Fire hazard (cruise air basement units 85PT40) - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fire hazard (cruise air basement units 85PT40) (/showthread.php?tid=349) |
Fire hazard (cruise air basement units 85PT40) - lcondosta - 04-21-2005 13:38 Trying to get all systems checked out for summer I was checking my A/C units to find that my center (basement) unit inop. These are the same units (cruise airs)that where in my boats so Iam very familier with these units.After removing the control panel cover I found a burnt wire that went to the thermostat.This would not bother me so much but Bluebird did not leave any space behind the A/C control panel and a wood cover which I found chared!!!! .This is a comin problem with these units. (wire is to small for the load)Iam going the increase the space between the control panel to lesson the possibility of fire also would recommend a heaver wire from the thermostat to the compressor.Lee Condosta Wilmington N.C 85PT40 Fire hazard (cruise air basement units 85PT40) - George Lowry - 04-21-2005 14:01 Hi Lee, FWIW, While at the Western Area FMCA rally, I had Dometic check out one of my A/C that had suddenly quit working. He went right to the junction box under the cover and found the wire burned in two. He said it was a very common problem and caused by low voltage. Something to watch for. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD lcondosta wrote: > > Trying to get all systems checked out for summer I was checking my A/C > units to find that my center (basement) unit inop. These are the same > units (cruise airs)that where in my boats so Iam very familier with > these units.After removing the control panel cover I found a burnt > wire that went to the thermostat.This would not bother me so much but > Bluebird did not leave any space behind the A/C control panel and a > wood cover which I found chared!!!! .This is a comin problem with > these units. (wire is to small for the load)Iam going the increase the > space between the control panel to lesson the possibility of fire also > would recommend a heaver wire from the thermostat to the > compressor.Lee Condosta Wilmington N.C 85PT40 > > > > > > > > Yahoo! Groups Links > > > > > > > > > > Fire hazard (cruise air basement units 85PT40) - Jeff Miller - 04-21-2005 16:09 Perhaps adding a relay at the A/C unit would make more sense than running the compressor unit's entire current needs through it. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "lcondosta" wrote: > > Trying to get all systems checked out for summer I was checking my A/C > units to find that my center (basement) unit inop. These are the same > units (cruise airs)that where in my boats so Iam very familier with > these units.After removing the control panel cover I found a burnt > wire that went to the thermostat.This would not bother me so much but > Bluebird did not leave any space behind the A/C control panel and a > wood cover which I found chared!!!! .This is a comin problem with > these units. (wire is to small for the load)Iam going the increase the > space between the control panel to lesson the possibility of fire also > would recommend a heaver wire from the thermostat to the > compressor.Lee Condosta Wilmington N.C 85PT40 |
