Coolant Filter and Conditioner 8V92 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Coolant Filter and Conditioner 8V92 (/showthread.php?tid=3374) |
Coolant Filter and Conditioner 8V92 - Curt Sprenger - 09-08-2006 05:29 Reading through my Detroit Diesel V92 CD (manual), I find a section on Coolant Filter and Conditioner. Did Bluebird install these on our coaches, and where? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Coolant Filter and Conditioner 8V92 - Leroy Eckert - 09-11-2006 06:04 Curt: Just back from tracing coolant lines on my coach. I do not have a coolant filter. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Friday, September 08, 2006 12:29 PM Subject: [WanderlodgeForum] Coolant Filter and Conditioner 8V92 Reading through my Detroit Diesel V92 CD (manual), I find a section on Coolant Filter and Conditioner. Did Bluebird install these on our coaches, and where? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] Coolant Filter and Conditioner 8V92 - Curt Sprenger - 09-11-2006 06:28 Leroy, Thanks. I don't believe BB installed the coolant filter on any Birds, at least not on the 8V92. I let Randy know that I could be interested in adding a unit to our coolant system. He's checking on quantity pricing, etc. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: > Curt: > > Just back from tracing coolant lines on my coach. I do not have a > coolant filter. > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > Coolant Filter and Conditioner 8V92 - Tom Warner - 09-11-2006 10:21 There are different types of coolants being used and not all of them are compatible with some coolant filters. In addition there are different sizes of coolant filters depending on the size of the system and its uses. Installing the incorrect filter can result in a system that is over charged causing the drop out of solids that will harm the water pump and passage ways of the coolant system, or be to small resulting in a cooling system that is not fully protected. Those that are considering adding one may want to read this http://www.baldwinfilter.com/products/coolant.html http://tinyurl.com/h3bjl There are others but Baldwin and Fleet are I believe the most widely used. Tom Warner Vernon Center,NY 1985 PT 40 At 02:28 PM 9/11/2006, you wrote: >Leroy, >Thanks. I don't believe BB installed the coolant filter on any Birds, at >least not on the 8V92. I let Randy know that I could be interested in >adding a unit to our coolant system. He's checking on quantity pricing, etc. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > >Leroy Eckert wrote: > > > Curt: |
