UPDATE: 87-89FC Throttle Cable - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: UPDATE: 87-89FC Throttle Cable (/showthread.php?tid=3620) |
UPDATE: 87-89FC Throttle Cable - Rick B - 10-11-2006 01:34 I just uploaded a file to the files section. The name of the file is 87FC35_Throttle_Cable.pdf It is the drawing from Bendix of the Throttle/Cruise cable. Teleflex/Morse P/N D-303192-000-0047.8 Bendix P/N 102735 (These numbers are also on the drawing.) Those with 87-89FC coaches will want to print this off for your records. You will also want to open the doghouse, and have someone watch as you run the accelerator cable, and make sure the cable is not rubbing on anything as it moves. An update as for my coach. After breaking this cable over a year ago, it was repaired and made to work, however recently I was enlightened to find out I was not getting Full Throttle (Thanks to Dave Thompson for swapping coaches with me and comparing notes). After 3 weeks in the shop trying to obtain the above mentioned part, we decided to go ahead and try to modify the existing one again to make it work better. The mechanic created a new mount such that the cable now has a nice straight line to the fuel pump lever, as well as some other adjusting, and I am now getting much better performance, and what I believe to be full throttle (or at least very close to it). There is an ongoing effort to try to get these cables made, and I will post an update on that effort when I learn more. Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, "w3ww" > > Rick, > > Good Luck! > > I'll also agree with Bob..............Anything you can pass along would be extremely appreciated. > > Don Mohney > 87FC35 > > > > [Non-text portions of this message have been removed] > UPDATE: 87-89FC Throttle Cable - w3ww - 10-11-2006 03:47 Rick, Got It. Thanks for the drawing and info. I'm sure I be checking that throttle cable before going anywhere. Don Mohney Jensen Beach 87FC35SB [Non-text portions of this message have been removed] UPDATE: 87-89FC Throttle Cable - pattypape - 10-11-2006 05:06 Thanks Rick for uploading this drawing. The late model FC owners would be interested in any further information. Thanks Again Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Rick B" > > I just uploaded a file to the files section. > The name of the file is 87FC35_Throttle_Cable.pdf > It is the drawing from Bendix of the Throttle/Cruise cable. > > Teleflex/Morse P/N D-303192-000-0047.8 > Bendix P/N 102735 > > (These numbers are also on the drawing.) > > Those with 87-89FC coaches will want to print this off > for your records. You will also want to open the doghouse, and have > someone watch as you run the accelerator cable, and make sure the > cable is not rubbing on anything as it moves. > > An update as for my coach. After breaking this cable over a year ago, > it was repaired and made to work, however recently I was enlightened > to find out I was not getting Full Throttle (Thanks to Dave Thompson > for swapping coaches with me and comparing notes). After 3 weeks in > the shop trying to obtain the above mentioned part, we decided to go > ahead and try to modify the existing one again to make it work better. > The mechanic created a new mount such that the cable now has a nice > straight line to the fuel pump lever, as well as some other adjusting, > and I am now getting much better performance, and what I believe to be > full throttle (or at least very close to it). > > There is an ongoing effort to try to get these cables made, and I will > post an update on that effort when I learn more. > > Rick > 87FC35 > Rochester, MN > > --- In WanderlodgeForum@yahoogroups.com, "w3ww" > > > > Rick, > > > > Good Luck! > > > > I'll also agree with Bob..............Anything you can pass along > would be extremely appreciated. > > > > Don Mohney > > 87FC35 > > > > > > > > [Non-text portions of this message have been removed] > > > |
