Alternators out - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Alternators out (/showthread.php?tid=3604) |
Alternators out - ronmarabito2002 - 10-08-2006 08:17 O.K. guys. Here's one for you to analyze. Couple days ago I was driving and both voltage guages went to 16 volts and 150 amps showing. Stopped at rest area to verify. Ralph and I talking on the phone decided it sounded like a lost ground or the regulators didn't see batteries as fully charged. I checked the voltage on the batteries and they read a real 15.7 volts. No way to run very far with that going on, so we headed for a stop and it was late in the day. Nextmorning, Benny said 150 amps could be from only one alternator, so we took alternators off the system one at a time. One was dead and the other showed a little output, so we headed down the road with that one working. Within an hour, it quit with a fault light showing. After I took it out of the system, the fault light remained. I started generator and allowed the battery chargers to take the place of the alternators. I do not intend to remove either while on the trip and try to find a decent place for re-build. Will do that when I get home. Not sure if one regulator went bad and then took out the other. I only want to do this once. There could be something else in the charging circuit that is the problem. If you can shed any light on this, let the ideas fly. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in Pigeon Forge, TN Alternators out - Rob Robinson - 10-08-2006 08:28 Ron if you have to remove part of the bedroom floor to get at the rear alternator don't be too quick to close up the hole after installing new alternator and belts. The belts stretch a little and you need to retighten them after a couple of hundred miles. Rig up something temporary as cover plate so you can have easy access to retighten those belts after say 500 miles. On 08/10/06, ronmarabito2002 > > O.K. guys. Here's one for you to analyze. > > Couple days ago I was driving and both voltage guages went to 16 volts > and 150 amps showing. Stopped at rest area to verify. Ralph and I > talking on the phone decided it sounded like a lost ground or the > regulators didn't see batteries as fully charged. I checked the > voltage on the batteries and they read a real 15.7 volts. No way to > run very far with that going on, so we headed for a stop and it was > late in the day. > > Nextmorning, Benny said 150 amps could be from only one alternator, so > we took alternators off the system one at a time. One was dead and > the other showed a little output, so we headed down the road with that > one working. Within an hour, it quit with a fault light showing. > After I took it out of the system, the fault light remained. I > started generator and allowed the battery chargers to take the place > of the alternators. I do not intend to remove either while on the > trip and try to find a decent place for re-build. Will do that when I > get home. Not sure if one regulator went bad and then took out the > other. I only want to do this once. There could be something else in > the charging circuit that is the problem. If you can shed any light > on this, let the ideas fly. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Currently in Pigeon Forge, TN > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Alternators out - ronmarabito2002 - 10-08-2006 11:40 Good idea, but not very practical unless I was taking a trip somewhere and returning home to close it up. I could let the belts work while I do some local running around though, but would not be 500 miles by a long shot. I might try re-designing the carpet installation in the bedroom in order to get away with much less work, but still have to remove the baseboard cover over piping below the drawers. Anything to add about the electrical problem causing the loss to the alternators? R.E.(Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Ron if you have to remove part of the bedroom floor to get at the rear > alternator don't be too quick to close up the hole after installing new > alternator and belts. The belts stretch a little and you need to retighten > them after a couple of hundred miles. Rig up something temporary as cover > plate so you can have easy access to retighten those belts after say 500 > miles. > > On 08/10/06, ronmarabito2002 > > > > O.K. guys. Here's one for you to analyze. > > > > Couple days ago I was driving and both voltage guages went to 16 volts > > and 150 amps showing. Stopped at rest area to verify. Ralph and I > > talking on the phone decided it sounded like a lost ground or the > > regulators didn't see batteries as fully charged. I checked the > > voltage on the batteries and they read a real 15.7 volts. No way to > > run very far with that going on, so we headed for a stop and it was > > late in the day. > > > > Nextmorning, Benny said 150 amps could be from only one alternator, so > > we took alternators off the system one at a time. One was dead and > > the other showed a little output, so we headed down the road with that > > one working. Within an hour, it quit with a fault light showing. > > After I took it out of the system, the fault light remained. I > > started generator and allowed the battery chargers to take the place > > of the alternators. I do not intend to remove either while on the > > trip and try to find a decent place for re-build. Will do that when I > > get home. Not sure if one regulator went bad and then took out the > > other. I only want to do this once. There could be something else in > > the charging circuit that is the problem. If you can shed any light > > on this, let the ideas fly. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > Currently in Pigeon Forge, TN > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Alternators out - jqrjr - 10-09-2006 00:40 Ron, I have been having a simmilar problem with my 88 WBWLXXV, the alternators have not yet gone out but I do have voltage that goes to 16 to high apms 150 also, this seem to happen to me after I have run for about an hour and happen intermittantly. I have not resolved the problem yet I was hoping the at RITV I could get some hands on help. Please let me know what happen with you! Jim Riordan --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > O.K. guys. Here's one for you to analyze. > > Couple days ago I was driving and both voltage guages went to 16 volts > and 150 amps showing. Stopped at rest area to verify. Ralph and I > talking on the phone decided it sounded like a lost ground or the > regulators didn't see batteries as fully charged. I checked the > voltage on the batteries and they read a real 15.7 volts. No way to > run very far with that going on, so we headed for a stop and it was > late in the day. > > Nextmorning, Benny said 150 amps could be from only one alternator, so > we took alternators off the system one at a time. One was dead and > the other showed a little output, so we headed down the road with that > one working. Within an hour, it quit with a fault light showing. > After I took it out of the system, the fault light remained. I > started generator and allowed the battery chargers to take the place > of the alternators. I do not intend to remove either while on the > trip and try to find a decent place for re-build. Will do that when I > get home. Not sure if one regulator went bad and then took out the > other. I only want to do this once. There could be something else in > the charging circuit that is the problem. If you can shed any light > on this, let the ideas fly. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Currently in Pigeon Forge, TN > |
