Rear Electric Heater - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rear Electric Heater (/showthread.php?tid=3630) |
Rear Electric Heater - Rob Robinson - 10-13-2006 03:42 I was wondering if anyone has ever accessed the rear electric heater. My coach is a 94 with a walk through bath. The electric heater is positioned under the clothes closet on the drivers side. This closet has four drawers below it and the heater is positioned below them. I'd like to get at it to give it a good cleaning. Every time I turn it on it smells like burnt dust for the first minute or so. I've pulled the drawers out and had a look around but didn't see any obvious screws that would let me remove panels or the draw frames. Any ideas? -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Rear Electric Heater - g_man1146 - 10-13-2006 04:22 Hi, If you have what is called a "toe-space" heater, designed to fit under the toe space of a cabinet, it will have two screws on the front that attach it to the wall or cabinet. The heater will slide out and then the cover can be removed to gain access for cleaning. Be sure to turn off the power prior to removing the heater, just turning the thermostat down won't necessarily protect you from a shock. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I was wondering if anyone has ever accessed the rear electric heater. My > coach is a 94 with a walk through bath. The electric heater is positioned > under the clothes closet on the drivers side. This closet has four drawers > below it and the heater is positioned below them. I'd like to get at it to > give it a good cleaning. Every time I turn it on it smells like burnt dust > for the first minute or so. I've pulled the drawers out and had a look > around but didn't see any obvious screws that would let me remove panels or > the draw frames. Any ideas? > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Rear Electric Heater - Rob Robinson - 10-13-2006 05:30 Thank you Rich I pulled it out as you and Fred directed and gave it a good vacuuming. Quite a build up of dust bunnies. Works and smell much better. On 13/10/06, g_man1146 > > Hi, If you have what is called a "toe-space" heater, designed to fit > under the toe space of a cabinet, it will have two screws on the > front that attach it to the wall or cabinet. The heater will slide > out and then the cover can be removed to gain access for cleaning. > Be sure to turn off the power prior to removing the heater, just > turning the thermostat down won't necessarily protect you from a > shock. > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > I was wondering if anyone has ever accessed the rear electric > heater. My > > coach is a 94 with a walk through bath. The electric heater is > positioned > > under the clothes closet on the drivers side. This closet has four > drawers > > below it and the heater is positioned below them. I'd like to get > at it to > > give it a good cleaning. Every time I turn it on it smells like > burnt dust > > for the first minute or so. I've pulled the drawers out and had a > look > > around but didn't see any obvious screws that would let me remove > panels or > > the draw frames. Any ideas? > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Rear Electric Heater - ronmarabito2002 - 10-13-2006 15:27 Rob: It is not necessary to remove any drawers, etc.. The heater is held in position by a couple of screws. You might have to remove the face plate first. It's been a couple years since I pulled mine. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in the Smoky Mountains --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I was wondering if anyone has ever accessed the rear electric heater. My > coach is a 94 with a walk through bath. The electric heater is positioned > under the clothes closet on the drivers side. This closet has four drawers > below it and the heater is positioned below them. I'd like to get at it to > give it a good cleaning. Every time I turn it on it smells like burnt dust > for the first minute or so. I've pulled the drawers out and had a look > around but didn't see any obvious screws that would let me remove panels or > the draw frames. Any ideas? > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Rear Electric Heater - Rob Robinson - 10-13-2006 16:17 Yup Ron you're right. Two screws and it was out. By the looks of it mine hadn't been cleaned in years. Easy job to do now that I know how it's done. On 13/10/06, ronmarabito2002 > > Rob: > > It is not necessary to remove any drawers, etc.. The heater is > held in position by a couple of screws. You might have to remove the > face plate first. It's been a couple years since I pulled mine. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Currently in the Smoky Mountains > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > I was wondering if anyone has ever accessed the rear electric heater. My > > coach is a 94 with a walk through bath. The electric heater is > positioned > > under the clothes closet on the drivers side. This closet has four > drawers > > below it and the heater is positioned below them. I'd like to get at > it to > > give it a good cleaning. Every time I turn it on it smells like > burnt dust > > for the first minute or so. I've pulled the drawers out and had a look > > around but didn't see any obvious screws that would let me remove > panels or > > the draw frames. Any ideas? > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Rear Electric Heater - TeamConfuzed@... - 10-13-2006 20:42 Since we are discussing that heater, I thought that I'd go out and test ours. The fan runs just fine once the thermostat is turned up, but there doesn't seem to be any heat coming out. Is there a fuse or switch that I might be overlooking? How about a source for a replacement heating element, if that turns out to be the problem? Thanks! --PirateJohn-- Directeur Sportif, Team Confuzed _www.PirateJohn.com_ (http://www.PirateJohn.com) a/k/a John W. Gilmer Jacksonville, FL 1982 PT-40 [Non-text portions of this message have been removed] Rear Electric Heater - erniecarpet@... - 10-14-2006 06:38 John, you might have to pull that heater out and take the cover off it. It has a long cord so it's easy to wrk n. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
