Air Bags & ZF Transmission - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Bags & ZF Transmission (/showthread.php?tid=3816) |
Air Bags & ZF Transmission - dlefty12 - 11-14-2006 14:53 Gentleman, I have two problems I am currently dealing with on my '87 35FC. The first is I am replacing my air bags. I purchased Firestone W01- 358-8992 for the front. The bags in the coach are original Firestone bags although the fronts are 2 inches wider in diameter than the new ones. This has me baffled because I thought I researched it from the forum when I purchased the bags last year. I just never got around to having them installed until now. So, did Firestone make an update that would account for the size difference? The second is that I can't get the bird to go into gear. I checked to see if I had the relay going to the ZF ECU. I have the proper Bosch 30 amp relay. I then checked the voltage and it was 12.7 V going to the ECU. Could I have trouble with the throttle position sender not allowing the coach to go into gear? Has anybody had this problem? Any help would be much appreciated... Dan Leftwich Somers, NY '87 35FC Air Bags & ZF Transmission - Gregory OConnor - 11-14-2006 18:27 Dan, 12.7 v with the ground YOU used for the test, how is the ground the ECU uses? even the TPS and other sensors need good contact. I often wondered if the trouble is with sensors and ECU using mixed battery banks. I would simply jump + and - on both banks and see if it makes a repair. Then ground both banks to the engine block and see if it makes a repair. As far as air springs go, I noticed, the OLD BAGS at the SWBB Rally were wider. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "dlefty12" wrote: > > Gentleman, > I have two problems I am currently dealing with on my '87 35FC. > > The first is I am replacing my air bags. I purchased Firestone W01- > 358-8992 for the front. The bags in the coach are original > Firestone bags although the fronts are 2 inches wider in diameter > than the new ones. This has me baffled because I thought I > researched it from the forum when I purchased the bags last year. I > just never got around to having them installed until now. So, did > Firestone make an update that would account for the size difference? > > The second is that I can't get the bird to go into gear. I checked > to see if I had the relay going to the ZF ECU. I have the proper > Bosch 30 amp relay. I then checked the voltage and it was 12.7 V > going to the ECU. Could I have trouble with the throttle position > sender not allowing the coach to go into gear? Has anybody had this > problem? > > Any help would be much appreciated... > > Dan Leftwich > Somers, NY '87 35FC > Air Bags & ZF Transmission - Richard Gideon - 11-15-2006 05:54 Dan: Check the ZF load sensor adjustment. The load sensor on your coach is located on backside of roadside battery bank. When the CAT 3208 injection pump is in the "idle" position the load sensor needs to be adjusted to the "idle" indication which means the load sensor control lever must point to the "idle tang" on the load sensor casting. An illustration of the "load sensor" can be seen in the ZF instruction sheet which also depicts how to properly check the ZF transmission fluid level. Also check the load sensor cable which runs to the injection pump for binding and kinks. Check for missing, broken or mispositioned load sensor return spring. I lubed my Load Control sensor cable using CorrosionX which is available from Aircraft Spruce & aircraft supply stores. Dick Gideon 1989 35FC Cessna 172 Vietnam Vet Seabee MCB5 Rolla, Missouri --- In WanderlodgeForum@yahoogroups.com, "dlefty12" wrote: > > Gentleman, > I have two problems I am currently dealing with on my '87 35FC. > > The first is I am replacing my air bags. I purchased Firestone W01- > 358-8992 for the front. The bags in the coach are original > Firestone bags although the fronts are 2 inches wider in diameter > than the new ones. This has me baffled because I thought I > researched it from the forum when I purchased the bags last year. I > just never got around to having them installed until now. So, did > Firestone make an update that would account for the size difference? > > The second is that I can't get the bird to go into gear. I checked > to see if I had the relay going to the ZF ECU. I have the proper > Bosch 30 amp relay. I then checked the voltage and it was 12.7 V > going to the ECU. Could I have trouble with the throttle position > sender not allowing the coach to go into gear? Has anybody had this > problem? > > Any help would be much appreciated... > > Dan Leftwich > Somers, NY '87 35FC > Air Bags & ZF Transmission - Tom McCarthy - 11-15-2006 13:37 Now, Greg. Flair and Blair were rather narrow. Otherwise, you are correct and no offense taken, my