Cruise Air - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cruise Air (/showthread.php?tid=3502) |
Cruise Air - erniecarpet@... - 09-24-2006 08:15 Robert, under your couch, there is a return air with 2 tabs on the top that will give you access to the first filter. Way inside is a screen, or filter that needs cleaning also. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Cruise Air - chapelhill2901 - 09-24-2006 09:58 i'm needing instruction on how to change or clean air conditioner filter on the front a/c of a 1985 pt40 w/cruise a/c. thank you robert o.k.c. ok 1985 pt40 Cruise Air - erniecarpet@... - 09-24-2006 10:21 That Cruise Air filter has tabs on the side that make it stay put. You have to either pry it out-- or that filter may have been removed and discarded. Bluebird had many couches. On mine, I have to pull up and then pull toward the center of the coach. Its a pain. When folks ask how many people can your coach sleep? I say 2 and then our 3 pups. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Cruise Air - chapelhill2901 - 09-24-2006 13:17 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Robert, under your couch, there is a return air with 2 tabs on the top that > will give you access to the first filter. Way inside is a screen, or filter > that needs cleaning also. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] ernie, i found the vent under the couch, but i can't see how to remove the filter, is there a screen and a filter? do you remove or clean it. also i have another question about the factory couch i can't seem to pull it out far enough to make it into a bed. how wide is the bed when it is pulled out? (queen)? are there three cushions on the back? thanks,robert 85 pt40i pur a couc okc ok. |
