Followup on camloc fastener (was Re: Weather Striping) - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Followup on camloc fastener (was Re: Weather Striping) (/showthread.php?tid=3601) |
Followup on camloc fastener (was Re: Weather Striping) - Pete Masterson - 10-07-2006 14:10 Well, the number 6 camlocs arrived from Aircraft Spruce and .... they're too short. I was able to re-measure (using the distance from the pin to the end added to my broken stud) to get an overall length of 1.0625 (approx) inches. At the Milspec <http://www.milspecproducts.com/index.html> web site, this matches to a #16 camloc (1.06 inches in the catalog) and (after another bout with the magnifying glass), I see a 1 in front of the 6 that I originally took as a tool mark rather than a part of the number. Aircraft Spruce doesn't carry the #16, but Milspec does (and stated that they're the supplier to Aircraft Spruce). This is a "very long" and "unusual" camloc, but I was able to order them (by phone as Milspec doesn't have an online order form). They'll be here next week. Note, the Milspec web site includes a page with the overall length of each camloc, should you need it. Yes, I have the 6-tooth internal locking washer that goes on the inside of the panel. (I ordered new ones with the new camlocs as I doubt that I can remove the old ones in re-usable condition.) Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 29, 2006, at 3:39 PM, Leroy Eckert wrote: > OK, you have a -6 probably about 11/4 to 11/2 inch long. Is that > about right? Did you have a six tooth internal locking washer? > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, September 29, 2006 11:40 AM > Subject: Re: [WanderlodgeForum] Re: Weather Striping > > > Leroy, I got to admit, you've got a lot better eyesight than I have! > The number is barely noticeable ... but with a strong magnifier, I > was able to make out a "6" on the one from my coach. > > Thanks. > [Non-text portions of this message have been removed] Followup on camloc fastener (was Re: Weather Striping) - Leroy Eckert - 10-09-2006 01:18 Pete, Just got home from being at the coach. I got my Camloc's #4 and they were short also. I made the same error and then passed the bad info to you. Sorry! Turns out mine are #14. I have to say the numbers are very difficult to see. Thanks for the milspec site. I gotta reorder. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Saturday, October 07, 2006 9:10 PM Subject: [WanderlodgeForum] Followup on camloc fastener (was Re: Weather Striping) Well, the number 6 camlocs arrived from Aircraft Spruce and .... they're too short. I was able to re-measure (using the distance from the pin to the end added to my broken stud) to get an overall length of 1.0625 (approx) inches. At the Milspec <http://www.milspecproducts.com/index.html> web site, this matches to a #16 camloc (1.06 inches in the catalog) and (after another bout with the magnifying glass), I see a 1 in front of the 6 that I originally took as a tool mark rather than a part of the number. Aircraft Spruce doesn't carry the #16, but Milspec does (and stated that they're the supplier to Aircraft Spruce). This is a "very long" and "unusual" camloc, but I was able to order them (by phone as Milspec doesn't have an online order form). They'll be here next week. Note, the Milspec web site includes a page with the overall length of each camloc, should you need it. Yes, I have the 6-tooth internal locking washer that goes on the inside of the panel. (I ordered new ones with the new camlocs as I doubt that I can remove the old ones in re-usable condition.) Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 29, 2006, at 3:39 PM, Leroy Eckert wrote: > OK, you have a -6 probably about 11/4 to 11/2 inch long. Is that > about right? Did you have a six tooth internal locking washer? > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, September 29, 2006 11:40 AM > Subject: Re: [WanderlodgeForum] Re: Weather Striping > > > Leroy, I got to admit, you've got a lot better eyesight than I have! > The number is barely noticeable ... but with a strong magnifier, I > was able to make out a "6" on the one from my coach. > > Thanks. > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Followup on camloc fastener (was Re: Weather Striping) - jqrjr - 10-09-2006 02:24 I got cam locks at Ace hardware, a little work on the door for shore power but the work fine! Jim Riordan 88WBWLXXV -- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Pete, Just got home from being at the coach. I got my Camloc's #4 and they were short also. I made the same error and then passed the bad info to you. Sorry! Turns out mine are #14. I have to say the numbers are very difficult to see. Thanks for the milspec site. I gotta reorder. > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > > > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, October 07, 2006 9:10 PM > Subject: [WanderlodgeForum] Followup on camloc fastener (was Re: Weather Striping) > > > Well, the number 6 camlocs arrived from Aircraft Spruce and .... > they're too short. > > I was able to re-measure (using the distance from the pin to the end > added to my broken stud) to get an overall length of 1.0625 (approx) > inches. > > At the Milspec <http://www.milspecproducts.com/index.html> web site, > this matches to a #16 camloc (1.06 inches in the catalog) and (after > another bout with the magnifying glass), I see a 1 in front of the 6 > that I originally took as a tool mark rather than a part of the > number. Aircraft Spruce doesn't carry the #16, but Milspec does (and > stated that they're the supplier to Aircraft Spruce). This is a "very > long" and "unusual" camloc, but I was able to order them (by phone as > Milspec doesn't have an online order form). They'll be here next > week. Note, the Milspec web site includes a page with the overall > length of each camloc, should you need it. > > Yes, I have the 6-tooth internal locking washer that goes on the > inside of the panel. (I ordered new ones with the new camlocs as I > doubt that I can remove the old ones in re-usable condition.) > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 42' > El Sobrante, CA > > On Sep 29, 2006, at 3:39 PM, Leroy Eckert wrote: > > > OK, you have a -6 probably about 11/4 to 11/2 inch long. Is that > > about right? Did you have a six tooth internal locking washer? > > > > Leroy Eckert > > 1990 WB-40 > > Niceville, FL > > > > > > > > ----- Original Message ----- > > From: Pete Masterson > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, September 29, 2006 11:40 AM > > Subject: Re: [WanderlodgeForum] Re: Weather Striping > > > > > > Leroy, I got to admit, you've got a lot better eyesight than I have! > > The number is barely noticeable ... but with a strong magnifier, I > > was able to make out a "6" on the one from my coach. > > > > Thanks. > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
