3208turbo idler pullies - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 3208turbo idler pullies (/showthread.php?tid=3709) |
3208turbo idler pullies - sweeperman210 - 10-26-2006 06:42 Hello i brought a 1980FC33SB back in may have put on 8,000.miles on it with no problems.The first owner had a new 250 turbo engine put in the bus when it was two years old and 22,000 miles I have the paper work from the cat dealer who did the work.Has anyone had to replace thier idler pullies?is it hard to to do ? mine are starting to make niose thanks Mark dammann 1980Fc33 3208turbo idler pullies - jim matus - 10-26-2006 16:29 You can buy the complete idler assy. from Cat(expensive)or you can buy just the bearings,plug and snap ring from Cat(much cheaper). The hardest part about rebuilding it is getting the old bearings off the shaft(hard to hold in press)I had a shop cut them off with a bearing cutter. Works great after done and saves you about $200.00 compared with a whole new assy. Jim Matus 1984 35FC Rescue CA > |
