Block Heater - Printable Version
+--- Thread: Block Heater (/showthread.php?tid=3587)
Pages: 1 2 3
Block Heater - erniecarpet@... - 10-04-2006 08:25
Gardner, i always use my block heater when temps go below 50. Not only does
it help it start right away- you don't have to use the starter for a long
period. Sometimes old age kicks in and I forget that it is on and only know it
when
I walk by the engine and feel some heat coming from the side panel.
83 PT40
Livingston, Montana
Block Heater - erniecarpet@... - 10-04-2006 09:36
Is your switch on the dash or by the co-pilots chair?
Block Heater - Gardner Yeaw - 10-04-2006 11:38
At what temperature would you consider running the block heater a few
hours before starting? I will be in New Hampshire next weekend and I
expect overnight temperatures in the high 30's. My 3208 NA always
kicks off right away and, from what I have read, high 30's shouldn't
be a concern, but I figured I'd ask more experienced folks.
Gardner
78FC33
Block Heater - Jay Darst - 10-04-2006 12:21
I like to use the block heater when temps fall below 50 degrees.
cuts down on the smoke at start-up
much better for the engine to be warmed up at start up
the block heater is a "use it or loose it"
If you are plugged in, there is no down side to using the block heater.
I use the block often. Much nicer start up.
Jay Darst
85PT40
Springfield, IL
few
I
> Gardner
> 78FC33
Block Heater - Rob Robinson - 10-04-2006 12:30
Gardner I use my engine heat before every startup no matter what the outside
temp is. My 8v92 always starts up easy but even easier and with less smoke
when the preheat is applied. I will bet yours will too. I've heard it is NOT
a good idea to forget to turn it off before starting the engine. I don't
know this for a fact just heard it somewhere.
On 04/10/06, Gardner Yeaw wrote:
> 78FC33
Rob, Sue & Merlin Robinson
94 WLWB
Block Heater - Gardner Yeaw - 10-04-2006 12:32
Jay,
I hadn't considered the white smoke reduction. It sounds like a
good idea to fire up the heater when I go to bed. I know the
neighbor on the exhaust side would appreciate it and I would like to
be as neighborly as I can.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
heater.
> Jay Darst
> 85PT40
> Springfield, IL
a
> few
> I
always
shouldn't
> > Gardner
> > 78FC33
Block Heater - Rob Robinson - 10-04-2006 12:46
Gardner I wouldn't leave your heater on all night. If you're at all like me
an feel the need to get up somewhere in the middle of the night to visit the
facilities then that's a good time to put it on. Two or three hours is
usually enough.
> Jay,
> Gardner
> 78FC33
> "Jay Darst"
> heater.
> > Jay Darst
> > 85PT40
> > Springfield, IL
> "Gardner Yeaw"
> a
> > few
> and
> > I
> always
> shouldn't
> > > Gardner
> > > 78FC33
94 WLWB
Block Heater - Gardner Yeaw - 10-04-2006 13:14
Ernie,
Sounds like I may need to add an indicator light on the dash to
remind me it is on.
Gardner
78fc33
only does
a long
only know it when
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
Block Heater - Gardner Yeaw - 10-04-2006 23:51
The switch is by the co-pilots chair down by the floor
Block Heater - erniecarpet@... - 11-29-2006 10:32
RoseMary- not a dumb question at all. it is a red switch at the co-pilots
feet.
83PT40
Livingston, Montana
