Best Mobile Internet Service - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Best Mobile Internet Service (/showthread.php?tid=3834) |
Best Mobile Internet Service - Rob Robinson - 11-16-2006 14:50 I'd like to ask those who connect to the internet using Verizon PC cards for their recommendations. So far I've found four available cards PC5740, V620, KPC650 and V640. From what Verizon tells me it is the Plan I select that determines the speed. They say the Broadband Access is the fastest. Is it your experience that any of the above PC cards will do the job or is one better than another. Thanks for your info. -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Best Mobile Internet Service - Dan Weaver - 11-16-2006 15:57 This forum is the best I found on the subject: http://www.evdoforums.com/index.php Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I'd like to ask those who connect to the internet using Verizon PC cards for > their recommendations. So far I've found four available cards PC5740, V620, > KPC650 and V640. From what Verizon tells me it is the Plan I select that > determines the speed. They say the Broadband Access is the fastest. Is it > your experience that any of the above PC cards will do the job or is one > better than another. Thanks for your info. > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Best Mobile Internet Service - Julia Bonser - 11-16-2006 16:38 I don't know which PC card would be best for your laptop but the EVDO forum would provide good information. http://www.evdoforums.com/index.php We have had wireless data card since March of '05. We ordered the external antenna and that has helped us get connected in low signal areas. I read today where Verizon has just added the whole southern tip of Texas to its EVDO system. Julie Bonser 1992 WLWB PT 40' On Nov 16, 2006, at 8:50 PM, Rob Robinson wrote: > I'd like to ask those who connect to the internet using Verizon PC > cards for > their recommendations. So far I've found four available cards > PC5740, V620, > KPC650 and V640. From what Verizon tells me it is the Plan I select > that > determines the speed. They say the Broadband Access is the fastest. > Is it > your experience that any of the above PC cards will do the job or > is one > better than another. Thanks for your info. > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > Best Mobile Internet Service - Dan Weaver - 11-16-2006 16:38 More info: On the EVDO air card, my laptop has the new express card/34 slot. My wife's laptop has the PCMIA slot. (Currently, there are 2 types of Data card formats available: - PCMCIA (or PC Slot) - this is the PC Slot that is in most laptops before 2006 (and even still in many new laptops). Some popular laptops don't have a PC Slot (iBook or PowerBook 12 inch). - ExpressCard - this is a new format that just started coming out in 2006 and at some point, it will be the primary connection. By 2007, 70% of laptops will have ExpressCards and not PC Slots. So, if you have a new laptop, determine if it has a PC Slot or an ExpressCard (BTW, ExpressCard comes in two different sizes 34mm or 54mm sizes, most laptops use the ExpressCard/34 size).) If we were to do EVDO today, I would buy a package deal off the EVDO forum link of a Kyocera KR1 Router (the router has a PCMIA EVDO card slot, then broadcasts wifi to computers in range), with an EVDO PCMIA card, and an external antenna. I would set up the PCMIA EVDO card in my wife's laptop, and then from then on have the router serve both laptops via that card. This would build a wifi EVDO card "connectivity" network for computers in range, work at home, and on the road in the coach. You could then also optionally provide the wifi security code with coaches parked near you, so they could also connect via your KR1 modem/EVDO card. I am currently on Comcast cable high speed â but looking into converting to EVDO for at home and on the road connectivity. There are many links on the EVDO forum â some lead to verizons site to determine what speed they offer in your home area. Dan --- In WanderlodgeForum@yahoogroups.com, "Dan Weaver" > > This forum is the best I found on the subject: > http://www.evdoforums.com/index.php > > Dan > 94 BMC 37' > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > I'd like to ask those who connect to the internet using Verizon PC > cards for > > their recommendations. So far I've found four available cards > PC5740, V620, > > KPC650 and V640. From what Verizon tells me it is the Plan I > select that > > determines the speed. They say the Broadband Access is the > fastest. Is it > > your experience that any of the above PC cards will do the job or > is one > > better than another. Thanks for your info. > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > Best Mobile Internet Service - Tom Meservey - 11-17-2006 00:53 Hi Rob and group. I have had the Verizone 5740 for over a year now and really like it. The speed is not great (National Access) but it is faster than dial up, averaging about 144kps. What I have found is it is VERY dependable. I have just returned from upper Maine where I never have internet, but this year Verizon has struck a deal with U.S. Cellular (and other carries) so I could use my laptop with the PC card off thier tower, a little slow, but good and reliable. I use the internet alot