Dash EL Inverter Locations - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Dash EL Inverter Locations (/showthread.php?tid=3480) Pages: 1 2 |
Dash EL Inverter Locations - dspithaler@... - 09-21-2006 06:50 Leroy I have two inverters in the over head panel. Mine were bad & I replaced them with two form Stephen. They lit it up a lot brighter. Mine were above the driver side in the load center. My bottom dash is out right now & it is the inverters. I have 5 in the outside right load center. Stephen said two would that one also. Don 89 SP 36' Butler, PA Curt: Thanks, this winter I am going to look again for the inverters that power my overhead panel. I have a Royal conversion and cannot remove the panel, encased with wood. It is the only one that does not work so I think the problem is in the inverters. Cannot find them. I don't know how I going to do it but will try again. There are many stereo, TV and other cables in the overhead cabs. Looks like good Italian spaghetti. So there was only on inverter cube that powered your complete overhead panel? Is there only one panel? I think I have three. Leroy Eckert 1990 WB-40 [Non-text portions of this message have been removed] Dash EL Inverter Locations - Curt Sprenger - 09-21-2006 08:44 Leroy, I found our lower dash EL inverters (2) behind the center console drawers. What fun I had replacing them...PITA comes to mind. The upper dash EL inverter (1) was found behind the upper dash, drivers side, easy R&R. The old were the blue cube. Replacements came from Stephen Birtles, silver, rectangle. -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Dash EL Inverter Locations - erniecarpet@... - 09-21-2006 09:10 Leroy- since you have a Royal conversion, do you have the goat rails? And where did you purchase your coach? I'm just curious. I wonder how many Royal conversions bluebird let out? Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Dash EL Inverter Locations - Leroy Eckert - 09-21-2006 10:05 Curt: Thanks, this winter I am going to look again for the inverters that power my overhead panel. I have a Royal conversion and cannot remove the panel, encased with wood. It is the only one that does not work so I think the problem is in the inverters. Cannot find them. I don't know how I going to do it but will try again. There are many stereo, TV and other cables in the overhead cabs. Looks like good Italian spaghetti. So there was only on inverter cube that powered your complete overhead panel? Is there only one panel? I think I have three. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Thursday, September 21, 2006 3:44 PM Subject: [WanderlodgeForum] Dash EL Inverter Locations Leroy, I found our lower dash EL inverters (2) behind the center console drawers. What fun I had replacing them...PITA comes to mind. The upper dash EL inverter (1) was found behind the upper dash, drivers side, easy R&R. The old were the blue cube. Replacements came from Stephen Birtles, silver, rectangle. -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] Dash EL Inverter Locations - dspithaler@... - 09-21-2006 10:29 Leroy You know that they are blue ??? & about the size of a relay. Don 89 SP 36' Butler, PA Don, I'll look at the left upper load center and the exterior load center again. You cannot believe how much time I have sent looking for those little suckers. Can't find them. Thanks, Leroy Eckert 1990WB-40 Niceville, FL [Non-text portions of this message have been removed] Dash EL Inverter Locations - dspithaler@... - 09-21-2006 10:57 Curt Does your Altimeter panel light up. If it is suppose to mine doesn't. Only the panels on each side. Don 89 SP 36' Butler, PA One upper dash inverter. Multiple panels...a left panel, a right panel, and the Altimeter between the two. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] Dash EL Inverter Locations - Leroy Eckert - 09-21-2006 11:53 Thanks. I'm going to look again this weekend. I do not have an altimeter but have a Bird logo in the center. Pretty cool if I can get the background to work. I spent 7 hours today cleaning and painting everything in the engine bay. Looks great. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 22, 2006 6:13 PM Subject: Re: [WanderlodgeForum] Dash EL Inverter Locations One upper dash inverter. Multiple panels...a left panel, a right panel, and the Altimeter between the two. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt: Thanks, this winter I am going to look again for the inverters that power my overhead panel. I have a Royal conversion and cannot remove the panel, encased with wood. It is the only one that does not work so I think the problem is in the inverters. Cannot find them. I don't know how I going to do it but will try again. There are many stereo, TV and other cables in the overhead cabs. Looks like good Italian spaghetti. > So there was only on inverter cube that powered your complete overhead panel? Is there only one panel? I think I have three. > >Leroy Eckert >1990 WB-40 >Niceville, FL > > > > [Non-text portions of this message have been removed] Dash EL Inverter Locations - Leroy Eckert - 09-21-2006 11:58 Don, I'll look at the left upper load center and the exterior load center again. You cannot believe how much time I have sent looking for those little suckers. Can't find them. Thanks, Leroy Eckert 1990WB-40 Niceville, FL ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 21, 2006 5:50 PM Subject: Re: [WanderlodgeForum] Dash EL Inverter Locations Leroy I have two inverters in the over head panel. Mine were bad & I replaced them with two form Stephen. They lit it up a lot brighter. Mine were above the driver side in the load center. My bottom dash is out right now & it is the inverters. I have 5 in the outside right load center. Stephen said two would that one also. Don 89 SP 36' Butler, PA Curt: Thanks, this winter I am going to look again for the inverters that power my overhead panel. I have a Royal conversion and cannot remove the panel, encased with wood. It is the only one that does not work so I think the problem is in the inverters. Cannot find them. I don't know how I going to do it but will try again. There are many stereo, TV and other cables in the overhead cabs. Looks like good Italian spaghetti. So there was only on inverter cube that powered your complete overhead panel? Is there only one panel? I think I have three. Leroy Eckert 1990 WB-40 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Dash EL Inverter Locations - dspithaler@... - 09-21-2006 20:51 Curt Mine had a loose wire on the right upper side that when I plugged it in every thing worked fine except the small middle section. Don 89 SP 36' Butler, PA Don, Good question. I don't recall if the altimeter would light up. Once I had the upper dash working, it soon failed which could be caused by me doing a lot of work up in there. I have not gotten back to testing that. Will do so soon, maybe. It is on my to-do-list. Curt Sprenger 1987 PT38 [Non-text portions of this message have been removed] Dash EL Inverter Locations - Leroy Eckert - 09-22-2006 00:55 Ernie: Bus does have goat rails. I am the 3rd owner originally titled in Texas. I bought it from a family in Wilmington, NC. They had owned it 8 months, they purchased a Prevost. He is the one who advised me about the conversion. It does not look like a standard BB inside. I don't think there are many. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 21, 2006 8:10 PM Subject: Re: [WanderlodgeForum] Dash EL Inverter Locations Leroy- since you have a Royal conversion, do you have the goat rails? And where did you purchase your coach? I'm just curious. I wonder how many Royal conversions bluebird let out? Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
