Ceiling panel question - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Ceiling panel question (/showthread.php?tid=3455) |
Ceiling panel question - davidkerryedwards - 09-18-2006 01:40 One my ceiling panels must have been cut a little short at the factory. There is a section of about 18 inches that is not captured by the plastic trim strip that goes betweeen panels. Various fixes had been tried by previous owners including construction adhesive under th panel and caulk on top of it. The ideal solution would be wider trim strip. Does anyone know if a wider strip is available. If not, anyone have any suggestions for stopping it from drooping down in that one section? Kerry 82 FC 35 Denver Ceiling panel question - erniecarpet@... - 09-18-2006 07:45 Kerry- in the flooring business we use a metal track and a snap in vinyl insert. You can get some Chem-rex adhesive and glue the track in place. Wait a day and cut the vinyl insert and snap it in with a hammer. You can find this stuff at a floor covering supply house. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Ceiling panel question - Richard Hayden - 09-18-2006 17:05 Trim strips are available from BB. Call Earl Davis at BB Parts. As I recall they are in 90" lengths and cost about $6 each. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 18, 2006 6:40 AM Subject: [WanderlodgeForum] Ceiling panel question One my ceiling panels must have been cut a little short at the factory. There is a section of about 18 inches that is not captured by the plastic trim strip that goes betweeen panels. Various fixes had been tried by previous owners including construction adhesive under th panel and caulk on top of it. The ideal solution would be wider trim strip. Does anyone know if a wider strip is available. If not, anyone have any suggestions for stopping it from drooping down in that one section? Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] |
