AQUA HOT/OPERATOR ERROR - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: AQUA HOT/OPERATOR ERROR (/showthread.php?tid=3711) |
AQUA HOT/OPERATOR ERROR - rvdependent - 10-26-2006 10:23 What I found out after buying parts[filter,thermostats,nozzle,photo eye] and spending the whole day on my Aqua Hot 1]First problem appeared to be that the burner would run then turn off.I had activated the burner by turning up the thermosats, all 3 to the mid 80's when the burner failed to go on I then checked the domestic hot weater at the sink and found it not to be hot after several minutes. OK what I didn't take into consideration was that the burner was coming on then shutting off because the temperature requirement had been met [its Florida and probably high *80's in the coach. 1st operator error. 2] after turning the stats to the highest setting the burner ran and the exhaust was clean and hot, it only shut off when I turned the stats down. Now for the hot water problem. After exhausting myself, a trip to the local Blue Bird dealer and quizzing the mechanics,I called Aqua Hot-- should have done that first. explained about the domestic water not heating and was asked if my outside wash station valves were turn off. They were not,, problem solved. Having both turned on caused them to act like a mixing valve not allowing the hot water to circulate..OPERATOR ERROR. Many Thanks to all who responded to my request for help. I learned a great deal about my BlueBird. Many Thanks to all. Donald Brown,Palmetto,Florida BMC37 |
