Facet Pump - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Facet Pump (/showthread.php?tid=3807) |
Facet Pump - dspithaler@... - 11-13-2006 07:14 Got a question on the facet pump??? Where is it located on a 89 SP 36' ??? I've owned this coach for three years been all over it underneath & haven't been able to find it. First off should it have one or did they build them with out a facet pump? Maybe I am looking for something that is not there. Also I have never been able to locate the front & back places to bleed the air when refilling the coolant after draining the system. The book tells where they are but I can't find them. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] Facet Pump - jvredden@... - 11-13-2006 21:54 the pumps are available from Mark Dexter 5742934328. he sold them to BB. I just got a pump from him. Also Vehicle Systems (who sells webasto replacements) has pumps for Primus. SE Hallum, a long time engineer with BB told me to stick with PRIMUS. He said " if it is working there is no better heat for an RV" If its not working its a PITA, as are all heat systems that do not work. Also Steve Birtles with this forum is a great source for PRIMUS parts and other electrical repairs. His post name is capeinnovations john redden 91 PT40 [Non-text portions of this message have been removed] Facet Pump - ronmarabito2002 - 11-14-2006 01:15 I assume you are talking about the pumps in the Primus System. They are located below the boilers. Very difficult to get to, but they are there. The engine pre-heat pump is located on the curb side attached to a diagonal brace down to the transmission. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > Got a question on the facet pump??? Where is it located on a 89 SP 36' ??? > I've owned this coach for three years been all over it underneath & haven't > been able to find it. First off should it have one or did they build them with > out a facet pump? Maybe I am looking for something that is not there. Also I > have never been able to locate the front & back places to bleed the air when > refilling the coolant after draining the system. The book tells where they > are but I can't find them. > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > Facet Pump - dspithaler@... - 11-14-2006 07:38 Thanks Ron I was talking about the Facet pump that pumps the fuel to the engine from the fuel tank up front. Don 89 SP 36' Butler, PA I assume you are talking about the pumps in the Primus System. They are located below the boilers. Very difficult to get to, but they are there. The engine pre-heat pump is located on the curb side attached to a diagonal brace down to the transmission. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , dspithaler@., dsp > > Got a question on the facet pump??? Where is it located on a 89 SP 36' ??? > I've owned this coach for three years been all over it underneath & haven't > been able to find it. First off should it have one or did they build them with > out a facet pump? Maybe I am looking for something that is not there. Also I > have never been able to locate the front & back places to bleed the [Non-text portions of this message have been removed] |
