FAN BLADE FOR AIR CONDITIONER - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FAN BLADE FOR AIR CONDITIONER (/showthread.php?tid=3794) |
FAN BLADE FOR AIR CONDITIONER - putneyflash - 11-10-2006 11:06 I am tryng to bring my dash air back to life on my 1983 FC-35 SB When i got the condenser installed and engergized i discovered that the white plastic fan Blade on one motor is broken. I have called blue bird, they don't carry them any longer. does anyone know when to get one.?? re brake 1983 FC-35 SB "Sagecoach" FAN BLADE FOR AIR CONDITIONER - Mike Hohnstein - 11-10-2006 12:12 Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. Randy Dupree helped me out a good a bit on the rework and it's still working fine. MH ----- Original Message ----- From: putneyflash To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 10, 2006 5:06 PM Subject: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER I am tryng to bring my dash air back to life on my 1983 FC-35 SB When i got the condenser installed and engergized i discovered that the white plastic fan Blade on one motor is broken. I have called blue bird, they don't carry them any longer. does anyone know when to get one.?? re brake 1983 FC-35 SB "Sagecoach" [Non-text portions of this message have been removed] FAN BLADE FOR AIR CONDITIONER - Curt Sprenger - 11-10-2006 14:52 Mike, Please provide the Red Dot parts and part numbers that you used. Thanks. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Mike Hohnstein wrote: >Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. >Randy Dupree helped me out a good a bit on the rework and it's still working fine. >MH > > > FAN BLADE FOR AIR CONDITIONER - putneyflash@...> - 11-11-2006 00:01 Thanks mike: as i work at a CAT shop we will try the upgrade first, but i know where to proceed if it fails > > From: Curt Sprenger > Date: 2006/11/10 Fri PM 09:52:45 EST > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER > > Mike, > Please provide the Red Dot parts and part numbers that you used. Thanks. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > Mike Hohnstein wrote: > > >Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. > >Randy Dupree helped me out a good a bit on the rework and it's still working fine. > >MH > > > > > > > > FAN BLADE FOR AIR CONDITIONER - Mike Hohnstein - 11-11-2006 06:31 I can't find the receipt, I found it on the Red Dot website, located a local dealer and had them get it for me. The one I chose has two fans on top is roughly 3 times the capacity of the original R 12 unit. 134 needs more condensor. MH ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 10, 2006 8:52 PM Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER Mike, Please provide the Red Dot parts and part numbers that you used. Thanks. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Mike Hohnstein wrote: >Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. >Randy Dupree helped me out a good a bit on the rework and it's still working fine. >MH > > > [Non-text portions of this message have been removed] FAN BLADE FOR AIR CONDITIONER - Curt Sprenger - 11-11-2006 11:02 Mike, Check this link. http://www.tknw.com/Products/RedDot/Condensers.asp Any of the two fan units look like what you used? Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Mike Hohnstein wrote: >I can't find the receipt, I found it on the Red Dot website, located a local dealer and had them get it for me. The one I chose has two fans on top is roughly 3 times the capacity of the original R 12 unit. 134 needs more condensor. >MH > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, November 10, 2006 8:52 PM > Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER > > > Mike, > Please provide the Red Dot parts and part numbers that you used. Thanks. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > Mike Hohnstein wrote: > > >Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. > >Randy Dupree helped me out a good a bit on the rework and it's still working fine. > >MH > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > FAN BLADE FOR AIR CONDITIONER - Mike Hohnstein - 11-11-2006 13:14 6260 is the one. MH ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Saturday, November 11, 2006 5:02 PM Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER Mike, Check this link. http://www.tknw.com/Products/RedDot/Condensers.asp Any of the two fan units look like what you used? Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Mike Hohnstein wrote: >I can't find the receipt, I found it on the Red Dot website, located a local dealer and had them get it for me. The one I chose has two fans on top is roughly 3 times the capacity of the original R 12 unit. 134 needs more condensor. >MH > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, November 10, 2006 8:52 PM > Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER > > > Mike, > Please provide the Red Dot parts and part numbers that you used. Thanks. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > Mike Hohnstein wrote: > > >Consider replacing the condenser with a 134a compatible unit. I used Red Dot. Make sure you replace the receiver dryer and expansion valve. I got to do mine twice because I didn't do the e/valve the first time, got clogged with debris. > >Randy Dupree helped me out a good a bit on the rework and it's still working fine. > >MH > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] |