follicly challenged friend. Tom McCarthy Poway, CA 95 PT42 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Dan, 12.7 v with the ground YOU used for the test, how is the ground > the ECU uses? even the TPS and other sensors need good contact. I > often wondered if the trouble is with sensors and ECU using mixed > battery banks. I would simply jump + and - on both banks and see if > it makes a repair. Then ground both banks to the engine block and see > if it makes a repair. > As far as air springs go, I noticed, the OLD BAGS at the SWBB Rally > were wider. > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > wrote: > > > > Gentleman, > > I have two problems I am currently dealing with on my '87 35FC. > > > > The first is I am replacing my air bags. I purchased Firestone W01- > > 358-8992 for the front. The bags in the coach are original > > Firestone bags although the fronts are 2 inches wider in diameter > > than the new ones. This has me baffled because I thought I > > researched it from the forum when I purchased the bags last year. > I > > just never got around to having them installed until now. So, did > > Firestone make an update that would account for the size difference? > > > > The second is that I can't get the bird to go into gear. I checked > > to see if I had the relay going to the ZF ECU. I have the proper > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 V > > going to the ECU. Could I have trouble with the throttle position > > sender not allowing the coach to go into gear? Has anybody had > this > > problem? > > > > Any help would be much appreciated... > > > > Dan Leftwich > > Somers, NY '87 35FC > > > Air Bags & ZF Transmission - dlefty12 - 12-29-2006 08:08 Hi Dick, I am still dealing with the ZF trans. not going into gear. It seems to go into gear when the weather is warm but on colder days it doesn't. My father and I have tried to get into the load sensor box in the roadside compartment but the steel access plate has three bolts with the nuts on the inside which turn when we try to loosen. I can't get behind the plate to hold the nuts. Any suggestions? Dan Leftwich 87 FC35 Somers NY --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > Dan: Check the ZF load sensor adjustment. The load sensor on your > coach is located on backside of roadside battery bank. When the CAT > 3208 injection pump is in the "idle" position the load sensor needs > to be adjusted to the "idle" indication which means the load sensor > control lever must point to the "idle tang" on the load sensor > casting. An illustration of the "load sensor" can be seen in the ZF > instruction sheet which also depicts how to properly check the ZF > transmission fluid level. > > Also check the load sensor cable which runs to the injection pump for > binding and kinks. Check for missing, broken or mispositioned load > sensor return spring. I lubed my Load Control sensor cable using > CorrosionX which is available from Aircraft Spruce & aircraft supply > stores. > > Dick Gideon 1989 35FC > Cessna 172 > Vietnam Vet Seabee MCB5 > Rolla, Missouri > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > wrote: > > > > Gentleman, > > I have two problems I am currently dealing with on my '87 35FC. > > > > The first is I am replacing my air bags. I purchased Firestone W01- > > 358-8992 for the front. The bags in the coach are original > > Firestone bags although the fronts are 2 inches wider in diameter > > than the new ones. This has me baffled because I thought I > > researched it from the forum when I purchased the bags last year. > I > > just never got around to having them installed until now. So, did > > Firestone make an update that would account for the size difference? > > > > The second is that I can't get the bird to go into gear. I checked > > to see if I had the relay going to the ZF ECU. I have the proper > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 V > > going to the ECU. Could I have trouble with the throttle position > > sender not allowing the coach to go into gear? Has anybody had > this > > problem? > > > > Any help would be much appreciated... > > > > Dan Leftwich > > Somers, NY '87 35FC > > > Air Bags & ZF Transmission - Gregory OConnor - 12-29-2006 09:09 grinder or plasma wrench GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "dlefty12" wrote: > > Hi Dick, > > I am still dealing with the ZF trans. not going into gear. It seems > to go into gear when the weather is warm but on colder days it > doesn't. My father and I have tried to get into the load sensor box > in the roadside compartment but the steel access plate has three > bolts with the nuts on the inside which turn when we try to loosen. > I can't get behind the plate to hold the nuts. Any suggestions? > > Dan Leftwich > 87 FC35 > Somers NY > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > Dan: Check the ZF load sensor adjustment. The load sensor on > your > > coach is located on backside of roadside battery bank. When the > CAT > > 3208 injection pump is in the "idle" position the load sensor > needs > > to be adjusted to the "idle" indication which means the load > sensor > > control lever must point to the "idle tang" on the load sensor > > casting. An illustration of the "load sensor" can be seen in the > ZF > > instruction sheet which also depicts how to properly check the ZF > > transmission fluid level. > > > > Also check the load sensor cable which runs to the injection pump > for > > binding and kinks. Check for missing, broken or mispositioned > load > > sensor return spring. I lubed my Load Control sensor cable using > > CorrosionX which is available from Aircraft Spruce & aircraft > supply > > stores. > > > > Dick Gideon 1989 35FC > > Cessna 172 > > Vietnam Vet Seabee MCB5 > > Rolla, Missouri > > > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > > wrote: > > > > > > Gentleman, > > > I have two problems I am currently dealing with on my '87 35FC. > > > > > > The first is I am replacing my air bags. I purchased Firestone > W01- > > > 358-8992 for the front. The bags in the coach are original > > > Firestone bags although the fronts are 2 inches wider in > diameter > > > than the new ones. This has me baffled because I thought I > > > researched it from the forum when I purchased the bags last > year. > > I > > > just never got around to having them installed until now. So, > did > > > Firestone make an update that would account for the size > difference? > > > > > > The second is that I can't get the bird to go into gear. I > checked > > > to see if I had the relay going to the ZF ECU. I have the > proper > > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 > V > > > going to the ECU. Could I have trouble with the throttle > position > > > sender not allowing the coach to go into gear? Has anybody had > > this > > > problem? > > > > > > Any help would be much appreciated... > > > > > > Dan Leftwich > > > Somers, NY '87 35FC > > > > > > Air Bags & ZF Transmission - one_dusty_hoot - 12-29-2006 09:19 Dan, Have you done the ZF update that inserts a relay in the 12 volts from the ignition switch? All kinds of kinky transmission happenings with low V. Chances are you have done this, but thought ot ask. bob janes, 87FC35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "dlefty12" wrote: > > Hi Dick, > > I am still dealing with the ZF trans. not going into gear. It seems > to go into gear when the weather is warm but on colder days it > doesn't. My father and I have tried to get into the load sensor box > in the roadside compartment but the steel access plate has three > bolts with the nuts on the inside which turn when we try to loosen. > I can't get behind the plate to hold the nuts. Any suggestions? > > Dan Leftwich > 87 FC35 > Somers NY > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > Dan: Check the ZF load sensor adjustment. The load sensor on > your > > coach is located on backside of roadside battery bank. When the > CAT > > 3208 injection pump is in the "idle" position the load sensor > needs > > to be adjusted to the "idle" indication which means the load > sensor > > control lever must point to the "idle tang" on the load sensor > > casting. An illustration of the "load sensor" can be seen in the > ZF > > instruction sheet which also depicts how to properly check the ZF > > transmission fluid level. > > > > Also check the load sensor cable which runs to the injection pump > for > > binding and kinks. Check for missing, broken or mispositioned > load > > sensor return spring. I lubed my Load Control sensor cable using > > CorrosionX which is available from Aircraft Spruce & aircraft > supply > > stores. > > > > Dick Gideon 1989 35FC > > Cessna 172 > > Vietnam Vet Seabee MCB5 > > Rolla, Missouri > > > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > > wrote: > > > > > > Gentleman, > > > I have two problems I am currently dealing with on my '87 35FC. > > > > > > The first is I am replacing my air bags. I purchased Firestone > W01- > > > 358-8992 for the front. The bags in the coach are original > > > Firestone bags although the fronts are 2 inches wider in > diameter > > > than the new ones. This has me baffled because I thought I > > > researched it from the forum when I purchased the bags last > year. > > I > > > just never got around to having them installed until now. So, > did > > > Firestone make an update that would account for the size > difference? > > > > > > The second is that I can't get the bird to go into gear. I > checked > > > to see if I had the relay going to the ZF ECU. I have the > proper > > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 > V > > > going to the ECU. Could I have trouble with the throttle > position > > > sender not allowing the coach to go into gear? Has anybody had > > this > > > problem? > > > > > > Any help would be much appreciated... > > > > > > Dan Leftwich > > > Somers, NY '87 35FC > > > > > > Air Bags & ZF Transmission - dlefty12 - 12-29-2006 11:23 Yes, I have the relays installed and the output is 14 V. I troubleshot this back in the beginning of November when it began acting up. I ran a few tests thanks to a couple of forum members. Wouldn't you know it, the bird started to run fine just in time for my Thanksgiving trip down to the Birdnest. Had a few other things worked on by Bleakley in Unidilla Ga. I thought that it was a freak thing and that I was in the clear. So I get back home to NY and now that it is cold again the problem has come up again. Back to the drawing board Dan Leftwich 87FC35, Somers NY --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Dan, > Have you done the ZF update that inserts a relay > in the 12 volts from the ignition switch? All kinds > of kinky transmission happenings with low V. > Chances are you have done this, but thought ot ask. > > bob janes, 87FC35, greenville, sc > > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > wrote: > > > > Hi Dick, > > > > I am still dealing with the ZF trans. not going into gear. It > seems > > to go into gear when the weather is warm but on colder days it > > doesn't. My father and I have tried to get into the load sensor > box > > in the roadside compartment but the steel access plate has three > > bolts with the nuts on the inside which turn when we try to > loosen. > > I can't get behind the plate to hold the nuts. Any suggestions? > > > > Dan Leftwich > > 87 FC35 > > Somers NY > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > > > > Dan: Check the ZF load sensor adjustment. The load sensor on > > your > > > coach is located on backside of roadside battery bank. When the > > CAT > > > 3208 injection pump is in the "idle" position the load sensor > > needs > > > to be adjusted to the "idle" indication which means the load > > sensor > > > control lever must point to the "idle tang" on the load sensor > > > casting. An illustration of the "load sensor" can be seen in the > > ZF > > > instruction sheet which also depicts how to properly check the ZF > > > transmission fluid level. > > > > > > Also check the load sensor cable which runs to the injection pump > > for > > > binding and kinks. Check for missing, broken or mispositioned > > load > > > sensor return spring. I lubed my Load Control sensor cable using > > > CorrosionX which is available from Aircraft Spruce & aircraft > > supply > > > stores. > > > > > > Dick Gideon 1989 35FC > > > Cessna 172 > > > Vietnam Vet Seabee MCB5 > > > Rolla, Missouri > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > > > wrote: > > > > > > > > Gentleman, > > > > I have two problems I am currently dealing with on my '87 > 35FC. > > > > > > > > The first is I am replacing my air bags. I purchased Firestone > > W01- > > > > 358-8992 for the front. The bags in the coach are original > > > > Firestone bags although the fronts are 2 inches wider in > > diameter > > > > than the new ones. This has me baffled because I thought I > > > > researched it from the forum when I purchased the bags last > > year. > > > I > > > > just never got around to having them installed until now. So, > > did > > > > Firestone make an update that would account for the size > > difference? > > > > > > > > The second is that I can't get the bird to go into gear. I > > checked > > > > to see if I had the relay going to the ZF ECU. I have the > > proper > > > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 > > V > > > > going to the ECU. Could I have trouble with the throttle > > position > > > > sender not allowing the coach to go into gear? Has anybody had > > > this > > > > problem? > > > > > > > > Any help would be much appreciated... > > > > > > > > Dan Leftwich > > > > Somers, NY '87 35FC > > > > > > > > > > Air Bags & ZF Transmission - dlefty12 - 12-29-2006 11:26 Not a bad idea! Anybody have any other thoughts on this? Dan Leftwich 87FC35, Somers, NY --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > grinder or plasma wrench > GregoryO'Connor > 94ptRomolandCa > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > wrote: > > > > Hi Dick, > > > > I am still dealing with the ZF trans. not going into gear. It > seems > > to go into gear when the weather is warm but on colder days it > > doesn't. My father and I have tried to get into the load sensor > box > > in the roadside compartment but the steel access plate has three > > bolts with the nuts on the inside which