Central Vacuum - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Central Vacuum (/showthread.php?tid=368) |
Central Vacuum - olson_phil - 04-24-2005 07:22 Does anyone know how to remove a central vac on an 83 FC35SB? I have removed six screews that were holding it into the wood frame, and am able to raise it slightly, but can't get it out. Any help would be appreciated. Phil Olson Appleton, WI 83FC35SB Central Vacuum - mrdonut12 - 04-24-2005 08:25 Phil, I had to take mine out and I believe the hidden screws are behind the on/off switch plate. I had to remove the switch and remove a screw or 2 back there. Mine had quit working and a local vacuum shop repaired the motor for me for about 50 bucks. I was ready to replace the entire thing, but he said they were easy to fix. Did it in a day and didn't even have to order parts. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > Does anyone know how to remove a central vac on an 83 FC35SB? I have > removed six screews that were holding it into the wood frame, and am > able to raise it slightly, but can't get it out. Any help would be > appreciated. > > Phil Olson > Appleton, WI > 83FC35SB Central Vacuum - olson_phil - 04-24-2005 08:54 Thanks George. On mine, the on-off switch is located on the wall inside the cabinet, about 2 feet away from the vacuum. Does the electrical cord that runs from the switch to the vacuum have to be disconnected at the switch or is there an electric disconnect somewhere under the unit? Phil Olson Appleton, WI 83FC35SB --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > > > Phil, > I had to take mine out and I believe the hidden screws are behind > the on/off switch plate. I had to remove the switch and remove a > screw or 2 back there. > Mine had quit working and a local vacuum shop repaired the motor > for me for about 50 bucks. I was ready to replace the entire thing, > but he said they were easy to fix. Did it in a day and didn't even > have to order parts. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > > --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > > > > Does anyone know how to remove a central vac on an 83 FC35SB? I have > > removed six screews that were holding it into the wood frame, and am > > able to raise it slightly, but can't get it out. Any help would be > > appreciated. > > > > Phil Olson > > Appleton, WI > > 83FC35SB Central Vacuum - mrdonut12 - 04-24-2005 09:18 Phil, Well, THAT changes everything. ;o) Mine is behind the stepwell cover (when it's up) and mounted in the side of the cabinet to the right of the entry door. The switch is right next to it. I think I disconnected the power wire at the switch and fed the wire back into the vacuum to get the vacuum out. If I remember right, I also had to disconnect the (vacuum) exhaust air piece. The air from the vacuum exhausts out the coach floor into the propane tank area. So, you're probably caught up with the power wire and exhaust plumbing. It wasn't that easy for me to figure out, either, and I'm a car mechanic. LOL George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > Thanks George. On mine, the on-off switch is located on the wall > inside the cabinet, about 2 feet away from the vacuum. Does the > electrical cord that runs from the switch to the vacuum have to be > disconnected at the switch or is there an electric disconnect > somewhere under the unit? > > Phil Olson > Appleton, WI > 83FC35SB > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > wrote: > > > > > > Phil, > > I had to take mine out and I believe the hidden screws are behind > > the on/off switch plate. I had to remove the switch and remove a > > screw or 2 back there. > > Mine had quit working and a local vacuum shop repaired the motor > > for me for about 50 bucks. I was ready to replace the entire thing, > > but he said they were easy to fix. Did it in a day and didn't even > > have to order parts. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > > > > > > > Does anyone know how to remove a central vac on an 83 FC35SB? I have > > > removed six screews that were holding it into the wood frame, and am > > > able to raise it slightly, but can't get it out. Any help would be > > > appreciated. > > > > > > Phil Olson > > > Appleton, WI > > > 83FC35SB Central Vacuum - Jeff Miller - 04-24-2005 12:12 I agree with others, probably either the wire or the PVC exhaust pipe through the floor. The pipe is held by silicone seal, easy to pull free. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > Does anyone know how to remove a central vac on an 83 FC35SB? I have > removed six screews that were holding it into the wood frame, and am > able to raise it slightly, but can't get it out. Any help would be > appreciated. > > Phil Olson > Appleton, WI > 83FC35SB |
