Rediline relay noise - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rediline relay noise (/showthread.php?tid=3839) |
Rediline relay noise - mrkane1952 - 11-17-2006 09:11 Greetings All: Anyone have a suggested modification to cure the noisy Rediline relay? Perhaps a replacement latching relay that won't hum? I would like to keep the option of using the Rediline, but the noise is too obnoxious when in an otherwise quiet environment. Thanks-- M.R.Kane '85 PT40 Rediline relay noise - one_dusty_hoot - 11-17-2006 13:54 M, I do not have a Rediline to compare but I do know this. Many times a coil will hum because the laminations of the metal becomes loose. I have seen this come up before on a forum posting but that is the extent of my recall. You might try insulating the base of the coil from the enclosure with some stand-off insulators to reduce the resonance. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings All: > > Anyone have a suggested modification to cure the noisy Rediline relay? > Perhaps a replacement latching relay that won't hum? I would like to > keep the option of using the Rediline, but the noise is too obnoxious > when in an otherwise quiet environment. > > Thanks-- > M.R.Kane > '85 PT40 > Rediline relay noise - Jay Darst - 11-17-2006 14:36 M.R., Replace the relay and the noise will be gone. If ya want, I'll see if I still have one around here. I put it in and then shortly after, installed a Xantrex 2,500 watt inverter/charger. So, the rlay comes out permanently with the inverter update. Where r u from? Does your dash a/c work? Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings All: > > Anyone have a suggested modification to cure the noisy Rediline relay? > Perhaps a replacement latching relay that won't hum? I would like to > keep the option of using the Rediline, but the noise is too obnoxious > when in an otherwise quiet environment. > > Thanks-- > M.R.Kane > '85 PT40 > |