turn when we try to > loosen. > > I can't get behind the plate to hold the nuts. Any suggestions? > > > > Dan Leftwich > > 87 FC35 > > Somers NY > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > > > > Dan: Check the ZF load sensor adjustment. The load sensor on > > your > > > coach is located on backside of roadside battery bank. When the > > CAT > > > 3208 injection pump is in the "idle" position the load sensor > > needs > > > to be adjusted to the "idle" indication which means the load > > sensor > > > control lever must point to the "idle tang" on the load sensor > > > casting. An illustration of the "load sensor" can be seen in the > > ZF > > > instruction sheet which also depicts how to properly check the ZF > > > transmission fluid level. > > > > > > Also check the load sensor cable which runs to the injection pump > > for > > > binding and kinks. Check for missing, broken or mispositioned > > load > > > sensor return spring. I lubed my Load Control sensor cable using > > > CorrosionX which is available from Aircraft Spruce & aircraft > > supply > > > stores. > > > > > > Dick Gideon 1989 35FC > > > Cessna 172 > > > Vietnam Vet Seabee MCB5 > > > Rolla, Missouri > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > > > wrote: > > > > > > > > Gentleman, > > > > I have two problems I am currently dealing with on my '87 > 35FC. > > > > > > > > The first is I am replacing my air bags. I purchased Firestone > > W01- > > > > 358-8992 for the front. The bags in the coach are original > > > > Firestone bags although the fronts are 2 inches wider in > > diameter > > > > than the new ones. This has me baffled because I thought I > > > > researched it from the forum when I purchased the bags last > > year. > > > I > > > > just never got around to having them installed until now. So, > > did > > > > Firestone make an update that would account for the size > > difference? > > > > > > > > The second is that I can't get the bird to go into gear. I > > checked > > > > to see if I had the relay going to the ZF ECU. I have the > > proper > > > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 > > V > > > > going to the ECU. Could I have trouble with the throttle > > position > > > > sender not allowing the coach to go into gear? Has anybody had > > > this > > > > problem? > > > > > > > > Any help would be much appreciated... > > > > > > > > Dan Leftwich > > > > Somers, NY '87 35FC > > > > > > > > > > Air Bags & ZF Transmission - Richard Gideon - 12-30-2006 07:52 Dan: Try PB Blaster or any good penetrating oil; apply or spray the bolts/nuts everytime you walk by them and let the PB Blaster work for a day or more to insure that the rust etc is loosened. Dick Gideon Parked in Fredericksburg ,TX 1989 35FC IPAQ 4700 --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > Dan: Check the ZF load sensor adjustment. The load sensor on your > coach is located on backside of roadside battery bank. When the CAT > 3208 injection pump is in the "idle" position the load sensor needs > to be adjusted to the "idle" indication which means the load sensor > control lever must point to the "idle tang" on the load sensor > casting. An illustration of the "load sensor" can be seen in the ZF > instruction sheet which also depicts how to properly check the ZF > transmission fluid level. > > Also check the load sensor cable which runs to the injection pump for > binding and kinks. Check for missing, broken or mispositioned load > sensor return spring. I lubed my Load Control sensor cable using > CorrosionX which is available from Aircraft Spruce & aircraft supply > stores. > > Dick Gideon 1989 35FC > Cessna 172 > Vietnam Vet Seabee MCB5 > Rolla, Missouri > > --- In WanderlodgeForum@yahoogroups.com, "dlefty12" > wrote: > > > > Gentleman, > > I have two problems I am currently dealing with on my '87 35FC. > > > > The first is I am replacing my air bags. I purchased Firestone W01- > > 358-8992 for the front. The bags in the coach are original > > Firestone bags although the fronts are 2 inches wider in diameter > > than the new ones. This has me baffled because I thought I > > researched it from the forum when I purchased the bags last year. > I > > just never got around to having them installed until now. So, did > > Firestone make an update that would account for the size difference? > > > > The second is that I can't get the bird to go into gear. I checked > > to see if I had the relay going to the ZF ECU. I have the proper > > Bosch 30 amp relay. I then checked the voltage and it was 12.7 V > > going to the ECU. Could I have trouble with the throttle position > > sender not allowing the coach to go into gear? Has anybody had > this > > problem? > > > > Any help would be much appreciated... > > > > Dan Leftwich > > Somers, NY '87 35FC > > > |
