Where should the pyro probe be located. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Where should the pyro probe be located. (/showthread.php?tid=3506) |
Where should the pyro probe be located. - bluebird3208 - 09-24-2006 15:20 On my 82 FC I converted it over to a 250 HP CAT. I have installed pyro probe locations before and 6" past the turbo. I have read where the probe should be past the turbo so that in the event it breaks off it will not shater the turbo blades. Others say the probe should be located as close to the exhaust mandifold as possible. Where is the pyro pbobe located on a stock 3208 250 HP from the factory? Jim 1982 35 FCRB Yorba Linda, CA Where should the pyro probe be located. - davidkerryedwards - 09-25-2006 01:43 I've read the same debates. Some people think that drilling a hole in the manifold pre- turbo while attached to the engine could put metal shavings into the turbo destorying it. Some people grease the bit or drill the hole with the engine running to shavings get blown out the hole. The best answer I ever read to the question was from an airplane mechanic. He said airplane engines locate them pre-turbo. If there was a significant chance the probes would break off, I don't think airplanes would locate them there. I never heard of one breaking off I don't know the location of the pyro on a 3208T. Mine has an aftermarket turbo and I'm pretty sure it's pre-turbo gvien the temperatures it reads and the fact that I've looked for it post-turbo and can't find it even though the visibility is good. Pre-trubo is hard for me to see. Do you have two pyros on your coach? It would be interesting to graph out the temperature differences on the two. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > On my 82 FC I converted it over to a 250 HP CAT. I have installed > pyro probe locations before and 6" past the turbo. I have read where > the probe should be past the turbo so that in the event it breaks off > it will not shater the turbo blades. Others say the probe should be > located as close to the exhaust mandifold as possible. Where is the > pyro pbobe located on a stock 3208 250 HP from the factory? > > Jim > > 1982 35 FCRB > Yorba Linda, CA > |
