Photo of belts? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Photo of belts? (/showthread.php?tid=3453) |
Photo of belts? - johnsunsetridge - 09-17-2006 16:18 Hello Group, My '83FC35 SB threw the fan belt and damaged other belts as well. I've located a diagram in the Files section which does a nice job of describing the belts as they should be arranged on an '84FC35. Does anyone know if this is reliable for use on an '83 model? Mine has the 250HP turbo. The diagram does not indicate whether it was based on the NA or turbo. I doubt it matters but thought I would ask. I had a friend come over to help me replace the belt that ended up shredded on the hiway. He did a nice job of getting things set up so she would run again. However, along the way he pulled all the belts off and I'm not convinced that what I have now is correct. Does anyone have a photo of the belts properly placed on an '83FC35, 250T, SB? It would help a bunch if this was not available. If not, then when I'm finished reworking the belts I'll post a photo for feedback and reference. Thanks, -Jack Photo of belts? - Eric Johnson - 09-18-2006 11:52 Hello Jack, Don't know which belt file you're referring to. I put one in that is based on a our 84FC 3208 TA. Can't say for sure if it applies to your '83 but I'd think they're close. Maybe you're looking at another file entirely, not sure. Happy to answer more belt questions if you have some. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "johnsunsetridge" wrote: > > Hello Group, > > My '83FC35 SB threw the fan belt and damaged other belts as well. > I've located a diagram in the Files section which does a nice job of > describing the belts as they should be arranged on an '84FC35. > > Does anyone know if this is reliable for use on an '83 model? Mine > has the 250HP turbo. The diagram does not indicate whether it was > based on the NA or turbo. I doubt it matters but thought I would ask. > > I had a friend come over to help me replace the belt that ended up > shredded on the hiway. He did a nice job of getting things set up so > she would run again. However, along the way he pulled all the belts > off and I'm not convinced that what I have now is correct. > > Does anyone have a photo of the belts properly placed on an '83FC35, > 250T, SB? It would help a bunch if this was not available. If not, > then when I'm finished reworking the belts I'll post a photo for > feedback and reference. > > Thanks, > > -Jack > Photo of belts? - johngilmoremd@... - 09-18-2006 12:12 Hi Eric, Yes, I believe yours is the one I downloaded from the forum files section. It had 4 or 5 pages and everything was diagrammed. My guess is that there is probably no difference in the belt setup between the '83 and '84 FC's but someone probably knows with certainty. By the way, if you put that file together.... nice job! I think a photo or two would help further but if your diagram applies to my year model then most likely I'm going to be ok. Thanks, -Jack -----Original Message----- From: esjmaj@... To: WanderlodgeForum@yahoogroups.com Sent: Mon, 18 Sep 2006 6:52 PM Subject: [WanderlodgeForum] Re: Photo of belts? Hello Jack, Don't know which belt file you're referring to. I put one in that is based on a our 84FC 3208 TA. Can't say for sure if it applies to your '83 but I'd think they're close. Maybe you're looking at another file entirely, not sure. Happy to answer more belt questions if you have some. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "johnsunsetridge" wrote: > > Hello Group, > > My '83FC35 SB threw the fan belt and damaged other belts as well. > I've located a diagram in the Files section which does a nice job of > describing the belts as they should be arranged on an '84FC35. > > Does anyone know if this is reliable for use on an '83 model? Mine > has the 250HP turbo. The diagram does not indicate whether it was > based on the NA or turbo. I doubt it matters but thought I would ask. > > I had a friend come over to help me replace the belt that ended up > shredded on the hiway. He did a nice job of getting things set up so > she would run again. However, along the way he pulled all the belts > off and I'm not convinced that what I have now is correct. > > Does anyone have a photo of the belts properly placed on an '83FC35, > 250T, SB? It would help a bunch if this was not available. If not, > then when I'm finished reworking the belts I'll post a photo for > feedback and reference. > > Thanks, > > -Jack > Yahoo! Groups Links mailto:WanderlodgeForum-fullfeatured@yahoogroups.com ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] |
