Locking Nuts on Fan - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Locking Nuts on Fan (/showthread.php?tid=386) |
Locking Nuts on Fan - pattypape - 04-25-2005 14:22 Hi Everyone, I need to do a little work behind the fan. Do these locking nuts need to be replaced each time they are removed?? I think they are called crush nuts. Does anyone know the torque for the fan bolt nuts. It would not be a pretty picture, if the fan kissed the radiator. It would make a lot of noise. Thanks, Bill 88 FC Michigan Locking Nuts on Fan - Mike Hohnstein - 04-25-2005 14:39 Torque is a spec that is determined by fastener diameter and thread count per inch. Lock tite and grade 8 bolts will usually keep the fan out of the radiator. The Cat shop manual has the torque specs. Mike Hohnstein Germantown, WI ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 25, 2005 9:22 PM Subject: [WanderlodgeForum] Locking Nuts on Fan Hi Everyone, I need to do a little work behind the fan. Do these locking nuts need to be replaced each time they are removed?? I think they are called crush nuts. Does anyone know the torque for the fan bolt nuts. It would not be a pretty picture, if the fan kissed the radiator. It would make a lot of noise. Thanks, Bill 88 FC Michigan ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
