Air Regulator - Microphor Toilet - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Regulator - Microphor Toilet (/showthread.php?tid=3473) |
Air Regulator - Microphor Toilet - Curt Sprenger - 09-20-2006 05:18 We have the Microphor Air Operated toilet in our coach. The air pressure regulator exhaust port is leaking, causing the compressor to cycle every 35 minutes. Microphor tells me that the regulator is defective, bad seal(s). Microphor wants $290 for a new regulator, $95 for Microphor to rebuild ours, $65 for a rebuild kit. Clippard wants about $15.00 for what looks to be the same regulator as installed with our toilet. Has anyone replaced this regulator? What brand, part #, cost, purchased where, etc? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Air Regulator - Microphor Toilet - Tom Warner - 09-20-2006 05:58 Curt if I understand how the Microphor air operated toilet works, any regulator that maintains a pressure of 60-65 PSI and has a filter to keep out the debris will work. You can get one that size for less then $20 at harbor freight for instance.http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42035 or if you want just the regulator its less then $10 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90590 Tom At 01:18 PM 9/20/2006, you wrote: >Reply-To: WanderlodgeForum@yahoogroups.com > >We have the Microphor Air Operated toilet in our coach. The air pressure >regulator exhaust port is leaking, causing the compressor to cycle every >35 minutes. Microphor tells me that the regulator is defective, bad >seal(s). > >Microphor wants $290 for a new regulator, $95 for Microphor to rebuild >ours, $65 for a rebuild kit. > >Clippard wants about $15.00 for what looks to be the same regulator as >installed with our toilet. > >Has anyone replaced this regulator? What brand, part #, cost, purchased >where, etc? > >-- >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Air Regulator - Microphor Toilet - g_man1146 - 09-20-2006 06:59 Hi Curt, I had the same problem and replaced the regulator with one that is mounted in the bay next to the aux tank instead of inside the back of the toilet. I also replaced the check valves at the same time. Total cost (MvMaster Carr) about $20.00. They have the plastic lines and push connector fittings too. The regulator is now mounted next to the one for the 120VAC compressor and since both have gauges, it is easy to adjust them so that the 12VDC compressor won't run unless the 120VAC or engine air is absent. Here is a link to the photo. http://www.photosleeve.com/gallery2/d/232032-1/Regulators.jpg Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > We have the Microphor Air Operated toilet in our coach. The air pressure > regulator exhaust port is leaking, causing the compressor to cycle every > 35 minutes. Microphor tells me that the regulator is defective, bad > seal(s). > > Microphor wants $290 for a new regulator, $95 for Microphor to rebuild > ours, $65 for a rebuild kit. > > Clippard wants about $15.00 for what looks to be the same regulator as > installed with our toilet. > > Has anyone replaced this regulator? What brand, part #, cost, purchased > where, etc? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > Air Regulator - Microphor Toilet - Curt Sprenger - 09-20-2006 08:07 Thanks Rich, I have thought about doing the same thing, but first I need to resolve a leak(s) in the 120V compressor service lines, it cycles every 20 to 25 minutes, so I don't use it much, yet. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. g_man1146 wrote: >Hi Curt, > >I had the same problem and replaced the regulator with one that is >mounted in the bay next to the aux tank instead of inside the back >of the toilet. I also replaced the check valves at the same time. >Total cost (MvMaster Carr) about $20.00. They have the plastic lines >and push connector fittings too. The regulator is now mounted next >to the one for the 120VAC compressor and since both have gauges, it >is easy to adjust them so that the 12VDC compressor won't run unless >the 120VAC or engine air is absent. > >Here is a link to the photo. >http://www.photosleeve.com/gallery2/d/232032-1/Regulators.jpg > >Rich D. '99LXi43' CT > > >--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > >>We have the Microphor Air Operated toilet in our coach. The air >> >> >pressure > > >>regulator exhaust port is leaking, causing the compressor to cycle >> >> >every > > >>35 minutes. Microphor tells me that the regulator is defective, >> >> >bad > > >>seal(s). >> >>Microphor wants $290 for a new regulator, $95 for Microphor to >> >> >rebuild > > >>ours, $65 for a rebuild kit. >> >>Clippard wants about $15.00 for what looks to be the same >> >> >regulator as > > >>installed with our toilet. >> >>Has anyone replaced this regulator? What brand, part #, cost, >> >> >purchased > > >>where, etc? >> >>-- >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. >> >> >> > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > Air Regulator - Microphor Toilet - g_man1146 - 09-20-2006 08:59 Curt, One of the leaks in my system was a faulty check valve allowing the 12VDC compressor tank to leak back to the main aux. tank. With that resolved, the little Microphor tank holds for weeks/months at a time. I leave the 12VDC compressor ON all the time and the only time it kicks in is when the 120VAC compressor is left OFF. (Leaks in the aux tank cause the 120VAC one to cycle every 90 minutes or so.) I'm still hunting leaks and sure wood like that to hold overnight so the 120VAC compresor wouldn't start during the night. BB tells me that every 2-4 hours is "normal" but I hate leaks! I've got .pdf's of the before and after air line schematic. The modification was per what Bennis said was their new way of plumbing the Microphor. Email if you want them. I have the Microphor service manual, Thanks. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thanks Rich, > > I have thought about doing the same thing, but first I need to resolve a > leak(s) in the 120V compressor service lines, it cycles every 20 to 25 > minutes, so I don't use it much, yet. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > g_man1146 wrote: > > >Hi Curt, > > > >I had the same problem and replaced the regulator with one that is > >mounted in the bay next to the aux tank instead of inside the back > >of the toilet. I also replaced the check valves at the same time. > >Total cost (MvMaster Carr) about $20.00. They have the plastic lines > >and push connector fittings too. The regulator is now mounted next > >to the one for the 120VAC compressor and since both have gauges, it > >is easy to adjust them so that the 12VDC compressor won't run unless > >the 120VAC or engine air is absent. > > > >Here is a link to the photo. > >http://www.photosleeve.com/gallery2/d/232032-1/Regulators.jpg > > > >Rich D. '99LXi43' CT > > > > > >--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > >>We have the Microphor Air Operated toilet in our coach. The air > >> > >> > >pressure > > > > > >>regulator exhaust port is leaking, causing the compressor to cycle > >> > >> > >every > > > > > >>35 minutes. Microphor tells me that the regulator is defective, > >> > >> > >bad > > > > > >>seal(s). > >> > >>Microphor wants $290 for a new regulator, $95 for Microphor to > >> > >> > >rebuild > > > > > >>ours, $65 for a rebuild kit. > >> > >>Clippard wants about $15.00 for what looks to be the same > >> > >> > >regulator as > > > > > >>installed with our toilet. > >> > >>Has anyone replaced this regulator? What brand, part #, cost, > >> > >> > >purchased > > > > > >>where, etc? > >> > >>-- > >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > >> > >> > >> > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > Air Regulator - Microphor Toilet - Curt Sprenger - 09-20-2006 13:52 Thanks Tom. Your posts are coming through late in the day. You have probable seen my response to my original post. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Tom Warner wrote: >Curt if I understand how the Microphor air operated toilet works, any >regulator that maintains a pressure of 60-65 PSI and has a filter to >keep out the debris will work. You can get one that size for less >then $20 at harbor freight for >instance.http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42035 >or if you want just the regulator its less then >$10 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90590 > >Tom > >At 01:18 PM 9/20/2006, you wrote: > > >>Reply-To: WanderlodgeForum@yahoogroups.com >> >>We have the Microphor Air Operated toilet in our coach. The air pressure >>regulator exhaust port is leaking, causing the compressor to cycle every >>35 minutes. Microphor tells me that the regulator is defective, bad >>seal(s). >> >>Microphor wants $290 for a new regulator, $95 for Microphor to rebuild >>ours, $65 for a rebuild kit. >> >>Clippard wants about $15.00 for what looks to be the same regulator as >>installed with our toilet. >> >>Has anyone replaced this regulator? What brand, part #, cost, purchased >>where, etc? >> >>-- >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. >> >> > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
