6V92 TA engine - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 6V92 TA engine (/showthread.php?tid=3848) |
6V92 TA engine - mjzakowski - 11-19-2006 07:04 Does any one know where I can get a rebuild detroit diesel 6v92 or a take out reasonable??? joe 1984 pt40 6V92 TA engine - Mike Hohnstein - 11-19-2006 07:36 You are bound to be disappointed. I had a decision to make recently, buy a Cat reman for 8 grand or a Dealers Remanufacturing in Minneapolis for 6 grand. The engine in question is a 3208 250 hp. The parts guy at Badger Ford in Milwaukee who in retrospect was probably getting kick backs from Dealers, convinced me to take the economy model. 4k miles later, stuck on the side of Pennsy Turnpike I didn't feel good about the saving. Moreover the fact that the remanufacturer told me to pound sand didn't help. No problem, I popped for the 4 grand repair and moved on. Dealers decided to save 20 dollars and reused a small fuel injecter pump componet that failed. Total cost for the "reman" engine, 10 grand. It does seem to be a good runner, now that it is equipped with a real Cat pump, and doesn't use much oil, but I'm not full confidence as I wonder what else they left undone or cut corners on. Get a real Detroit with a warrantee and keep the value of your Bird on track. MH ----- Original Message ----- From: mjzakowski To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 19, 2006 1:04 PM Subject: [WanderlodgeForum] 6V92 TA engine Does any one know where I can get a rebuild detroit diesel 6v92 or a take out reasonable??? joe 1984 pt40 [Non-text portions of this message have been removed] 6V92 TA engine - ronmarabito2002 - 11-19-2006 08:49 Suggest you do a Google search on Detroit Diesel Engines or similar titles. Search also: Remanufactured diesel engines. I used to receive bus magazines that had ads for engines. These will turn up some sources and then you need to research the possibilies carefully. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > Does any one know where I can get a rebuild detroit diesel 6v92 or a > take out reasonable??? > > joe 1984 pt40 > 6V92 TA engine - Wilhelmus Schreurs - 11-19-2006 09:08 Try http://www.busnut.com, they should have something in there Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 19, 2006 12:49:25 PM Subject: [WanderlodgeForum] Re: 6V92 TA engine Suggest you do a Google search on Detroit Diesel Engines or similar titles. Search also: Remanufactured diesel engines. I used to receive bus magazines that had ads for engines. These will turn up some sources and then you need to research the possibilies carefully. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@ yahoogroups. com, "mjzakowski" <mjzakowski@ ...> wrote: > > Does any one know where I can get a rebuild detroit diesel 6v92 or a > take out reasonable?? ? > > joe 1984 pt40 > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