and do not want to use my cell phone for connection (which is MUCH slower), so the PC card perfect for me. The PC card plus my 2 cell phones, with 700 minutes a month, runs me about $144.00. Now that we are permanent residents of SC and not traveling when I PC card contract (2 years) is up, I may consider going to a land line and DSL; however in this area, a phone, plus DSL is still going to cost me about $50-60 a month. AND Charleston is going to get Broadband for Verizon the first of the year, jacking the speeds up to 400-700kps, with the same PC card. Verizon's Technical support is really good and I don't have any complaints about either service. One thing you might want to check, is I think two of the PC cards now have antennas and that might be better, however, the Kyeoca card was almost $200 last time I checked, and I got the 5740 for free with a two year contract. So I was just going to hold of buying an antenna'd card until I needed it; but now won't so that is a moot point. Tom Meservey, USN (Ret) Ladson, SC - with the 1981 still for sale __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] Best Mobile Internet Service - Jack and Liz Pearce - 11-18-2006 04:13 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I'd like to ask those who connect to the internet using Verizon PC cards for > their recommendations. So far I've found four available cards PC5740, V620, > KPC650 and V640. From what Verizon tells me it is the Plan I select that > determines the speed. They say the Broadband Access is the fastest. Is it > your experience that any of the above PC cards will do the job or is one > better than another. Thanks for your info. > > -- > Rob, Sue & Merlin Robinson > 94 WLWB Howdy. We purchased Verizon's PC5740 in August this year. My plan is the Broadband/National Access with Quick2Net. The service is OK, certainly better than dial-up. BUT the performance depends on the signal strength. When we were in Fort Worth area and I had a good signal( 2-3 bars), the reception was very good. Now we are in Hondo, 30 miles west of San Antonio, TX and I have one signal bar and occasionally lose that and then I just have to wait until the signal comes back. So I am not really happy with the PC card right now. I considered the card that has the adjustable external antenna and I regret that I didn't buy that. I talked to Verizon tech and there is no way to boost the signal. We are still considering a satellite dish but those too are very expensive. Just my dollar's worth. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Best Mobile Internet Service - Thomas and Valeria Eastham - 12-12-2006 14:06 I wanted to share my mobile internet access experiences from today with the group. I've got a macbook laptop and have experience with EDGE, EVDO, etc as a traveling IT consultant for many years. I found none of these "cellular" options acceptable for more than occasional use. Today I just bought a Cingular Samsung a707 cell phone because it is highly rated and sports the new HSDPA 3G high speed data service. I had no trouble getting connected with bluetooth, my macbook and this phone. I am using it right now to post this message. My speeds today have been around 300kbps upload and download (real) per dslreports speed tests. Others have reported up to 1000kbps observed speeds. For me this is incredible as the data service is cheap as an option on a phone plan, I need no cables because I am using bluetooth, and the phone can be bought for $50 on a new plan from Cingular or $200 on ebay (I bought on ebay). Oh also you can talk on the phone and use the internet at the same time :-) The downside? HSDPA is only available in major cities right now but the phone will drop down to EDGE for non-covered areas. I hope someone else gets some value out of this as I find it very exciting and affordable / flexible. Thomas Eastham Houston, TX 1983 FC35 SB --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > I'd like to ask those who connect to the internet using Verizon PC > cards for > > their recommendations. So far I've found four available cards > PC5740, V620, > > KPC650 and V640. From what Verizon tells me it is the Plan I select that > > determines the speed. They say the Broadband Access is the fastest. > Is it > > your experience that any of the above PC cards will do the job or is one > > better than another. Thanks for your info. > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > Howdy. > We purchased Verizon's PC5740 in August this year. My plan is the > Broadband/National Access with Quick2Net. The service is OK, certainly > better than dial-up. BUT the performance depends on the signal > strength. When we were in Fort Worth area and I had a good signal( 2-3 > bars), the reception was very good. Now we are in Hondo, 30 miles west > of San Antonio, TX and I have one signal bar and occasionally lose > that and then I just have to wait until the signal comes back. So I am > not really happy with the PC card right now. I considered the card > that has the adjustable external antenna and I regret that I didn't > buy that. I talked to Verizon tech and there is no way to boost the > signal. We are still considering a satellite dish but those too are > very expensive. Just my dollar's worth. > > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > |
