1973 Wanderlodge/391 Ford gas engine - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1973 Wanderlodge/391 Ford gas engine (/showthread.php?tid=355) |
1973 Wanderlodge/391 Ford gas engine - Mike Knight - 04-22-2005 03:25 Where can I get the tune up specs. for a 391 Ford gas engine? Web Site? Timing, Dwell etc. Thanks! Mike K. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com 1973 Wanderlodge/391 Ford gas engine - Mike Hohnstein - 04-22-2005 12:07 Lose the points. A Pertronix breakerless conversion would be a better investment. Engine will start and run much better. Put one in a 312 Ford engine I used to own and was amazed at the improvement. Put one on a 67 427 Chevy engine, same result. If the carb gives you any trouble, don't try to fix it, buy a new one, not with a governor. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: Mike Knight To: WanderlodgeForum@yahoogroups.com Sent: Friday, April 22, 2005 10:25 AM Subject: [WanderlodgeForum] 1973 Wanderlodge/391 Ford gas engine Where can I get the tune up specs. for a 391 Ford gas engine? Web Site? Timing, Dwell etc. Thanks! Mike K. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] 1973 Wanderlodge/391 Ford gas engine - Curt Sprenger - 04-22-2005 12:32 Good advise Mike. I followed Mike's and other's advise when I had my 1974 BB with the 534 gas engine. I was amazed how well the engine ran after installing the Pertronix unit. It took about 20 minutes to remove the old point system and install the pertronix unit...you can't miss on this one. Install a new coil, new plugs and wires too. I had to remove the dog-house to change the plugs/wires. Again, following these guys advise, I removed the carburetor/govenor garbage and installed a 750 Holley. Easy job, about one hour. You need a smaller carburetor, a 650 CFM for the 391. Good luck. Curt Sprenger 1987 PT38 Anaheim, Ca. Mike Hohnstein wrote: > Lose the points. A Pertronix breakerless conversion would be a better > investment. Engine will start and run much better. Put one in a 312 > Ford engine I used to own and was amazed at the improvement. Put one > on a 67 427 Chevy engine, same result. If the carb gives you any > trouble, don't try to fix it, buy a new one, not with a governor. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: Mike Knight > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, April 22, 2005 10:25 AM > Subject: [WanderlodgeForum] 1973 Wanderlodge/391 Ford gas engine > > > Where can I get the tune up specs. > for a 391 Ford gas engine? Web Site? > Timing, Dwell etc. > Thanks! > > Mike K. > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > *Yahoo! Groups Links* > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > -- Curt Sprenger â87PT38, Anaheim, Calif. 1973 Wanderlodge/391 Ford gas engine - Jim Owens - 04-22-2005 14:30 --- In WanderlodgeForum@yahoogroups.com, Mike Knight <mjklightmedia2@y...> wrote: > Where can I get the tune up specs. > for a 391 Ford gas engine? Web Site? > Timing, Dwell etc. > Thanks! Mike, FWIW, When the Magnapulse aftermarket ignition failed on our 77 534 Ford the mechanic replaced it with off the shelf parts (Ford OEM). The distributor, coil and ignition module were replaced. Wires and plugs had been previously replaced during a tune-up and the alternator had been rebuilt. [The new distributor is 6" taller and requires fabrication of a new bracket for the engine a/c compressor to move it outboard 2". If your engine a/c is inoperative you might just remove the compressor and reroute the belt.] Mileage went from a dismal 3.9 mpg to a high of 6.4 mpg - avg 5.0 mpg flat towing a 2000 Jeep Cherokee. Starting and driveability were also improved. I recently talked with an auto enthusiast who spoke highly of a throttle body injector for big block gas engines (i.e. Chevy 454 and Ford 460). He said horsepower was down slightly but low end torque and fuel economy improved - just the ticket for a 'Bird. My wife's '93 Cadillac Fleetwood had a 5.7L V-8 with throttle body injection that delivered 25 mpg at 75 mph and would top out at 120 mph. Hmmmm...food for thought. Jim Owens 77FC33SB (Gas) Sweetie's Dream Lake of the Ozarks, MO 1973 Wanderlodge/391 Ford gas engine - randydupree2000 - 04-23-2005 13:12 --- In WanderlodgeForum@yahoogroups.com, Mike Knight <mjklightmedia2@y...> wrote: > Where can I get the tune up specs. > for a 391 Ford gas engine? Web Site? > Timing, Dwell etc. > Thanks! > > Mike K. mike,send me your address and i'll send you a factory BB manual on your engine..randy@... > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com 1973 Wanderlodge/391 Ford gas engine - drivesnewport - 04-24-2005 14:15 And as the happy/lucky buyer of Curt's '74 FC31, I can ditto his enthusiasm for whatever it was he did! Caroline 1974 FC31 Los Angeles Land --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > Good advise Mike. I followed Mike's and other's advise when I had my > 1974 BB with the 534 gas engine. I was amazed how well the engine ran > after installing the Pertronix unit. It took about 20 minutes to remove > the old point system and install the pertronix unit...you can't miss on > this one. Install a new coil, new plugs and wires too. I had to remove > the dog-house to change the plugs/wires. > > Again, following these guys advise, I removed the carburetor/govenor > garbage and installed a 750 Holley. Easy job, about one hour. You need a > smaller carburetor, a 650 CFM for the 391. > > Good luck. > Curt Sprenger 1987 PT38 Anaheim, Ca. > > Mike Hohnstein wrote: > > > Lose the points. A Pertronix breakerless conversion would be a better > > investment. Engine will start and run much better. Put one in a 312 > > Ford engine I used to own and was amazed at the improvement. Put one > > on a 67 427 Chevy engine, same result. If the carb gives you any > > trouble, don't try to fix it, buy a new one, not with a governor. > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > ----- Original Message ----- > > From: Mike Knight > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, April 22, 2005 10:25 AM > > Subject: [WanderlodgeForum] 1973 Wanderlodge/391 Ford gas engine > > > > > > Where can I get the tune up specs. > > for a 391 Ford gas engine? Web Site? > > Timing, Dwell etc. > > Thanks! > > > > Mike K. > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > > > > ---------------------------------------------------------------------------- -- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > ------------------------------------------------------------------------ > > *Yahoo! Groups Links* > > > > * To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > -- > Curt Sprenger `87PT38, Anaheim, Calif. |
