Benny's Move - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Benny's Move (/showthread.php?tid=3856) |
Benny's Move - ronmarabito2002 - 11-21-2006 04:30 Hi all: Before everyone goes off the deep end about Benny's move and what it means, I just talked with Earl in Parts Dept. He told me that Benny applied for the move because it was an opportunity for him to advance. This was not a move prompted by BB management. Let's support the new tech guy. R.E. (Ron) Marabito, Dallas, TX 92WB40 Benny's Move - Wallace Craig - 11-21-2006 05:02 Ron, thanks for going straight to the facts; idle speculation never helped anyone. We should all be happy for Benny. ronmarabito2002 Before everyone goes off the deep end about Benny's move and what it means, I just talked with Earl in Parts Dept. He told me that Benny applied for the move because it was an opportunity for him to advance. This was not a move prompted by BB management. Let's support the new tech guy. R.E. (Ron) Marabito, Dallas, TX 92WB40 Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] Benny's Move - Mike Hohnstein - 11-21-2006 05:58 I believe I did mention that possibility. MH ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, November 21, 2006 10:30 AM Subject: [WanderlodgeForum] Benny's Move Hi all: Before everyone goes off the deep end about Benny's move and what it means, I just talked with Earl in Parts Dept. He told me that Benny applied for the move because it was an opportunity for him to advance. This was not a move prompted by BB management. Let's support the new tech guy. R.E. (Ron) Marabito, Dallas, TX 92WB40 [Non-text portions of this message have been removed] Benny's Move - Leroy Eckert - 11-21-2006 06:15 Since we are leaving tomorrow I elected to have the fan sensor air expressed to me. I will take it on the trip as a precaution. I certainly cannot fault a person trying to better himself and his family. Good for him. I just hope his successor can fill his shoes. I will continue to support BB. In my case, I found the answer elsewhere. I will know for certain after I return, install the new sensor and test the system. Then I will know how it operates. Just the facts in my case. Still looking for a wiring and plumbing schematic of the system. It would be very helpful when testing. Happy Thanksgiving to all. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Wallace Craig To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, November 21, 2006 11:02 AM Subject: Re: [WanderlodgeForum] Benny's Move Ron, thanks for going straight to the facts; idle speculation never helped anyone. We should all be happy for Benny. ronmarabito2002 Before everyone goes off the deep end about Benny's move and what it means, I just talked with Earl in Parts Dept. He told me that Benny applied for the move because it was an opportunity for him to advance. This was not a move prompted by BB management. Let's support the new tech guy. R.E. (Ron) Marabito, Dallas, TX 92WB40 Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Benny's Move - Curt Sprenger - 11-22-2006 14:41 Leroy, Please keep us posted. Much appreciated. Anyone know if the '87 PT38 8V92 has the same system? I'll second Leroy...HAPPY THANKSGIVING TO ALL OF THE FORUM MEMBERS! I'm looking forward to deep fried turkey and all the goodies...and left over turkey for sandwiches. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: >Since we are leaving tomorrow I elected to have the fan sensor air expressed to me. I will take it on the trip as a precaution. >I certainly cannot fault a person trying to better himself and his family. Good for him. I just hope his successor can fill his shoes. I will continue to support BB. >In my case, I found the answer elsewhere. I will know for certain after I return, install the new sensor and test the system. Then I will know how it operates. >Just the facts in my case. >Still looking for a wiring and plumbing schematic of the system. It would be very helpful when testing. > >Happy Thanksgiving to all. > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL > > > > Benny's Move - Leroy Eckert - 11-26-2006 13:59 Curt: Just off the Thanksgiving trip 10 pounds heavier. I did some road testing on my hydraulic fan system. This is what I found. Haven't replaced the fan sensor yet because the plug is different. I have not traced the plumbing either. 1990 WB-40 8v92 475hp Fan Sensor Ops Outside air temp 65 degrees, pulling a trailer, 70-75mph 1. Fan override switch on. Fan runs at high RPM and holds thermostat temp.(about 180) 2. Fan override switch off. My system fan is designed to run at approx 500-600 RPM until engine water reaches 195 degrees. At 195 degrees the fan sensor sends the fan to high RPM( about 1800) until water temp is decreased( happens quickly) and then back to idle RPM. Hence, the guage cycling. My coach has done this but not now, the sensor is bad. Temps are creeping above 210 and I didn't want to see how high it would go. I am told that the sensor is designed to default to the high fan mode if sensor failure occurs. Apparantly, my sensor has not completely failed yet, just is not cycling. 3. Fan override switch off. If chassis air conditioning is turned on, either pilot, copilot or both, the fan runs at continuous high RPM and holds engine water temp at thermostat value. Same affect as having the fan override switch on. As long as the a/c is on the fan runs at high speed. In this configuration, the fan override switch has no affect as the fan is already in high mode. This explains something I have been trying to figure out for two years. Intermittant water guage cycling. In summer I use the genset and the roof air to keep the family cool on the road. Generally, I do not use the chassis air while the genset is running. In this configuration, the guage cycles although not as pronunced as in winter. If I turn the chassis air on guage cycling stops. In summer my water temp runs about 190 in fan override, or chassis a/c on. 4. The fan RPM is not progressive, it is either idle RPM or high RPM On this trip I ran in fan override. I saw an overall decrease in engine oil, tranny and retarder temps. Engine water--180 Engine oil--215 Tranny oil--170 Retarder---230 Based on the foregoing, apparently the basic function of the sensor is to tell the fan to run high RPM when 195 is reached and go to idle RPM when you get off the road and cool down. I'm trying to determine why it's in the system. Why not run the fan 1800 all the time? It has no role if the chassis air is on anyway. Wish I could hear that fan cycle but cannot get back there while driving. That's it for now. After I install the new sensor I'll check what happens on the trip to Texas in Dec. If it starts to cycle, I'll leave it alone. Wish I had a drawing of the total system. BB does not have one. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL . ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 22, 2006 8:41 PM Subject: Re: [WanderlodgeForum] Benny's Move Leroy, Please keep us posted. Much appreciated. Anyone know if the '87 PT38 8V92 has the same system? I'll second Leroy...HAPPY THANKSGIVING TO ALL OF THE FORUM MEMBERS! I'm looking forward to deep fried turkey and all the goodies...and left over turkey for sandwiches. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: >Since we are leaving tomorrow I elected to have the fan sensor air expressed to me. I will take it on the trip as a precaution. >I certainly cannot fault a person trying to better himself and his family. Good for him. I just hope his successor can fill his shoes. I will continue to support BB. >In my case, I found the answer elsewhere. I will know for certain after I return, install the new sensor and test the system. Then I will know how it operates. >Just the facts in my case. >Still looking for a wiring and plumbing schematic of the system. It would be very helpful when testing. > >Happy Thanksgiving to all. > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL > > > > [Non-text portions of this message have been removed] |
