Driving Light Air piston - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Driving Light Air piston (/showthread.php?tid=3690) |
Driving Light Air piston - erniecarpet@... - 10-23-2006 09:17 Alan, this is one item that has not been addressed. I'm glad you brought it up. Hopefully we will get some response. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] Driving Light Air piston - dspithaler@... - 10-23-2006 10:20 Alan there is a switch that the light has to touch to turn the light on. The light can be adjusted to hit it. If the cylinder is bad it is a Clippard. Mine is an SDR-20-3 & I got two new ones for sixty dollars for both. That made mine work fine after I adjusted them to come the whole way down. I don't think you can repair them. Don 89 SP 36' Butler, PA : One of my driving lights is slow to lower and then doesn't go quite all the way down (hence it won't come on until i push it into place). I was trying to find a post on working on those air pistons (... What are they called?). Can I repair or rebuild it? Thanks, Alan 87FC35 [Non-text portions of this message have been removed] Driving Light Air piston - Alan - 10-23-2006 12:40 One of my driving lights is slow to lower and then doesn't go quite all the way down (hence it won't come on until i push it into place). I was trying to find a post on working on those air pistons (... What are they called?). Can I repair or rebuild it? Thanks, Alan 87FC35 ps.. Just installed my headlight/bosch relay upgrade. I"m looking forward to trying it this weekend. |
