Bendix cruise control on mid 80s PT - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Bendix cruise control on mid 80s PT (/showthread.php?tid=3388) |
Bendix cruise control on mid 80s PT - bluesteelll - 09-09-2006 07:04 Does anyone know where the cruise control off/on switch picks up 12 volts dc? I read only 11.6 volts at the switch and the batteries are on float at 13.6 or so. The cc worked when last I drove the coach, the end of July, and wouldn't set at all yesterday. Dick Hayden - '87 PT 38 - Lake Stevens, WA Bendix cruise control on mid 80s PT - Richard Hayden - 09-09-2006 07:55 Also, where is the speed sensor located? I'm trying to check it's ground. Looks like there are 2 grounds in this system, one at the control module and the other at the speed sensor. Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: bluesteelll To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 09, 2006 12:04 PM Subject: [WanderlodgeForum] Bendix cruise control on mid 80s PT Does anyone know where the cruise control off/on switch picks up 12 volts dc? I read only 11.6 volts at the switch and the batteries are on float at 13.6 or so. The cc worked when last I drove the coach, the end of July, and wouldn't set at all yesterday. Dick Hayden - '87 PT 38 - Lake Stevens, WA [Non-text portions of this message have been removed] Bendix cruise control on mid 80s PT - Bob Lawrence - 09-10-2006 14:38 Hi Dick, Check the right rear double tires on the inside. You should find it there. I had occasional cutouts on my cruise also. Turned out the very thin wires on the speed sensor were almost cut in half. Easy fix. Will be seening you at the Hood Canal rally in Oct. Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > Also, where is the speed sensor located? I'm trying to check it's ground. Looks like there are 2 grounds in this system, one at the control module and the other at the speed sensor. > > Thanx > Dick Hayden - '87 PT 38 - Lake Stevens, WA > |
