > > [Non-text portions of this message have been removed] > > 1982PT40 propane leak protocal - Ralph L. Fullenwider - 09-06-2006 05:25 Hi Jerry: Any LP leak is a potential explosive danger. The leak from the refer would smell more like amonia than ethyl mercapita (lp aditive) The leak could be coming form the valve on the back of the refer or from the secondary regulator there. Switch off the sensor under the refer. Then close the main valve at the tank proper. A mobile RV tech, one who has an electronic lp sniffer can locate the leak, but more importantly he will be able to do a pressure drop test to make sure, in fact, you have a leak. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:07 AM 9/6/2006 -0700, you wrote: >Tonight my wife smelled an odor and turned on the sensor below the refrig. >It started beeping and after a few more test and her smelling around, we >feel it is the propane. Or could it be the hydrogen from the tubes behind >the refrig we just discovered recently has some leak. All the electrical >is shut down and main switch is Off. Windows open for circulation. > She couldn't find any instructions to follow to resolve this. Are there > propane companies that can be called to come out and search for the leak. > Is it dangerous...not really identified as such in the manuel. I left a > message at Bluebird. I am about 250 miles from the bus at this point in > time, but was there this morning. > Jerry Legris > 1982PT40 Anaheim/Fresno > > > Jerry Legris, Broker >LEGRIS TEAM REAL ESTATE >Serving Orange County >http://www.LegrisTeam.com email: Jerry@... >888-441-8751 toll free 714-635-9319 Fax > 1982PT40 propane leak protocal - davidkerryedwards - 09-06-2006 05:47 Since nobody else has answered, I'll take a stab at it. Propane is heavier than air so it will sink to the low spot, probably flowing out the steps at the door if it can. Opening the windows will keep fresh air in the coach but it won't allow the propane to escape. you can purchase a gas sniffer which will locate a leak. They aren't cheap--probably around $200 (I bought mine on ebay) but it might be cheaper than a service call. Propane companies could probably recommend a service technician. An RV shop could also deal with the problem. I believe most RV frig's run on ammonia so a frig leak should smell like ammonia. Did you shut off the manual valve at the propane tank? kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Jerry Legris > > Tonight my wife smelled an odor and turned on the sensor below the refrig. It started beeping and after a few more test and her smelling around, we feel it is the propane. Or could it be the hydrogen from the tubes behind the refrig we just discovered recently has some leak. All the electrical is shut down and main switch is Off. Windows open for circulation. > She couldn't find any instructions to follow to resolve this. Are there propane companies that can be called to come out and search for the leak. Is it dangerous...not really identified as such in the manuel. I left a message at Bluebird. I am about 250 miles from the bus at this point in time, but was there this morning. > Jerry Legris > 1982PT40 Anaheim/Fresno > > > Jerry Legris, Broker > LEGRIS TEAM REAL ESTATE > Serving Orange County > http://www.LegrisTeam.com email: Jerry@... > 888-441-8751 toll free 714-635-9319 Fax > > > > --------------------------------- > Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business. > > [Non-text portions of this message have been removed] > 1982PT40 propane leak protocal - Mike Lanning - 09-06-2006 12:10 Find a propane supplier in your area. If you have a Ferrellgas in the area use them. I was an employee with them for years and they are a very responsible company. They will check your system with a sniffer for free. The industry (Propane) does not want any accidents and police themselves well. Mike Curt Sprenger wrote: > Jerry > > Call Suburban Propane in Fresno 559 486-2770, 2874 S CHERRY AVE. > > I took our previous Bird to the Suburban Propane store in Placentia, CA. > They checked the propane system for leaks. > > When will the coach come to Anaheim? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > Jerry Legris wrote: > > > Tonight my wife smelled an odor and turned on the sensor below the > > refrig. It started beeping and after a few more test and her smelling > > around, we feel it is the propane. Or could it be the hydrogen from > > the tubes behind the refrig we just discovered recently has some leak. > > All the electrical is shut down and main switch is Off. Windows open > > for circulation. > > She couldn't find any instructions to follow to resolve this. Are > > there propane companies that can be called to come out and search for > > the leak. Is it dangerous...not really identified as such in the > > manuel. I left a message at Bluebird. I am about 250 miles from the > > bus at this point in time, but was there this morning. > > Jerry Legris > > 1982PT40 Anaheim/Fresno > > > > Jerry Legris, Broker > > LEGRIS TEAM REAL ESTATE > > Serving Orange County > > http://www.LegrisTeam.com email: Jerry@... > > > > > 888-441-8751 toll free 714-635-9319 Fax > > > > > > --------------------------------- > > Get your own web address for just $1.99/1st yr. We'll help. Yahoo! > > Small Business. > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] 1982PT40 propane leak protocal - bus2nut - 09-06-2006 13:49 --- In WanderlodgeForum@yahoogroups.com, Mike Lanning <mlanning@...> wrote: > > Find a propane supplier in your area. If you have a Ferrellgas in the > area use them. I was an employee with them for years and they are a very > responsible company. They will check your system with a sniffer for > free. The industry (Propane) does not want any accidents and police > themselves well. > > Mike > > Curt Sprenger wrote: > > > Jerry > > > > Call Suburban Propane in Fresno 559 486-2770, 2874 S CHERRY AVE. > > > > I took our previous Bird to the Suburban Propane store in Placentia, CA. > > They checked the propane system for leaks. > > > > When will the coach come to Anaheim? > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Jerry Legris wrote: > > > > > Tonight my wife smelled an odor and turned on the sensor below the > > > refrig. It started beeping and after a few more test and her smelling > > > around, we feel it is the propane. Or could it be the hydrogen from > > > the tubes behind the refrig we just discovered recently has some leak. > > > All the electrical is shut down and main switch is Off. Windows open > > > for circulation. > > > She couldn't find any instructions to follow to resolve this. Are > > > there propane companies that can be called to come out and search for > > > the leak. Is it dangerous...not really identified as such in the > > > manuel. I left a message at Bluebird. I am about 250 miles from the > > > bus at this point in time, but was there this morning. > > > Jerry Legris > > > 1982PT40 Anaheim/Fresno > > > > > > Jerry Legris, Broker > > > LEGRIS TEAM REAL ESTATE > > > Serving Orange County > > > http://www.LegrisTeam.com email: Jerry@... > > > > > > > > 888-441-8751 toll free 714-635-9319 Fax > > > > > > > > > --------------------------------- > > > Get your own web address for just $1.99/1st yr. We'll help. Yahoo! > > > Small Business. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > On my propane leak it turned out to be the oven control was on the off position instead of pilot off position.If not BOTH oven and range pilots must be lit. Ken Kalmakoff 82 35SB Richmond B.C. 1982PT40 propane leak protocal - Jerry Legris - 09-07-2006 09:20 Thanks Curt, Mike and Ralph for your responses. Curt especially for the Fresno contact. We had the bird in Anaheim for almost a month, but don't have adquate storage here in the historical district by downtown. Our Frseno house has adequate parking and hookups for now. My wife will be attending the University there so we can finish working out the little bugs by the end of the semister. Hope to get some road time this coming year and some of the ralleys, they sound fun. Jerry Legris 1982 PT40 6V Jerry Legris, Broker LEGRIS TEAM REAL ESTATE Serving Orange County http://www.LegrisTeam.com email: Jerry@... 888-441-8751 toll free 714-635-9319 Fax --------------------------------- Stay in the know. Pulse on the new Yahoo.com. Check it out. [Non-text portions of this message have been removed] |
