1984pt40 Front heater core leak - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1984pt40 Front heater core leak (/showthread.php?tid=3518) |
1984pt40 Front heater core leak - Wayne - 09-25-2006 10:50 I haven't posted here in a while, I guess things have been going too smoothly (knock on wood) However now I have a bit of a problem - my front heater core is leaking and I have opened up the beast and it looks like a major job to pull the heater core (3 fans? ductwork and 22 year old bolts. Is there any chance that some sort of radiator sealent could be put in the system and it would work? I have never used the stuff and have no idea if it is a good idea or not, especially in a wet sleeve diesel. Any thoughts?? Thanks Wayne Chappuis 1984 pt 40 Roswell ga 1984pt40 Front heater core leak - Mike Hohnstein - 09-25-2006 14:02 Filling the extensive glycol system, sporlan valves, many heater cores with funny sealing stuff, don't sound good to me. MH ----- Original Message ----- From: Wayne To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 25, 2006 5:50 PM Subject: [WanderlodgeForum] 1984pt40 Front heater core leak I haven't posted here in a while, I guess things have been going too smoothly (knock on wood) However now I have a bit of a problem - my front heater core is leaking and I have opened up the beast and it looks like a major job to pull the heater core (3 fans? ductwork and 22 year old bolts. Is there any chance that some sort of radiator sealent could be put in the system and it would work? I have never used the stuff and have no idea if it is a good idea or not, especially in a wet sleeve diesel. Any thoughts?? Thanks Wayne Chappuis 1984 pt 40 Roswell ga [Non-text portions of this message have been removed] 1984pt40 Front heater core leak - Gregory OConnor - 09-25-2006 15:21 I agree with Mike. I would use a hammer and beat on the core to see if it stoped leaking before putting in the used car dealer stop leak products. In a pinch I have used a couple of blunt chisels and crimped both ends of a leaking flow tube. Greg --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Filling the extensive glycol system, sporlan valves, many heater cores with funny sealing stuff, don't sound good to me. > MH > ----- Original Message ----- > From: Wayne > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, September 25, 2006 5:50 PM > Subject: [WanderlodgeForum] 1984pt40 Front heater core leak > > > I haven't posted here in a while, I guess things have been going too > smoothly (knock on wood) > > However now I have a bit of a problem - my front heater core is > leaking and I have opened up the beast and it looks like a major job > to pull the heater core (3 fans? ductwork and 22 year old bolts. > > Is there any chance that some sort of radiator sealent could be put in > the system and it would work? I have never used the stuff and have no > idea if it is a good idea or not, especially in a wet sleeve diesel. > > Any thoughts?? > > Thanks > > Wayne Chappuis > 1984 pt 40 > > Roswell ga > > > > > > [Non-text portions of this message have been removed] > 1984pt40 Front heater core leak - dr71@...> - 09-26-2006 06:49 Wayne, I also have a 1984 pusher. This year I have recored my generator radiator, and had to replace my coach radiator. I have already considered having my heater cores checked for preventive maintenance, if I can get them out. My suggestion would be to take the heater core out and fix it for peace of mind, then you can tell me how to get mine out. Don't you like advice from someone who knows practically nothing about radiators. Bill Rush 1984 PT40 Newberry,SC > > From: "Wayne" > Date: 2006/09/25 Mon PM 06:50:25 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 1984pt40 Front heater core leak > > I haven't posted here in a while, I guess things have been going too > smoothly (knock on wood) > > However now I have a bit of a problem - my front heater core is > leaking and I have opened up the beast and it looks like a major job > to pull the heater core (3 fans? ductwork and 22 year old bolts. > > Is there any chance that some sort of radiator sealent could be put in > the system and it would work? I have never used the stuff and have no > idea if it is a good idea or not, especially in a wet sleeve diesel. > > Any thoughts?? > > Thanks > > Wayne Chappuis > 1984 pt 40 > > Roswell ga > > > > > > |
