Replacing flooring ??? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Replacing flooring ??? (/showthread.php?tid=347) |
Replacing flooring ??? - erniecarpet@... - 04-21-2005 05:44 Dan, wood and ceramic can be installed in our coach. There is a sound deadening mat that extends about 4 feet from the front cabinet by the drivers area to the rear. That would have to come up. The sides os the coach conceal various wires and it looks better if you leave those carpeted. The floor in our coaches is very strong but a backer board would be advisable under ceramic. Weight, would be on no consequence. Have fun- bring that coach to Jeff or down south and we can fix you up. Ernie 83PT40 in Texas [Non-text portions of this message have been removed] Replacing flooring ??? - erniecarpet@... - 04-21-2005 06:53 Jack- that stuff from Home Depot is the handyman's do it yourself version of commercial carpet tiles. Those tiles are used in extremely heavily traffic areas, such as airports, schools, etc. The intended use of those means that any one that gets soiled or damaged it can be removed and a new one inserted. The edges are pre-trimmed at the factory. If I remember correctly, they have a poly back and are quite heavy. They are also kind of hard to cut- sharp knife is a must. And in the coach application- will never wear out. Ernie-83PT40 in Texas [Non-text portions of this message have been removed] Replacing flooring ??? - erniecarpet@... - 04-21-2005 07:32 it would be extremely difficult as they are made to lay flat with minimal adhesive. Ernie 83PT40 in Texas [Non-text portions of this message have been removed] Replacing flooring ??? - Dan Carr - 04-21-2005 09:32 We are thinking about replacing the carpeting with some type of flooring that will be easier to keep clean with two or more dogs on most trips. We are considering ceramic tile, fake ceramic tile with attached backer board, wood. We have a credenza with fold out dining top rather than the dinette so floor is a little wider in kitchen area. Was wondering what recommendations people have. Also if anyone has done this, what did you do for the channels that are currently carpeted. Thanks, Dan Carr 82PT40 6V92 Columbiana, OH Replacing flooring ??? - Jack & Donna Smith - 04-21-2005 10:43 Ernie: At the Home Depot, we saw a 'LEGATO" type carpet. About 18" squares of carpet, with irregular edges that nest togather. "Very easy to install", said the salesman. "Just line them up on the bare floor, walk on it a few times and vacume, it will look great Of course they will stay put, the special rubberized back eliminates the need for glue"! He sounded very sincere, much like a time share salesman.. Ernie, What is the scoop on this stuff??. Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Dan, wood and ceramic can be installed in our coach. There is a sound > deadening mat that extends about 4 feet from the front cabinet by the drivers area to > the rear. That would have to come up. The sides os the coach conceal various > wires and it looks better if you leave those carpeted. The floor in our > coaches is very strong but a backer board would be advisable under ceramic. Weight, > would be on no consequence. Have fun- bring that coach to Jeff or down south > and we can fix you up. Ernie 83PT40 in Texas > > > [Non-text portions of this message have been removed] Replacing flooring ??? - Tom - 04-21-2005 10:56 Ernie could you use them on the doghouse? Tom 1982 FC35 Vernon Center,NY In the beautiful Mohawk Valley At 06:53 PM 4/21/2005 -0400, you wrote: >Jack- that stuff from Home Depot is the handyman's do it yourself version of >commercial carpet tiles. Those tiles are used in extremely heavily traffic >areas, such as airports, schools, etc. The intended use of those means >that any >one that gets soiled or damaged it can be removed and a new one inserted. The >edges are pre-trimmed at the factory. If I remember correctly, they have a >poly back and are quite heavy. They are also kind of hard to cut- sharp >knife is >a must. And in the coach application- will never wear out. Ernie-83PT40 in >Texas > > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
