Coach decor Problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Coach decor Problem (/showthread.php?tid=3662) |
Coach decor Problem - Jack and Liz Pearce - 10-18-2006 01:33 Howdy. I am looking for a contour rug for our bathroom. The problem is finding a contour rug that will fit around the base of the Microphor commode. The front of the commode base measures 10 inches across. Ideas or suggestions to solve this problem would be appreciated. Thanks, Liz Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge Currently in Boerne, TX Coach decor Problem - adieu2y - 10-18-2006 02:56 Liz, I'm a retired flooring guy and I doubt you'll ever find one to fit. It would not be difficult to customize a rug to fit. First, take some pattern material and loose fit it. Then take a compass/ dividers (the kind we used in school to make circles) and and trace around the comode, walls etc. Now go shopping for just the right look in a rug/ carpet . The material should be heavy enough to lay flat and stay flat. I'd suggest you make another out of pattern material and see if it fits correctly. This is important as you need to trace the pattern on the BACK of the rug. REMEMBER, when you turn the rug over, turn your pattern over too! The edges of the rug will want to unravel so seal the edges with a fexible adhesive. I would use a silicone type. If you hope to machine wash it use lots of silicone. Maybe make 2 , one for summer colors and one for winter. jack V Lxi 05 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy. > I am looking for a contour rug for our bathroom. The problem is > finding a contour rug that will fit around the base of the Microphor > commode. The front of the commode base measures 10 inches across. > Ideas or suggestions to solve this problem would be appreciated. > > > Thanks, > Liz > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge > Currently in Boerne, TX > Coach decor Problem - erniecarpet@... - 10-18-2006 08:50 Liz- wait till I get home in December and I'll cut you one. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
