Front running light mod - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Front running light mod (/showthread.php?tid=3821) |
Front running light mod - Ralph L. Fullenwider - 11-15-2006 05:20 Hello everyone: Some time back there was a thread on someone making or having made a stainless cover for the front running lights that is located between the headlights on the 90's Coaches. I searched but did locate the thread. Where was it made? are they available? Any help is appreciated. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma Front running light mod - David Brady - 11-15-2006 06:41 Hi Ralph, These guys can definitely make it. They may even have something is stock: http://www.summit-products.com/contact.htm David Brady '02 LXi, Smokey Va no more Ralph L. Fullenwider wrote: > Hello everyone: > > Some time back there was a thread on someone making or having made a > stainless cover for the front running lights that is located between the > headlights on the 90's Coaches. > > I searched but did locate the thread. Where was it made? are they > available? Any help is appreciated. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > Front running light mod - Curt Sprenger - 11-15-2006 07:44 Ralph, Greg O'Connor made a SS cover that goes between the head lights on his '94. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ralph L. Fullenwider wrote: >Hello everyone: > >Some time back there was a thread on someone making or having made a >stainless cover for the front running lights that is located between the >headlights on the 90's Coaches. > >I searched but did locate the thread. Where was it made? are they >available? Any help is appreciated. > >Safe travels, > >Ralph and Charolette Fullenwider >Ralph's RV Solutions, Duncan, Oklahoma > > > > Front running light mod - Leroy Eckert - 11-15-2006 08:05 Ralph: I fabricated flat stainless for my coach including a plate that surrounds the headlight and turn signal. I used 20 guage #8 polished stainless. Got the metal from Phoenix Metals. Leroy Eckert 1990 WB-40 Smoke N Mirrors Niceville, FL ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 15, 2006 11:20 AM Subject: [WanderlodgeForum] Front running light mod Hello everyone: Some time back there was a thread on someone making or having made a stainless cover for the front running lights that is located between the headlights on the 90's Coaches. I searched but did locate the thread. Where was it made? are they available? Any help is appreciated. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma [Non-text portions of this message have been removed] Front running light mod - Ralph L. Fullenwider - 11-15-2006 09:10 Thanks to all for the info, very much appreciated. With your help, I have found the solution. Ralph At 01:41 PM 11/15/2006 -0500, you wrote: >Hi Ralph, > >These guys can definitely make it. They may even have >something is stock: > >http://www.summit-products.com/contact.htm > >David Brady >'02 LXi, Smokey >Va no more > >Ralph L. Fullenwider wrote: > > Hello everyone: > > > > Some time back there was a thread on someone making or having made a > > stainless cover for the front running lights that is located between the > > headlights on the 90's Coaches. > > > > I searched but did locate the thread. Where was it made? are they > > available? Any help is appreciated. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma Front running light mod - Gregory OConnor - 11-15-2006 17:18 Ralph, I made several out of rem stock I think 6 units cost less than 20.00 to make. Its easy if you have access to a brake. from headlight to headlight there is a slight radius that can be duplicated by leaving both fold tabs with material to trim ( aprox 2 inches)drag a plasma torch quick for the first 4-5 and last 4-5 inches but lift the torch during the center cut to heat the dross and distort the SS with a radius. If you want it closer to chrome use "everbright" SS I went with the DeLorean look using brushed SS. I made one of each for a guy we are meeting up with in Quartsite. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Thanks to all for the info, very much appreciated. With your help, I have > found the solution. > > Ralph > > > At 01:41 PM 11/15/2006 -0500, you wrote: > >Hi Ralph, > > > >These guys can definitely make it. They may even have > >something is stock: > > > >http://www.summit-products.com/contact.htm > > > >David Brady > >'02 LXi, Smokey > >Va no more > > > >Ralph L. Fullenwider wrote: > > > Hello everyone: > > > > > > Some time back there was a thread on someone making or having made a > > > stainless cover for the front running lights that is located between the > > > headlights on the 90's Coaches. > > > > > > I searched but did locate the thread. Where was it made? are they > > > available? Any help is appreciated. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > |
